查看: 11672|回复: 15
最新LJ插件uq_jumpstats 2.12 显示任何数据
发表于 2010-10-15 23:49:43 | 显示全部楼层 |阅读模式
JumpStats by [KZuq]BorJomi
version 2.12
Hi everyone! As you might know, in the Kreedz world two stats plugin are dominating, Jumpstats by Exolent and Long Jump Stats - eXtreme Modification by Numb. Both have their advantages and disadvantages, that's why I've just decided to do something mean in my plugin, whether I have succeeded? Time will tell). The starting point that I used was the original kz_stats by SchlumPF, modded by xPaw, but beyond that, I just borrowed some parts of the code from those LJ Stats - eXtreme Modification and Jumpstats, for which I express my special thanks to their developers.
Todo: Fix fu..ks bugs),
Cvar's ( in
default values)
1. What should work when players connect to the server (0 = none, a = colorchat, b = stats, c = speed, d = showpre, e = strafe stats, f = beam, g = duck stats for mcj, h = shows message when your bhop prestrafe is failed,i=show multibhop pre,j= show prestrafe after duck, k=show lj prestrafe))
kz_uq_connect
abdehk
1.1
For what team stats enable (0=all team,1=T,2=CT)
kz_uq_team
Allow highlighting after landing (1 = on, 0 = off; works for holy, leet and god distances)
kz_uq_light
3. Allow sounds (1 = on, 0 = off)
kz_uq_sounds
How to save Top10 (2 = steamid, 1 = Ip, 0 = name)
kz_uq_top_by
kz_uq_save_top
1 - On/Off TOP10 (1 = on, 0 = off)
kz_uq_maptop
1 - On/Off MapTop (1 = on, 0 = off)
5.
Allow check to legal settings (1 = on, 0 = off)
а) kz_uq_legal_settings 1
б) kz_uq_fps 0
(1=more than 101 FPS jump does not count, 0= counts)
6.
The prefix for all messages in chat
kz_uq_prefix
unique-kz
7.
How to set up a server by value sv_airaccelerate (0=10aa, 1=100aa)
kz_uq_airaccelerate
8. Color Hud message statistics when you jump, in the RGB
kz_uq_stats_red
kz_uq_stats_green
255
kz_uq_stats_blue
159
9.
Color Hud messages Fail statistics when you jump, in the RGB
kz_uq_failstats_red
255
kz_uq_failstats_green
kz_uq_failstats_blue
109
10.
Color Hud messages prestrafe, in the RGB
kz_uq_prestrafe_red
255
kz_uq_prestrafe_green
255
kz_uq_prestrafe_blue
255
11.
Color of speed, in the RGB
kz_uq_speed_red
255
kz_uq_speed_green
255
kz_uq_speed_blue
255
12.
Coordinates Hud messages
a) General stats jump
kz_uq_stats_x
-1.0
kz_uq_stats_y
0.70
b) Strafes Stats
kz_uq_strafe_x
0.70
kz_uq_strafe_y
0.35
c) Ducks Stats for Multi CountJump
kz_uq_duck_x
0.6
kz_uq_duck_y
0.78
d) For speed
kz_uq_speed_x
-1.0
kz_uq_speed_y
0.83
e) for prestrafe
kz_uq_prestrafe_x
-1.0
kz_uq_prestrafe_y
0.65
13.
