查看: 3153|回复: 22
[国际新闻] WR Release #573 - 16 New Demos
发表于 2011-6-9 19:34:30 | 显示全部楼层 |阅读模式
Playmate
cg_d2block_h done in 12:17.25 ( 15:43.26 Imb!k )牛逼的人~~~
pizza^
dr0_cliffside done in 01:52.89 ( 01:53.34 KeltA )
imao_darkcavern done in 02:26.61 ( 02:28.26 w1zz )
kz_man_congo_b01[-carpets] done in [url=http://xtreme-jumps.eu/check.php?filename=KZ_man_congo_b01[-carpets]_pizza^_0454.13.rar]04:54.13[/url] ( 05:01.80 pizza^ )
po_roboclimb done in 01:53.83 ( 01:55.11 omilo )
px_pharoah done in 01:56.82 ( 01:57.29 Flibo )
Cypek
kz_andy done in 04:34.97 ( 04:37.22 Cypek )
juanch0x
kz_brickfacility done in 06:07.08 ( 06:27.42 Dubstep )
demolation
kz_cg_nightcastle done in 05:45.01 ( 05:47.69 VNS )
SAMNY
kz_deserted done in 01:29.70 ( 01:39.46 akkord )
risk_inertia done in 01:38.55 ( 01:38.83 kunqui )
shNz  复出了???
kz_wsp_cavity done in 04:23.71 ( 04:27.69 koukouz )
nfs_longjumpez done in 00:24.97 ( 00:25.34 Chasquido )
risk_sector done in 01:08.52 ( 01:08.73 kayne )
CaBeZa
risk_crashed done in 02:12.58 ( 02:13.21 mgD )
sn_minivolcano done in 01:54.63 ( 01:56.67 Chasquido )
Read the extended news post for demos that were improved or didn't quite make it.
kz_man_congo_b01[-carpets]_Toffifee_0459.92.rar - Demo improved.
kz_man_congo_b01[-carpets]_pizza^_0456.52.rar - Demo improved.
kz_man_congo_b01[-carpets]_pizza^_0457.30.rar - Demo improved.
kz_man_congo_b01[-carpets]_pizza^_0458.79.rar - Demo improved.
 楼主| 发表于 2011-6-9 19:45:24 | 显示全部楼层
Playmate
cg_d2block_h done in 12:17.25 ( 15:43.26 Imb!k )       牛逼的人~~~牛逼的图。国内现在没人能裸掉!
乌克兰双子星之一。另一个是 Adantoud。两人的加速都很硬,爆红基本不在话下。 可以参考Adantoud的kzm_fineblock对于这ET难度的攀登图,Playmate全程跳得小心翼翼。没多少很耗时间的失误。特别是KKZ卡了N久的那个旋转点一次就过了。所以最终刷了3分多。Imb!k 就不提了,虽然刷了KKZ,但跳得实在太猥琐~      (顺带一提:会DCJ ——————— 挺好)
pizza^
pizza^应该是第一批KZ的老玩家,超级古董级KZer。这么多年都还不寂寞,搞得比Zhady还活跃。这图那么小,换些花样又能挤出些时间了。搞笑的是被刷的KeltA 还是旁观者。{:soso_e120:}估计应该心里郁闷了!
这图我叫它一根毛。而且还是昏暗洞穴图。个人不喜欢这类图。pizza^在图中多加了些许连跳点,就把 w1zz干掉了。
kz_man_congo_b01[-carpets] done in [url=http://xtreme-jumps.eu/check.php?filename=kz_man_congo_b01[-carpets]_pizza^_0454.13.rar]04:54.13[/url] ( 05:01.80 pizza^ )
这图的不走超级SC版DEMO已经很久没被动过了。即便走原路,也有个隐藏大捷径。pizza^自刷成功。
老图了,包含一个大捷径和一个超级大捷径。所以极大的压缩了刷图时间。2个老KZ玩家的对决。期待omilo反扑~~~~~~
97服里出现率比较高的地图。想要跳得快,滑坡就要掌握好。国内服务器里暂时还没见过把这鸟图刷进2分10秒内的。
Cypek
挺强的实力派选手,为何喜欢选择自慰?
juanch0x
冷门图。很难看见人刷。以juanch0x的名气和实力刷了20秒纯属正常。
demolation
火力集中图。不知道为什么,自从Iceman搞了这图后,这图就火了。这阵子在这图上杀得天昏地暗的。应该算是近十期换手率最高的图了。demolation来自马其顿。很虾米的小国也来XJ露下脸。
SAMNY
葡萄牙这货好久没出来了。?  几个捷径走的真好,连得很连贯。而且又有新捷径来着。值得观看。
我一直认为这图算娱乐图。跟跑酷类似。有兴趣的可以试下。
shNz
shNz终于出现了。选择下手的既然是KKZ的攀登图。整张图跳得非常炫。有几串限制级的连跳。中间还是夹着些小失误。细节处理上比KKZ还是差些。但shNz的DEMO观赏性依然很高~~~
这个没啥说的。用了3个连跳过台子~
....................在大家技巧都差不多的情况下,这图基本就比扔枪**了。
CaBeZa
阿根廷新星?以前没见过。但能刷mgD和Chasquido两个强人,确实魄力非凡。mgD这图才稳了一期就被这小子废了。CaBeZa有点意思. 希望他能继承昆曲和插死quido的辉煌。
连得真疯。这种微缩岩浆图都可以刷2秒。想当年Skicg刷这图时,我认为当时那时间几乎接近极限。翻来覆去被刷过N回后,时间又缩短了好几秒。{:soso__9865860790811885532_3:}
参与人数 5金币 +40 +40 收起 理由
liaoyp089 + 5 + 5 点评文章,多多益善啊
SiMen.Apple + 9 + 9 精品文章
老_鼠 + 1 + 1 辛苦了!顶一个
SiMen.Ctrl + 20 + 20 精品文章
maRisa + 5 + 5 精品文章
发表于 2011-6-9 19:47:06 | 显示全部楼层
cg_d2block_h 太...
发表于 2011-6-9 19:52:05 | 显示全部楼层
cg_d2block_h这图太大了把。。。。无奈·
发表于 2011-6-9 20:10:16 | 显示全部楼层
看完第一个demo我觉得这辈子都不想挑战那图
发表于 2011-6-9 22:17:48 | 显示全部楼层
回复 dragonsandy 的帖子
貌似adantoud不能轻而易举爆红吧,他的LJ数据不漂亮,但是硬加速确实叼!
 楼主| 发表于 2011-6-10 01:13:06 | 显示全部楼层
lambqwe 发表于 2011-6-9 22:17
回复 dragonsandy 的帖子
我不清楚adantoud刷图爆红的概率多大。但以前在XJ论坛里见过他一个跳板子的DEMO,只有几M。247板,跳了13次。红了8次。我觉得这爆红率也算比较大的了。当然不能和XJ排行榜上那些牛人比。特别是freestyler这货的LJ练习DEMO。在250板子上,几乎就没掉过。稳定在255左右。那才叫拉风~~~~
发表于 2011-6-10 08:03:59 | 显示全部楼层
shNz闭关这么久是在苦练攀岩么,爆掉了KKZ,一定要看
发表于 2011-6-10 08:15:06 | 显示全部楼层
shNz
v5
发表于 2011-6-10 08:25:46 | 显示全部楼层
Playmate最后失误频频,可能太兴奋了吧!
