查看: 4246|回复: 13
[已解决] MCJ的插件
发表于 2011-2-4 18:10:26 | 显示全部楼层 |阅读模式
請問誰有顯示MCJ的插件啊?????
发表于 2011-2-4 18:22:21 | 显示全部楼层
JumpStats by [kzuq]BorJomi
version 2.29
Hi everyone! As you might know, in the Kreedz world two stats plugin are dominating, Jumpstats by Exolent and Long Jump Stats - eXtreme Modification by Numb. Both have their advantages and disadvantages, that's why I've just decided to do something mean in my plugin, whether I have succeeded? Time will tell). The starting point that I used was the original kz_stats by SchlumPF, modded by xPaw, but beyond that, I just borrowed some parts of the code from those LJ Stats - eXtreme Modification and Jumpstats, for which I express my special thanks to their developers.
Todo: Fix fu..ks bugs),
Cvar's ( in « » default values)
1. What should work when players connect to the server (0 = none, a = colorchat, b = stats, c = speed, d = showpre, e = strafe stats, f = beam, g = duck stats for mcj, h = shows message when your bhop prestrafe is failed,i=show multibhop pre,j= show prestrafe after duck, k=show lj prestrafe))
kz_uq_connect «abdehk»
1.1 For what team stats enable (0=all team,1=T,2=CT)
kz_uq_team «0»
2. Allow highlighting after landing (1 = on, 0 = off; works for holy, leet and god distances)
kz_uq_light «0»
3. Allow sounds (1 = on, 0 = off)
kz_uq_sounds «1»
4. How to save Top10 (2 = steamid, 1 = Ip, 0 = name)
kz_uq_top_by «1»
kz_uq_save_top «1» - On/Off TOP10 (1 = on, 0 = off)
kz_uq_maptop «1» - On/Off MapTop (1 = on, 0 = off)
5. Allow check to legal settings (1 = on, 0 = off)
а) kz_uq_legal_settings «1»
б) kz_uq_fps «0»
(1=more than 101 FPS jump does not count, 0= counts)
6. The prefix for all messages in chat
kz_uq_prefix «unique-kz»
7. How to set up a server by value sv_airaccelerate (0=10aa, 1=100aa)
kz_uq_airaccelerate «0»
8. Color Hud message statistics when you jump, in the RGB
kz_uq_stats_red «0»
kz_uq_stats_green «255»
kz_uq_stats_blue «159»
9. Color Hud messages Fail statistics when you jump, in the RGB
kz_uq_failstats_red «255»
kz_uq_failstats_green «0»
kz_uq_failstats_blue «109»
10. Color Hud messages prestrafe, in the RGB
kz_uq_prestrafe_red «255»
kz_uq_prestrafe_green «255»
kz_uq_prestrafe_blue «255»
11. Color of speed, in the RGB
kz_uq_speed_red «255»
kz_uq_speed_green «255»
kz_uq_speed_blue «255»
12. Coordinates Hud messages
a) General stats jump
kz_uq_stats_x «-1.0»
kz_uq_stats_y «0.70»
b) Strafes Stats
kz_uq_strafe_x «0.70»
kz_uq_strafe_y «0.35»
c) Ducks Stats for Multi CountJump
kz_uq_duck_x «0.6»
kz_uq_duck_y «0.78»
d) For speed
kz_uq_speed_x «-1.0»
kz_uq_speed_y «0.83»
e) for prestrafe
kz_uq_prestrafe_x «-1.0»
kz_uq_prestrafe_y «0.65»
13. Channels Hud messages
kz_uq_hud_stats «3»
b) Strafes Stats
kz_uq_hud_strafe «4»
kz_uq_hud_duck «1»
d) For speed
kz_uq_hud_speed «2»
e) For prestafe
kz_uq_hud_pre «1»
