查看: 1166|回复: 6
【已解决】 求滑坡服的C4计时器插件
发表于 2010-10-16 10:05:23 | 显示全部楼层 |阅读模式
就是酷克那个滑坡服,有些地图没计时器,就是用那个C4计时器的…
好希望得到啊!
发表于 2010-10-16 10:23:02 | 显示全部楼层
LZ,你就是R.u!-2 是不是你?  昨天在HNS里看到你了,<MAP>是不是。
 楼主| 发表于 2010-10-16 10:33:42 | 显示全部楼层
回复 2# Jc.ppx
    额…我的ID就没换过,难道你第一次见到我?
发表于 2010-10-16 10:40:26 | 显示全部楼层
回复 3# honwenle
    第一次看到,好菜、呵呵
 楼主| 发表于 2010-10-16 10:53:28 | 显示全部楼层
回复 4# Jc.ppx
    原先技术就菜还是在网吧…最不会玩的就是HNS了,每次玩都要被笑,所以玩一下子就没敢玩了,每次都这样所以一直玩不好。你要不要教教我啊…
发表于 2010-10-16 12:49:55 | 显示全部楼层
发表于 2010-10-17 11:46:43 | 显示全部楼层
Plugins Info:
Well, I friend tell me that he want a Top15 for his Kz Server. So I start a new kz plugin that many persons request. So now I create this plugin with many funccions for adapt any type of plugin with this.
You can Test the Plugin in Our Servers: cs.kz-arg.com.ar:27015
Commands: the prefix of all this commands are ( "say /", "say .", "/", ".", "say_team /", "say_team .",)
Quote:
  • cp, checkpoint, check
  • tele, gc, gocheck, tp
  • stuck, unstuck
  • reset
  • pause, unpause
  • start
  • showtime
  • vip, vips, admin, admins
  • menu
  • c4start
  • weapons
  • scout
  • showkeys
  • showspeckeys
  • setstart
Lasts Changes:
  • Corrects Some errors & add some stock... Thanks Hawk
In Next Version:
  • kz_say Special kz say
  • Admin Menu
  • Help MotD
  • Add Measure
  • An more Sorprises.
ToDo:
  • Fix /Scout that remove you the USP & KNIFE
  • Fix the Top15 Sql, Not Finish.
  • Fix kz_get_plugin_version
ChangeLog:
Quote:
-> 1.7 Beta
Add ML Support
/setstart, Now the start save with the first touch and the admin can change
Fix some C4 Problems and add new Move Menu
News ML Support
Fix prints natives
Correct some others texts Problems
sma Download
-link-
参与人数 1金币 +3 收起 理由
honwenle + 3 爱死你了
