查看: 1791|回复: 3
【已解决】 Simen.K.进来看下,ProKreedz_v2.3.sma插件编译问题
发表于 2010-10-16 00:37:51 | 显示全部楼层 |阅读模式
如题
ProKreedz_v2.3.amxx插件排名问题,只能steam玩家可以,如果不是steam的用户,就只能记录主机的排名!去xj看了下,说加入如图的代码就行了,
可是按位子加好代码后,一编译就出现一个错误
如编译图 。模块我都开了,就是不知道是哪的原因,K哥给看下嘛,舍身家给你加分!
发表于 2010-10-16 01:05:18 | 显示全部楼层
得了 你用这个吧
ProKreedz v2.0
(Normal & SQL Top versions)
by nucLeaR
Current Version: 2.0y - 13.10.2010
CVars:
- kz_checkpoints <0/1> - Allows Checkpoints creation
- kz_godmode <0/1> - GodMode Disabled / Enabled
- kz_cheatdetect <0/1> - Detects usage of noclip,hook and so to reset time
- kz_spawn_mainmenu <0/1> - Brings up Main Menu when player spawns
- kz_show_timer <0/1> - Shows timer on HUD (mm:ss)
- kz_chatorhud <0/1/2> - For CP, GC messages. 2 for HUD, 1for chat, 0 for none
- kz_hud_color <r g b> - red , green , blue with values <0-255>
- kz_other_weapons <0/1> - Allow /weapon command to spawn all the weapons
- kz_hook_prize <0/1> - Gives hook to each player that finishs the map
- kz_hook_sound <0/1> - Enables or disables the hook sound
- kz_hook_speed <speed> - Sets the hook speed. Default: 300.0
- kz_drop_weapons <0/1> - Allows players to drop weapons
- kz_remove_drops <0/1> - Remove dropped items (to avoid abusing/cheating)
- kz_use_radio <0/1> - Allows players to use radio
- kz_nvg <0/1> - Allows players to use Night Vision
- kz_nvg_colors <r g b> - red , green , blue - For Night Vision color
- kz_pause <0/1> - Allows players to use pauses during a climb
- kz_vip <0/1> - Either show or not VIP tag for admins in showscores
- kz_showkeys <0/1> - Enable or not the possibility you can see your keys and/or the players' you are spectating
- kz_semiclip <0/1> - Enable or not the semiclip (not only transparency)
- kz_respawn_ct <0/1> - Respawns CTs if they die
- kz_strip_other_weapons <0/1> - Strips or not different than USP and Knife when starting the time
- kz_spec_saves <0/1> - Saves the location where the player goes spec (and moves to it when you go CT again) and pauses your time (if it's started)
- kz_save_autostart <0/1> - Saves the last location when a player started his time and teleports him to that exact spot when he's typing /start
- kz_showtime_start <0/1/2> - Sets the start-up showtime method ( 0-Disabled ,1- HUD ,2-RoundTime). You can change it ingame by command /timer.
SQL Top CVars: (Add those CVars into kreedz.cfg for prokreedz_sql)
- kz_sql_host "IP of the host"
- kz_sql_file "IP of the domain you have the php files on (usually same with host IP)
- kz_sql_user "username"
- kz_sql_pass "password"
- kz_sql_db = "DB name"
- kz_sql_name = "Server Name"
Installation of SQL Version
Copy the CVars above in kreedz.cfg
- Make a DB called top15 (or the name you put for kz_sql_db)
- Download and put the PHP files into your webserver
- Open the PHP files and complete with username & password where needed
PS:
You can only use KZ-Arg's Pro15 SQL. If you want to use the old top, delete kz_nub15.
Players commands:
- /cp, /checkpoint - Creates a Checkpoint
- /tp, /teleport, /gc , /gocheck - Teleports you to the last Checkpoint
- /stuck, /unstuck - Teleports you to the last but not last Checkpoint\
- /top15, /pro15, /nub15 - Opens up Top15 menu(for first) or the respective top
- /reset - Resets time/checkpoints/gochecks
- /start - Moves you to start position
- /menu, /kz - Opens KZ Menu (Main menu)
- /ct, /spec - Moves you to spectator respective CT
- /pause - Pauses your time, only if the timer is started
- /weapons - Gives you other weapons, only if the timer is not started
- /scout, /usp, /knife - Gives you scout/usp&knife (works if the timer is enabled too!)
- /timer - Enables/Disables the HUD Timer
- /invis,/winvis,/pinivis - First opens Invis menu, seconds makes water invisible, third makes only players invisible
- /noclip - Gives you noclip and resets your time
Admins commands:
- /public, /pub - Loads Kreedz.cfg
- /setstart - Sets (or changes if it already exists) the start position
- /delstart - Deletes the start position
If you want to record demos, you must use prokreedz_demo plugin (included in archive).
- /demo or /legal to set up legal settings (only CVars for prokreedz plugin, not mpbhop or others)
- /pub or /public- executes kreedz.cfg (if it doesn't exist it loads the CVars directly)
参与人数 2金币 +6 +6 收起 理由
T!g3r + 3 + 3 强大
badmonkey + 3 + 3 K ,泄了!
发表于 2010-10-16 12:39:19 | 显示全部楼层
 楼主| 发表于 2010-10-17 01:23:25 | 显示全部楼层
回复 2# SiMen.K.
    泄了。k,我拿你给的那个汉化成功了。加分绝对给你!
