查看: 1022|回复: 10
LJ pity stats
发表于 2012-2-28 22:16:15 | 显示全部楼层 |阅读模式
以下是一些令人遺憾的各種跳躍數據,有些是fail版子了,有些是pre太低了
有些是我跳的,有些是KZhk.sh[xtreme]跳的,懶得分了,就是覺得太遺憾才分享上來
DCJ Distance: 255.326293 Maxspeed: 340.466613 (65.438) Prestrafe: (273.9) (265.0) 275.028198 Strafes: 5 Sync: 9
Distance: 254.956024 Maxspeed: 330.850585 (60.379) Prestrafe: 270.471160 Strafes: 7 Sync: 8
Distance: 248.328277 Maxspeed: 326.803833 (65.840) Prestrafe: 260.963531 Strafes: 7 Sync: 8
LJ Distance: 247.385955 Maxspeed: 336.740844 (74.975) Prestrafe: 261.765380 Strafes: 7 Sync: 8
Distance: 242.054458 Maxspeed: 316.798370 (62.939) Prestrafe: 253.858596 Strafes: 7 Sync: 8
LJ Distance: 254.015563 Maxspeed: 342.600646 (71.609) Prestrafe: 270.991241 Strafes: 7 Sync: 9
Distance: 246.832992 Maxspeed: 326.235534 (60.783) Prestrafe: 265.452453 Strafes: 7 Sync: 9
DCJ 實際距離: 256.451171 空中最大速度: 342.062286 (67.475) 地面速度: (268.4) (263.3) 274.586791 加速次數: 6
Distance: 252.110748 Maxspeed: 329.325286 (59.681) Prestrafe: 269.644256 Strafes: 7 Sync: 8
Distance: 253.783325 Maxspeed: 331.311218 (57.504) Prestrafe: 273.806823 Strafes: 7 Sync: 8
LJ Distance: 240.049011 Maxspeed: 320.207183 (72.126) Prestrafe: 247.980581 Strafes: 7 Sync: 9
LJ Distance: 245.116653 Maxspeed: 328.961578 (72.007) Prestrafe: 256.954162 Strafes: 6 Sync: 8
LJ Distance: 253.573059 Maxspeed: 341.271728 (69.419) Prestrafe: 271.851867 Strafes: 7 Sync: 85 1 13.009 0.000 14.9 90 2 12.681 0.000 17.6 76 3 10.073 0.520 13.4 90 4 10.649 0.634 14.8 90 5 10.072 1.006 14.8 90 6 9.891 0.491 17.5 76 7 3.042 0.023
LJ Distance: 247.178787 Maxspeed: 332.540985 (70.504) Prestrafe: 262.036926 Strafes: 6 Sync: 8 *1 13.027 0.000 13.4 90 2 11.704 0.066 14.8 81 3 11.641 0.000 16.1 100 4 11.340 0.246 19.0 71 5 11.728 0.672 16.1 91 6 11.061 0.276 20.
LJ Distance: 249.074624 Maxspeed: 311.314788 (39.776) Prestrafe: 271.538330 Strafes: 3 Sync: 9
Distance: 247.965454 Maxspeed: 323.536621 (62.164) Prestrafe: 261.371734 Strafes: 7 Sync: 8
LJ Distance: 239.256698 Maxspeed: 308.673645 (58.714) Prestrafe: 249.959091 Strafes: 5 Sync: 7
Distance: 248.066467 Maxspeed: 317.859436 (53.993) Prestrafe: 263.866058 Strafes: 7 Sync: 8
LJ Distance: 245.172424 Maxspeed: 315.335388 (56.410) Prestrafe: 258.925323 Strafes: 5 Sync:
LJ Distance: 248.401550 Maxspeed: 317.957763 (52.863) Prestrafe: 264.994696 Strafes: 5 Sync: 8
看看好了,不是想炫耀什麼的,單純覺得很遺憾
发表于 2012-2-28 22:21:20 | 显示全部楼层
看的蛋疼...  没图啊?
遇到這種情況你會cap圖? 我看第一個反應是如何尋死吧-_-  详情 回复 发表于 2012-2-28 22:22
 楼主| 发表于 2012-2-28 22:22:58 | 显示全部楼层
Teffy 发表于 2012-2-28 22:21
看的蛋疼...  没图啊?
遇到這種情況你會cap圖?
我看第一個反應是如何尋死吧-_-
发表于 2012-2-28 22:23:49 | 显示全部楼层
那这比发数据图还无意义。
發這帖的意義本來就在於和你們分享遺憾而已 不是想炫耀什麼的 本質已經和數據圖不同  详情 回复 发表于 2012-2-28 22:26
 楼主| 发表于 2012-2-28 22:26:23 | 显示全部楼层
Teffy 发表于 2012-2-28 22:23
那这比发数据图还无意义。
不是想炫耀什麼的
本質已經和數據圖不同
发表于 2012-2-29 08:24:52 | 显示全部楼层
发表于 2012-2-29 14:14:15 | 显示全部楼层
不管是什么跳法  距离是最主要的  这和  同步  低速 空速 都有关系     特别是每次加速的同步和空速  不要球多 只要求每次的质量
空速是穩定的, 但這種強桿的空速,老實說,不常出,但每次都是pre不夠,和沒上成板子.  详情 回复 发表于 2012-2-29 20:16
发表于 2012-2-29 14:29:37 | 显示全部楼层
跳的什么板子,有冇遗憾
有的是250 有的是255 一次沒上板  详情 回复 发表于 2012-2-29 20:15
 楼主| 发表于 2012-2-29 20:15:25 | 显示全部楼层
beatifulpee 发表于 2012-2-29 14:29
跳的什么板子,有冇遗憾
有的是250 有的是255
一次沒上板
 楼主| 发表于 2012-2-29 20:16:13 | 显示全部楼层
ft119 发表于 2012-2-29 14:14
不管是什么跳法  距离是最主要的  这和  同步  低速 空速 都有关系     特别是每次加速的同步和空速  不要球 ...
空速是穩定的,