Channels Hud messages
kz_uq_hud_stats
b) Strafes Stats
kz_uq_hud_strafe
kz_uq_hud_duck
d) For speed
kz_uq_hud_speed
e) For prestafe
kz_uq_hud_pre
Color of chat messages of distance jump (good = grey, pro = green, holy = blue, leet = red, god = red (with sound godlike for all players))
a) LongJump/HighJump
kz_uq_good_lj
240
kz_uq_pro_lj
245
kz_uq_holy_lj
250
kz_uq_leet_lj
253
kz_uq_god_lj
255
b) CountJump
kz_uq_good_cj
250
kz_uq_pro_cj
255
kz_uq_holy_cj
260
kz_uq_leet_cj
265
kz_uq_god_cj
267
c) Double CountJump/Multi CountJump
kz_uq_good_dcj
250
kz_uq_pro_dcj
255
kz_uq_holy_dcj
260
kz_uq_leet_dcj
265
kz_uq_god_dcj
270
d) LadderJump
kz_uq_good_ladder
150
kz_uq_pro_ladder
160
kz_uq_holy_ladder
170
kz_uq_leet_ladder
180
kz_uq_god_ladder
190
e) BhopJump/StandUp BhopJump
kz_uq_good_bj
230
kz_uq_pro_bj
235
kz_uq_holy_bj
240
kz_uq_leet_bj
245
kz_uq_god_bj
247
f) WeirdJump/Drop CountJump/Ladder BhopJump
kz_uq_good_wj
255
kz_uq_pro_wj
260
kz_uq_holy_wj
265
kz_uq_leet_wj
270
kz_uq_god_wj
272
g) Drop BhopJump/Drop StandUp BhopJump
kz_uq_good_dbj
240
kz_uq_pro_dbj
250
kz_uq_holy_dbj
265
kz_uq_leet_dbj
270
kz_uq_god_dbj
272
h)StandUp CountJump(if 100aa all cvar dist +15 units)
kz_uq_good_scj
240
kz_uq_pro_scj
245
kz_uq_holy_scj
250
kz_uq_leet_scj
255
kz_uq_god_scj
257
15. on/off each technique
kz_uq_lj
kz_uq_cj
kz_uq_bj
kz_uq_sbj
kz_uq_wj
kz_uq_dcj
kz_uq_mcj
kz_uq_drbj
kz_uq_scj
kz_uq_drcj
kz_uq_ladder
kz_uq_ldbj
16. Minimum jump distance (except LadderJump)
kz_uq_min_dist
215
kz_uq_max_dist
290
Players commands
say /strafes – on/off statistics Strafes
say /showpre –on/off display prestrafe
say /ducks –on/off statistics ducks for multi cj
say /ljstats –on/off the main statistics
say /uqversion – show version
say /beam – on/off showing the trajectory of the jump
say /speed –on/off display of speed player
say /colorchat –on/off display of color in the chat messages from other players
say /ljsmenu – open the configuration menu
say /ljtop – open TOP10 menu
say /bhopwarn -on/off show message when you bhop prestrafe is fail
say /multibhop - on/off show multi bhop pre
say /duckspre - on/off display prestrafe after each duck
say /ljpre - on/off display prestrafe for LJ
Admin command
amx_reset_uqtops – reset all tops
amx_uq_default_cvars - set all cvars to default values
uq_jumpstats_2.12.zip
发表于 2010-10-15 23:54:19 | 显示全部楼层
貌似很屌,去试试~
发表于 2010-10-16 00:11:15 | 显示全部楼层
本来想加分的,一看原来是问问题的,手硬是停住了
发表于 2010-10-16 00:36:10 | 显示全部楼层
MaMaMiYa 发表于 2010-10-16 00:11
    本来想加分的,一看LS才知道原来是问问题的,手硬是停住了
发表于 2010-10-16 00:57:09 | 显示全部楼层
同样的插件我输入/ljtop有反应。但我也不能解答你的问题,你试试/lj10吧。
发表于 2010-10-16 02:35:15 | 显示全部楼层
楼主骗人木有小鸡鸡
发表于 2010-10-16 09:13:02 | 显示全部楼层
唉。。差点被欺骗了
发表于 2010-10-16 17:34:26 | 显示全部楼层
回复 4# honwenle
    本来是想加粪的,一看4L才知道是问问题的,手硬是停住了!
 楼主| 发表于 2010-10-18 11:34:21 | 显示全部楼层
LS几个白痴
我怎么骗人了?
我插件没发出来么?
但在我的电脑上确实出现了上诉问题
发表于 2010-10-18 13:54:29 | 显示全部楼层
呵呵,逗你玩了,反正我是菜鸟,喃不知道这问题的原因
