查看: 960|回复: 2
[已解决] 大侠们,有木有转换第三人称视角的插件,求个
发表于 2011-8-17 20:38:31 | 显示全部楼层 |阅读模式
RT  不要KZ插件了,插件有了,就是单独的那种,谢谢了...
发表于 2011-9-8 22:20:35 | 显示全部楼层
  1. #include <amxmodx>
  2. #include <amxmisc>
  3. #include <engine>
  4. new view[32]
  5. public plugin_precache()
  6. precache_model("models/rpgrocket.mdl")
  7. public plugin_init() {
  8. register_plugin("Change View","v1.0","OneEyed")
  9. register_concmd("amx_view","changeView",ACCESS_TYPE,"Cycles through 4 different view types.")
  10. }
  11. public client_disconnect(id)
  12. view[id] = 1
  13. public client_connect(id)
  14. view[id] = 1
  15. public changeView(id,level,cid) {
  16. if ( !cmd_access(id,level,cid,0) )
  17. return PLUGIN_HANDLED
  18. new viewtype[32]
  19. if(view[id] > 3)
  20. view[id] = 0
  21. switch(view[id])
  22. {
  23. case 0: format(viewtype,31,"Normal")
  24. case 1: format(viewtype,31,"3rd Person")
  25. case 2: format(viewtype,31,"3rd Person (Up Left)")
  26. case 3: format(viewtype,31,"3rd Person (Top Down)")
  27. }
  28. client_print(id,print_chat,"Changing View to %s",viewtype)
  29. set_view(id, view[id])
  30. view[id]++
  31. return PLUGIN_HANDLED
  32. }
复制代码
bind f6 amx_view
咋用?我不会啊  详情 回复 发表于 2011-9-13 18:07
 楼主| 发表于 2011-9-13 18:07:00 | 显示全部楼层
SiMen.K. 发表于 2011-9-8 22:20
bind f6 amx_view
咋用?我不会啊{:soso_e127:}
