查看: 1306|回复: 12
【XJ】 New real time events
发表于 2011-1-4 15:18:19 | 显示全部楼层 |阅读模式
Some months ago the hard/extreme league was stopped, but since it had a great resonance from the community I thought it is time to restart the project. Our goal is once again to implement an alternative to the record business, but this time we will probably not only run an improved league, we will also organize other events.
Update: Check this forum thread to see all information about the current tournament.
XJ Tournament server hosted by  KraXXXel: 217.79.189.113:27022
Official HLTV hosted by insilio.org: 78.47.209.67:27020
Join the tournament steam group to receive announcements when a match starts!
I wrote down all necessary information you need to know about the future real time events in XJ's forum.
Read through these threads if you want to understand how the system works. If you have any questions about it, please ask them into the related thread.
Since this newspost is not just about theory I want to announce the first tournament now!
First tournament
It will be an 8 slot tournament which will start at the latest on Friday. Every match needs to be played within 3 days and that means the tournament will be finished on 16th January or earlier. So if you apply make sure you can play within this time and that you read the rules! Use the comments of this newspost for your application!
This time we will not have a certain choice of maps, all maps are into the mappool. The server and hltv IP will be published later.
Hopefully you like the renaissance of real time events! Feedback and critics are welcome, thanks in advance!
英文帝来把
 楼主| 发表于 2011-1-4 15:19:41 | 显示全部楼层
谷歌大哥给的翻译没几人人能懂
几个月前硬/极端联赛停下来了,但因为它有一个伟大的共振社会我想是时候重新启动这个项目。我们的目标是实现又一次记录可替代的业务,但这次我们将很有可能不会只运行一种改进的联赛,我们也可以组织其他事件。
更新:检查这个论坛线程看到所有有关当前的比赛。
XJ KraXXXel:主办的比赛217.79.189.113:27022服务器
官方HLTV insilio.org:78.47.209.67:27020主办
参加比赛一汽集团接受公告当比赛开始!
我写下所有必要的信息,你需要了解未来事件的XJ实时论坛。
浏览这些螺纹如果你想了解系统是如何工作的。如果你有任何问题,请他们到相关的线。
因为这newspost不仅仅是理论我想宣布的第一次比赛,现在!
第一场比赛
这将是一个8槽锦标赛,将开始在最新的在星期五。需要每一场比赛了,这就意味着三天内完成比赛将在1月16日或更早的。因此,如果你的运用使你当然可以在比赛,你读过这个时候,规则啊!使用注释您的应用程序newspost !
这次我们不会有一定的选择的地图,地图进入mappool。服务器和IP将hltv稍后被公布。
希望你喜欢文艺复兴的实时活动!反馈和评论家是受欢迎的,谢谢!
发表于 2011-1-4 15:22:37 | 显示全部楼层
来个人编辑下吧,看得我快疯了
发表于 2011-1-4 15:34:24 | 显示全部楼层
几个月前,硬/极端联赛被停止使用,但由于它是从社会上我觉得现在是时候重新启动该项目的很大的共鸣。我们的目标是再次实施替代唱片业,但这次我们大概不会只运行一个改进的联赛,我们还将组织其他活动。
更新:检查这个论坛线程看到所有有关当前赛事信息。
许继锦标赛主办KraXXXel服务器:217.79.189.113:27022
官方的HLTV主办insilio.org:78.47.209.67:27020
参加比赛的汽集团收到通知时,比赛开始!
我写下了所有必要的信息,你需要知道未来的XJ的论坛实时事件。
通过阅读这些线程,如果你想了解系统如何工作。如果您有关于它的任何问题,请把相关的线程。
由于这newspost不只是理论我要宣布第一场比赛吧!
第一场比赛
这将是一个8插槽的比赛将在周五开始的最新。每场比赛必须在3日内起,这意味着该赛事将于1月16日或之前完成。所以,如果你申请请务必在这段时间内可以发挥,而且你读了规则!使用此为您的应用newspost的意见!
这一次,我们将不会有地图的必然选择,所有的地图都将mappool。服务器和的HLTV IP将稍后公布。
希望你喜欢的实时事件的复兴!欢迎反馈和批评,在此先感谢!
 楼主| 发表于 2011-1-4 15:40:32 | 显示全部楼层
回复 4# 395274783
    和谷歌大哥的差不多
    9 小时前
  • 签到天数: 540 天
    [LV.9]以坛为家II
    发表于 2011-1-4 15:48:08 | 显示全部楼层
    有的看咯,好戏即将上演
    发表于 2011-1-4 15:50:56 | 显示全部楼层
    终于快可以看现场直播了
    发表于 2011-1-4 15:51:21 | 显示全部楼层
    昨晚晚自修逛XJ,无聊跟同学已经翻译了一遍了…
    发表于 2011-1-4 17:06:22 | 显示全部楼层
    LS求答案
    发表于 2011-1-4 17:36:58 | 显示全部楼层
    求翻译,看着蛋疼
