查看: 4243|回复: 49
1月28日 被kayne暴过的各种人
发表于 2012-1-28 22:33:07 | 显示全部楼层 |阅读模式
Hello, jumpers.
Today, we come with a massive rollback of our demo section, centering on a bug found in one of the plugins used by some of you, uq_dcjstats.
To keep this post clean and informing, all extra information, including statements, have been moved to the extended section of this same post.
Kind Regards,
Vee & XJ Staff
koukouz
bkz_dusttemple done in 03:00.13 ( 02:59.62 kayne )
cg_brick done in 02:39.93 ( 02:38.05 kayne )
j2s_sandland done in 02:48.93 ( 02:47.32 kayne )
kz_goldenbean_200401 done in 03:57.85 ( 03:51.25 kayne )
zr_hetablock[easy] done in [url=http://xtreme-jumps.eu/check.php?filename=zr_hetablock[easy]_koukouz_0426.45.rar]04:26.45[/url] ( 04:20.97 kayne )
shNz
cg_coldbhop done in 00:25.83 ( 00:25.81 kayne )
clintmo_bhopwarehouse done in 00:21.07 ( 00:20.77 kayne )
kz_cargo done in 02:26.78 ( 02:26.26 kayne )
kz_ea_dam done in 02:54.18 ( 02:52.84 kayne )
risk_sector done in 01:08.52 ( 01:08.34 kayne )
KeltA
cg_cupiators done in 00:42.78 ( 00:42.42 kayne )
kz_goldwood done in 02:50.02 ( 02:48.11 kayne )
kz_j2s_nightcanyon done in 02:12.29 ( 02:10.47 kayne )
kz_j2s_summercliff_ez done in 02:03.52 ( 02:03.24 kayne )
kz_kzsca_sewerbhop done in 04:16.07 ( 04:12.60 kayne )
kz_kzse_towerblock done in 02:04.12 ( 02:03.66 kayne )
kz_luonto done in 03:28.95 ( 03:26.84 kayne )
kz_minimountain done in 01:21.96 ( 01:21.58 kayne )
kz_redbrickworld done in 02:44.54 ( 02:42.64 kayne )
kz_xj_3ways[easy] done in [url=http://xtreme-jumps.eu/check.php?filename=KZ_xj_3ways[easy]_KeltA_0506.70.rar]05:06.70[/url] ( 05:06.53 kayne )
kz_xj_mountez done in 01:15.07 ( 01:14.64 kayne )
rd_city_jump done in 03:40.99 ( 03:38.40 kayne )
puppetz
kz_adv_underground done in 06:56.78 ( 06:44.27 kayne, 06:56.62 HitMan )
plst
kz_cg_lavacliff done in 02:35.02 ( 02:32.52 kayne )
zhady
kz_cg_lost_castle done in 03:50.63 ( 03:47.97 kayne )
Cypek
kz_concise[easy] done in [url=http://xtreme-jumps.eu/check.php?filename=kz_concise[easy]_Cypek_0250.75.rar]02:50.75[/url] ( 02:49.19 kayne )
kz_man_castle done in 06:47.33 ( 06:45.72 kayne )
gizpo_O
kz_greattemple done in 04:19.46 ( 04:18.25 kayne )
kznl_factory done in 03:30.91 ( 03:28.36 kayne )
kzsca_bagdad done in 01:23.44 ( 01:22.76 kayne )
pizza^
kz_halicarnassus done in 02:46.99 ( 02:46.30 kayne )
chrizZo
kz_highlands done in 03:53.14 ( 03:49.03 kayne )
sKiCg
kz_kzdk_bridge2 done in 07:38.64 ( 07:29.89 kayne )
DeeDFTW
kz_kzsca_fjellheimen done in 05:19.41 ( 05:16.76 kayne )
omilo
kz_kzse_rockvalley done in 03:47:74 ( 03:42:48 omilo )
juanch0x
kz_toon_underground done in 03:41.44 ( 03:35.08 kayne )
kznl_mountainpass done in 01:42.50 ( 01:41.60 kayne )
kzru_spacehop done in 04:46.07 ( 04:42.94 kayne )
Dsnts
kzie_bunnyheaven done in 04:47.80 ( 04:47.16 kayne )
kunqui
kzro_darkfury done in 03:40.56 ( 03:34.82 kayne )
BAEVERN
kzru_sun5hine done in 01:22.46 ( 01:21.25 kayne )
Memories
kzsca_caseblock_v3_e done in 12:27.63 ( 12:08.83 kayne )
NeW
mto_lightblock done in 02:17.96 ( 02:17.81 kayne )
Chasquido
zr_minimountain done in 00:39.08 ( 00:38.75 kayne )
Additionally, two maps, kz_desolate3 and cosy_dustblock, have now no world record.
Read the extended news post for statements from the involved people and additional information.
At first, I ( Vee) would like to reiterate that this is not a cheat, but a bug in the mentioned plugin that makes the movement in CS go "wrong".
Also, if any legal demo has been removed, please feel free to re-submit it and I will gladly put it back on its place.
Important Note: We would like to remind you how important it is to keep your CS installation as close to the standard one as possible! When in doubt, use only XJ's official AMXX plugin!
Here, we have statement from eDark regarding this situation:
"The particular demos differ from the standard/default CS movement, which could be an advantage (but in some of the cases even a disadvantage). However, it is safe to say that they differ from the standard CS engine movement, which is why we have to remove these files."
发表于 2012-1-28 22:39:09 | 显示全部楼层
由于用了uq_dcj那个插件,demo的录制和cs标准引擎有偏差,所以要恢复这46个demo,XJ呼吁以后录制demo用官方amxx插件
发表于 2012-1-28 22:41:00 | 显示全部楼层
当然因为这样,kayne一夜回到解放前,跌出top5,不过以他的实力再录就是了,决心和时间的问题。
BB+1 其他人也不用胡乱猜测了~ 仔细看,被回滚的还有omilo和HitMan ,可不光只kayen一[/backcolor]人。。[/backcolor]  详情 回复 发表于 2012-1-28 23:38
发表于 2012-1-28 22:46:35 | 显示全部楼层
打开XJ 没看上面 直接看到kayne被爆菊 震惊了...
再一看上面 原来是回滚...
真悲情
参与人数 1金币 +2 收起 理由
愿意为您效劳 + 2 神马都是浮云,哈哈
发表于 2012-1-28 22:49:25 | 显示全部楼层
震惊了。。。。
发表于 2012-1-28 22:50:40 | 显示全部楼层
刚看到新闻的,还以为sk回归了...
美凌格+米兰球迷,撸过  详情 回复 发表于 2012-1-29 18:51
发表于 2012-1-28 23:38:48 | 显示全部楼层
BB+1
其他人也不用胡乱猜测了~  仔细看,被回滚的还有omilo和HitMan ,可不光只kayen一人。。
发表于 2012-1-28 23:49:50 | 显示全部楼层
我還以為kayne一下子被beat了45個wr,原來只是回復了
发表于 2012-1-29 00:21:40 | 显示全部楼层
震惊了。**
发表于 2012-1-29 01:27:00 | 显示全部楼层
我都不知道说什么好了
