鼠标设置里的提高精确度,会是位移变成加速状态,你鼠标移动多少,游戏里对应的位移却是加速的,
掌握不好,就无法游戏了。不加上去加速的命令,会使位移变成减速状态,也就是负加速。同样道理。
所以正常来说,要发挥稳定,还是去鼠标加速,同时,取消 “提高鼠标精确度”。
当然 你完全适应了你的某个加速或者是减速的设置,可以不用特意去加速。
- Windows Registry Editor Version 5.00
- [HKEY_CURRENT_USER\Control Panel\Mouse]
- "SmoothMouseXCurve"=hex:00,00,00,00,00,00,00,00,00,a0,00,00,00,00,00,00,00,40,\
- 01,00,00,00,00,00,00,80,02,00,00,00,00,00,00,00,05,00,00,00,00,00
- "SmoothMouseYCurve"=hex:00,00,00,00,00,00,00,00,66,a6,02,00,00,00,00,00,cd,4c,\
- 05,00,00,00,00,00,a0,99,0a,00,00,00,00,00,38,33,15,00,00,00,00,00
复制代码
复制上面的代码保存为"去鼠标加速.reg" 然后运行。需要重启Windows !
将-noforcemaccel -noforcemparms -noforcemspd加在CS桌面快捷方式的属性中目标栏cstrike.exe
或hl.exe -game cstrike后加上这几个参数,绝对没有一点点加速。
- "SmoothMouseXCurve"=hex:00,00,00,00,00,00,00,00,15,6e,00,00,00,00,00,00,00,40,\
- 01,00,00,00,00,00,29,dc,03,00,00,00,00,00,00,00,28,00,00,00,00,00
- "SmoothMouseYCurve"=hex:00,00,00,00,00,00,00,00,b8,5e,01,00,00,00,00,00,cd,4c,\
- 05,00,00,00,00,00,cd,4c,18,00,00,00,00,00,00,00,38,02,00,00,00,00
复制代码
复制上面的代码保存为"恢复鼠标加速.reg" 然后运行。即可还原,需要重启Windows ! |