14. Color of chat messages of distance jump (good = grey, pro = green, holy = blue, leet = red, god = red (with sound godlike for all players))
a) LongJump/HighJump
kz_uq_good_lj «240»
kz_uq_pro_lj «245»
kz_uq_holy_lj «250»
kz_uq_leet_lj «253»
kz_uq_god_lj «255»
b) CountJump
kz_uq_good_cj «250»
kz_uq_pro_cj «255»
kz_uq_holy_cj «260»
kz_uq_leet_cj «265»
kz_uq_god_cj «267»
c) Double CountJump/Multi CountJump
kz_uq_good_dcj «250»
kz_uq_pro_dcj «255»
kz_uq_holy_dcj «260»
kz_uq_leet_dcj «265»
kz_uq_god_dcj «270»
d) LadderJump
kz_uq_good_ladder «150»
kz_uq_pro_ladder «160»
kz_uq_holy_ladder «170»
kz_uq_leet_ladder «180»
kz_uq_god_ladder «190»
e) BhopJump/StandUp BhopJump
kz_uq_good_bj «230»
kz_uq_pro_bj «235»
kz_uq_holy_bj «240»
kz_uq_leet_bj «245»
kz_uq_god_bj «247»
f) WeirdJump/Drop CountJump/Ladder BhopJump
kz_uq_good_wj «255»
kz_uq_pro_wj «260»
kz_uq_holy_wj «265»
kz_uq_leet_wj «270»
kz_uq_god_wj «272»
g) Drop BhopJump/Drop StandUp BhopJump
kz_uq_good_dbj «240»
kz_uq_pro_dbj «250»
kz_uq_holy_dbj «265»
kz_uq_leet_dbj «270»
kz_uq_god_dbj «272»
h)StandUp CountJump(if 100aa all cvar dist +15 units)
kz_uq_good_scj «240»
kz_uq_pro_scj «245»
kz_uq_holy_scj «250»
kz_uq_leet_scj «255»
kz_uq_god_scj «257»
15. on/off each technique
kz_uq_lj «1»
kz_uq_cj «1»
kz_uq_bj «1»
kz_uq_sbj «1»
kz_uq_wj «1»
kz_uq_dcj «1»
kz_uq_mcj «1»
kz_uq_drbj «1»
kz_uq_scj «1»
kz_uq_drcj «1»
kz_uq_ladder «1»
kz_uq_ldbj «1»
16. Minimum jump distance (except LadderJump)
kz_uq_min_dist «215»
kz_uq_max_dist «290»
Players commands
say /strafes – on/off statistics Strafes
say /showpre –on/off display prestrafe
say /ducks –on/off statistics ducks for multi cj
say /ljstats –on/off the main statistics
say /uqversion – show version
say /beam – on/off showing the trajectory of the jump
say /speed –on/off display of speed player
say /colorchat –on/off display of color in the chat messages from other players
say /ljsmenu – open the configuration menu
say /ljtop – open TOP10 menu
say /bhopwarn -on/off show message when you bhop prestrafe is fail
say /multibhop - on/off show multi bhop pre
say /duckspre - on/off display prestrafe after each duck
say /ljpre - on/off display prestrafe for LJ
Admin command
amx_reset_uqtops – reset all tops
amx_uq_default_cvars - set all cvars to default values
Credits
SchlumPF, xPaw, Exolent, Fatalis, Numb, Lt.RAT
Visit
http://unique-kz.com
http://cs.n-sib.net
http://extreme-jump.ru
http://xtreme-jumps.eu
download
mirror
 楼主| 发表于 2011-2-4 18:35:13 | 显示全部楼层
有顯示mcj的嗎?
 楼主| 发表于 2011-2-4 18:35:35 | 显示全部楼层
這是最重要...
 楼主| 发表于 2011-2-4 18:36:21 | 显示全部楼层
這文件請問放在那?
发表于 2011-2-4 19:58:53 | 显示全部楼层
回复 SiMen.K. 的帖子
楼主杯具啊,连插件都不会装
K先教教他吧...
发表于 2011-2-4 21:17:07 | 显示全部楼层
{:soso__7531349777799091101_1:}不是吧,会MCJ竟然不会装插件。。不会跳的表示兰州烧饼了的撸过
发表于 2011-2-4 22:45:58 | 显示全部楼层
这插件是做什么用的???
发表于 2011-2-4 22:46:05 | 显示全部楼层
这插件是做什么用的???
发表于 2011-2-4 23:40:28 | 显示全部楼层
这插件都是用烧饼做的,!
