查看: 536|回复: 4
求指教啊?CJ?????
发表于 2011-9-12 21:31:08 | 显示全部楼层 |阅读模式
       真不知道什么是CJ ?。 哥哥英文真不好。那天看了这个轻松搞定地速285+!暴红260不要来找我![新手篇第二弹跳跃终极决秘武器CountJump!!!!!!在看看论坛好多人都说是小跳?到底是哪种。。。 还是插件的问题或者是DCJ 指的是 drop countjump... 做等真相啊。。
      Countjump/CJ: A technique which makes Highjumps as easy as Longjumps, and makes it even possible to jump way longer on usual Longjumps as well. Discovered by Count.
      我真不懂, 也没有说明到底是如何操作的。
      我想大家说的小跳就是指拨一次滚轮吧。 轻松搞定地速285+!暴红260不要来找我!这个讲得应该是快速2次吧。。 在看看大家对他得评论。哥哥真弄不明白。
 楼主| 发表于 2011-9-12 21:38:25 | 显示全部楼层
Okay, so now you know about all the advantages of it, but how can we do it?
Well, the countjump is a combination of several techniques, just like the longjump. The first technique you have to perform is a regular longjump's prestrafe and at the end of the prestrafe you have to perform a doubleduck. To do that bind duck on your mousewheel (bind mwheelup/mwheeldown +duck) and scroll! After you've performed this doubleduck you are flying through the air for very short amount of time.
后来我在往下看看了。。。 应该指的是快速拨动滚轮2次。!~
发表于 2011-9-12 21:51:11 | 显示全部楼层
CJ就是 LJ助跑时小跳一下,可以有效地免疫HJ说带来的加速烦恼,
发表于 2011-9-12 23:47:15 | 显示全部楼层
看视频教程
发表于 2011-9-12 23:47:24 | 显示全部楼层
小跳, 加LJ狐线助跑。
