查看: 4705|回复: 34
[国际新闻] WR Special Release #8 - 36 New Demos
发表于 2012-3-14 08:43:29 | 显示全部楼层 |阅读模式
KeltA
8b1_brickngrass done in 04:01.34 ( 04:02.71 juanch0x )
bk_icerock done in 02:05.31 ( 02:05.68 buh )
bkz_goldbhop done in 01:29.20 ( 01:29.45 shNz )
bn_tombbhop done in 02:20.81 ( 02:21.19 DizZy )
cg_wildwesthop done in 02:40.03 ( 02:40.55 NAPZ )
ex_deathdrop done in 01:55.45 ( 01:55.81 KeltA )
kz_cg_palmcliff done in 02:42.79 ( 02:44.79 KeltA )
kz_ea_highblock done in 02:38.56 ( 02:40.05 koukouz )
kz_goldenbean_200401 done in 03:48.54 ( 03:57.85 koukouz )
kz_goldwood done in 02:47.46 ( 02:48.32 26 )
kz_kzdk_tropicisland done in 01:57.63 ( 01:59.12 Chasquido )
kz_xj_3ways[hard] done in 04:37.45 ( 04:41.14 Zefix )
kzm_cityhops done in 03:17.39 ( 03:19.79 DizZy )
kzro_raincliff done in 01:51.11 ( 01:54.12 w1zz )
kzsca_cityblock done in 02:00.29 ( 02:01.25 Bibika )
prochallenge_speed done in 02:32.03 ( 02:33.70 Chasquido )
rr_dangerblock done in 02:50.82 ( 02:52.34 aloprando )
sn_ezycliff done in 02:41.86 ( 02:45.46 Kraeft )
sn_giantree_v2 done in 03:24.66 ( 03:27.50 pizza^ )
kayne
kz_cargo done in 02:24.51 ( 02:26.78 shNz )
kz_cg_holodeck done in 04:23.13 ( 04:25.83 MepH )
kz_chinabl0ck_ez done in 03:32.58 ( 03:32.88 heL^_x )
kz_concise[easy] done in 02:46.67 ( 02:48.53 w1zz )
kz_cosy_temple3 done in 04:50.64 ( 04:57.24 g0zi )
kz_desolate3 done in 02:07.71 ( 02:08.56 juleeeh )
kz_ep_gigablock_b01 done in 02:07.56 ( 02:08.83 kayne )
kz_greattemple done in 04:18.62 ( 04:19.46 gizpo_O )
kz_kzarg_catacombsbhop done in 02:38.02 ( 02:40.81 Nukk )
kz_kzfr_treeclimb done in 06:51.42 ( 06:58.48 zhady )
kz_man_climbersxp done in 13:04.40 ( 13:10.13 7D )
kz_nix done in 02:41.99 ( 02:43.70 26 )
kz_xj_mountez done in 01:13.61 ( 01:14.52 shNz )
kz_xj_rockblock done in 01:25.23 ( 01:25.52 Chasquido )
kznl_mountainpass done in 01:41.76 ( 01:42.50 juanch0x )
kzsca_bagdad done in 01:23.33 ( 01:23.44 gizpo_O )
kzus_bleu done in 01:04.80 ( 01:05.03 Chasquido )
第一次发记录的帖子,不知道这样子行不行。。。不行管理员直接删掉。。。忘见谅。。。
优酷土豆的合并明显刺激着KeltA和kayne,他们两个估计有合体的嫌疑。。。本期亮点:goldbhop被刷,kelta WR突破100!!
此外还有cg_wildwesthopkz_xj_mountez ,最爱的地图、、
26被爆、shnz被爆、超歌被爆,各种被爆。。。
发表于 2012-3-14 09:02:31 | 显示全部楼层
bkz_goldbhop被刷了,不知道shNz还有没有动力刷回来了{:soso_e197:}
shNz的低调不是一般人能比得上的,如果我告诉 你,shNz在很久前就过了BJ 248的板子和DCJ272的板子,这个图她早就进了28了,你会不会信呢 不是有没有动力,而是,有没有兴趣  详情 回复 发表于 2012-3-18 15:52
 楼主| 发表于 2012-3-14 09:03:59 | 显示全部楼层
不知道怎么把国旗发上去
发表于 2012-3-14 09:34:40 | 显示全部楼层
不会发就别抢啊
这两人又发什么疯,留几张图给新人刷吧
因为从来没有发过,想尝个鲜,见谅见谅,哈哈  详情 回复 发表于 2012-3-14 10:26
 楼主| 发表于 2012-3-14 10:26:22 | 显示全部楼层
fantasist 发表于 2012-3-14 09:34
不会发就别抢啊
这两人又发什么疯,留几张图给新人刷吧
发表于 2012-3-14 10:26:35 | 显示全部楼层
无语了2个都是怪物 太强悍了
发表于 2012-3-14 12:24:18 | 显示全部楼层
  极限了,还刷了!
发表于 2012-3-14 13:03:56 | 显示全部楼层
我X!震惊了!!
    发表于 2012-3-14 13:27:07 | 显示全部楼层
    2 个人商量好的??
    发表于 2012-3-14 13:51:14 | 显示全部楼层
    多想~和从前一样.刷图直到天亮.可是你.不在我身旁.拖清风送去安康…
