查看: 2102|回复: 10
【分享】 7-Zip 9.20 稳定版 承诺爱最终汉化版
发表于 2010-12-29 01:02:56 | 显示全部楼层 |阅读模式
Welcome to the 7-Zip Home!
7-Zip is a file archiver with a high compression ratio.
Download 7-Zip 9.20 (2010-11-18) for Windows:
LinkTypeWindowsSize
Download.exe32-bit x861 MB
Download.msi64-bit x641 MB
The download links above redirect you to download pages on SourceForge.net
License
7-Zip is open source software. Most of the source code is under the GNU LGPL license. The unRAR code is under a mixed license: GNU LGPL + unRAR restrictions. Check license information here: 7-Zip license.
You can use 7-Zip on any computer, including a computer in a commercial organization. You don't need to register or pay for 7-Zip.The main features of 7-Zip
  • High compression ratio in 7z format with LZMA and LZMA2 compression
  • Supported formats:
    • Packing / unpacking: 7z, XZ, BZIP2, GZIP, TAR, ZIP and WIM
    • Unpacking only: ARJ, CAB, CHM, CPIO, CramFS, DEB, DMG, FAT, HFS, ISO, LZH, LZMA, MBR, MSI, NSIS, NTFS, RAR, RPM, SquashFS, UDF, VHD, WIM, XAR and Z.
  • For ZIP and GZIP formats, 7-Zip provides a compression ratio that is 2-10 % better than the ratio provided by PKZip and WinZip
  • Strong AES-256 encryption in 7z and ZIP formats
  • Self-extracting capability for 7z format
  • Integration with Windows Shell
  • Powerful File Manager
  • Powerful command line version
  • Plugin for FAR Manager
  • Localizations for 79 languages
7-Zip works in Windows 7 / Vista / XP / 2008 / 2003 / 2000 / NT / ME / 98. There is a port of the command line version to Linux/Unix.
汉化后软件部分截图:
源文件为官方版本   破解后只做汉化 无任何后门    无加密加壳 方便自行检测
官方地址:http://www.7-zip.org/
下载地址: Download
发表于 2010-12-29 01:11:11 | 显示全部楼层
比起  WINRAR  和   好压   怎么样??
 楼主| 发表于 2010-12-29 01:18:20 | 显示全部楼层
回复 2# 395274783
    美不胜收
 楼主| 发表于 2010-12-29 01:20:24 | 显示全部楼层
译文:
欢迎来到 7-Zip 官方授权中文首页!
7-Zip 是一款拥有极高压缩比的开源压缩软件。
下载 7-Zip 9.20 稳定版 (2010-11-18) for Windows:
链接格式系统大小
下载.exe32 位1 MB
下载.msi64 位1 MB
上述下载链接将会转至 SourceForge.net
中文版附加内容 (2010-11-19),适用于 9.20:
包含:安装包模块、FAR 插件、中文自述、历史更新、帮助文件
链接格式系统大小
下载.7z32/64 位700 KB
上述下载链接将会转至 googlecode.com许可协议
7-Zip 是一款 开源 软件。大多数源代码都基于 GNU LGPL 许可协议下发布。AES 代码基于 BSD 许可下发布。unRAR 代码基于两种许可:GNU LGPL 和 unRAR 限制许可。更多下许可信息请查看:7-Zip 许可
您可以在任何一台计算机上使用 7-Zip ,包括用在商业用途的计算机,不对 7-Zip 进行捐赠或支付并不影响您的使用。7-Zip 主要特征
  • 全新的 LZMA 算法加大了 7z 格式 的压缩比
  • 支持格式:
    • 压缩 / 解压缩:7z, XZ, BZIP2, GZIP, TAR, ZIP
    • 仅解压缩:ARJ, CAB, CHM, CPIO, CramFS, DEB, DMG, FAT, HFS, ISO, LZH, LZMA, MBR, MSI, NSIS, NTFS, RAR, RPM, SquashFS, UDF, VHD, WIM, XAR, Z
  • 对于 ZIP 及 GZIP 格式,7-Zip 能提供比使用 PKZip 及 WinZip 高 2-10% 的压缩比
  • 为 7z 与 ZIP 提供更完善的 AES-256 加密算法
  • 7z 格式支持创建自释放(SFX)压缩档案
  • 集成 Windows 外壳扩展
  • 强大的的文件管理
  • 强大的命令行版本
  • 支持 FAR Manager 插件
  • 支持 79 种语言
7-Zip 适用于 95/98/ME/NT/2000/2003/XP/Vista/7。7-Zip 并且有面向 Linux、Unix 平台的命令行版本。
发表于 2010-12-29 01:39:42 | 显示全部楼层
我懂了~~~~~~~
发表于 2010-12-29 01:41:37 | 显示全部楼层
似乎1年前我就发过汉化过的7z
发表于 2010-12-29 02:13:56 | 显示全部楼层
完全看不懂啊。K姐。
怎么这几天HNS老是挂着的
发表于 2010-12-29 09:34:05 | 显示全部楼层
这,这玩意还用破解?
 楼主| 发表于 2010-12-29 09:42:03 | 显示全部楼层
回复 8# MaMaMiYa
   汉化就属于破解    一种非法手段
但必须注释说明作者以及官网
 楼主| 发表于 2010-12-29 09:49:25 | 显示全部楼层
回复 6# wzq5417601
    官方一直在更新 当前版本7-Zip 9.20 (2010-11-18更新的)  32位 86
过去是过去现在是现在  过去不等于现在
