查看: 974|回复: 6
【已解决】求汉化的KZ计时主插件{要带存读点的最好是汉化的}
发表于 2010-10-16 00:36:53 | 显示全部楼层 |阅读模式
Rt
想整合一套数据库保存的
求带码  高清
发表于 2010-10-16 00:45:39 | 显示全部楼层
你单机玩还是服务器?我搞了个英文的,弄了下,单机还不错,服务器排名有问题,正在解决。要的话给你!
发表于 2010-10-16 00:49:02 | 显示全部楼层
LZ经常夜间活动啊
 楼主| 发表于 2010-10-16 01:03:12 | 显示全部楼层
写数据库肯定是网络了
英文的也行打包丢上来
那个东西很简单
因为我是整合注册了所以不担心
我是用注册的UID来保存的
 楼主| 发表于 2010-10-16 01:04:42 | 显示全部楼层
回复 3# honwenle
    白天压力大
而且我电脑背对太阳
白天做电脑前 正对太阳光刺眼啊
发表于 2010-10-16 01:19:36 | 显示全部楼层
回复 5# lovehuai
    好理由啊…你个夜猫…
发表于 2010-10-17 10:55:18 | 显示全部楼层
Climb v2.0a3
6/21/2007
You can get nightly builds, change logs, cvars and requirement list as well as a donation link to support this project on my site at:
http://ian.cammarata.us/projects/climb
Description:
This plugin is designed for use in kz / climbing maps like those available from www.kreedz.com. Maps also available at http://xtreme-jumps.eu and http://1337bunnies.com.
See it in Action:
Use the following link to find a server that's running this plugin:
http://www.game-monitor.com/search.p...ll&country=all
Features:
Checkpoints
Individual Timers - Displayed using HUD round timer
Semi-clip
Boosts - 3 types
High scores ( SQLite / MySQL 4.1 or higher)
Bot - Prevents round from ending.
Spectator mode - See timer and messages of client you're spectating
Rewards System - Customizable with an ini file.
Flashlight - Replaces normal flashlight and NVG.
Auto Heal - Adapts to each map to make the experience as close to normal as possible.
Tons of other little odds and ends.
Commands:
A full set of help pages can be found at:
http://ian.cammarata.us/projects/cli...a3/en/commands
These pages are also available in game by using the chat command /climbhelp.
Notes:
I highly recommend using All Chat along with this plugin:
http://forums.alliedmods.net/showthread.php?t=56825
DF Hook Frontend plugin is included with this plugin, but still requires the Hookmod from AdminOP:
http://www.adminop.net/modules.php?n...ok_Mod_Windows
WebMod has a critical security flaw, and I can no longer recommend that anyone use it. The nightly build 2.0a3.4.20 has optimized html for the scoreboard and no longer needs WebMod to get a full listing. I recommend that everyone uninstall WebMod as soon as possible, this security flaw allows people to very easily crash your server, and with sufficient knowledge, they can even take control of the system on which your game server is running.
Credits:
Borrowed some code from Space Headed's bot_api.sma
sma  download
https://forums.alliedmods.net/showthread.php?t=56826
__________________
My Plugins: All Chat | SpecInfo | Grab+ | MP Bhops | DMG Doors |
