查看: 706|回复: 3
[已解决] 求个超级跳插件啊!
发表于 2011-2-25 22:03:52 | 显示全部楼层 |阅读模式
谁有超级跳插件啊,就是越跳越快的那种~
发表于 2011-2-25 23:52:18 | 显示全部楼层
你去下CS1.5以前的版本就可以了啊
或者去axn地图!
发表于 2011-2-26 11:00:58 | 显示全部楼层
This plugin removes the slow down you get after jumping in Counter-Strike.
A cool new feature. Simply hold down jump and you will bunny hop automatically. You can get up some serious speed. Unfortunately client prediction is a bit messed up because it doesn't expect you to be going so fast.
Cvars:
bh_enabled 1/0
Enable/disable the plugin.
bh_autojump 1/0
Enable/disable no skill required bunny hopping. (Just hold jump to bunny hop!)
bh_showusage 1/0
Enable/disable a small message to players when they connect informing them of the Bunny Hopping feature.
bunnyhop.sma (2.29 KB, 下载次数: 9)
 楼主| 发表于 2011-2-26 20:41:11 | 显示全部楼层
回复 SiMen.K. 的帖子
怎么用啊? 具体点呗- - 我菜鸟
