- 听众
- 收听
- 积分
- 20
- 主题
- 回帖
- 0
- 精华
注册时间2010-4-8
最后登录1970-1-1
楼主 |
发表于 2010-4-13 17:47:36
这个是里面参数
// HLTV Proxy configuration file
// HLTV proxy runs this file on start up
// This file should only be edited if you want to broadcast a game
// set HLTV proxy name as shown in score board
name "-2004- Esai.Cn HLTV"
// set HLTV name, how it should appear in game server browsers
hostname "-2004- Esai.Cn HLTV"
// set offline info text clients will see as reject reason if HLTV isn't broadcasting yet
offlinetext "Sorry, game is delayed. Please try again later."
// delays broadcasting for 30 seconds
delay 30.0
publicgame 0
// allow 3.5 KByte/sec as client rate. This is good a value
// for internet broadcasts. On LAN you may set this value to 10000
//maxclientrate 5500
// log HLTV console in proxy.log
// logfile 1
// local chatting for HLTV spectators enabled
chatmode 0
//allowjoingame 1
//maxclients 255
nomaster 1
//blockvoice 1
// if game server is password protected, enable this line
// serverpassword ""
// proxy's adim password for rcon, commentator etc.
adminpassword "esai"
// show message for 5 seconds each 60 seconds in center of X axis (-1) and
// above help text bar (0.85). Color given as hexadecimal RGBA .
loopcmd 1 60 localmsg "You're watching -2004- CHN HLTV Visit www.Play8.cn" 5 -1 0.86 5577FFFF
// hltv.tga will be shown instead of the default HLTV logo in spectator GUI
bannerfile "esaiHLTV.tga"
// these commands will be executed on connecting spectator client and may be used
// to adjust settings for HLTV (for example voice parameters)
signoncommands "voice_scale 2; voice_overdrive 16; volume 0.5; echo Voice adjusted for HLTV"
//echo hltv.cfg loaded. |
