查看: 2049|回复: 3
【下载】找到个VV10a 的下载地址(附注册机)
发表于 2010-10-12 20:16:57 | 显示全部楼层 |阅读模式
http://www.mv7.cn/thread-2331-1-1.html
专业人士去看看吧。
应该是破解的,气死小日本
 楼主| 发表于 2010-10-12 20:25:23 | 显示全部楼层
V10的crk方法
1:install sony vegas pro
2:close internet
3:run SonyVegasPro Patch.exe
4:select "program files\sony" folder from left icon and press "+" and then press Crack Me.        After patch close SonyVegasPro Patch.exe
5:run Keygen.exe
6:select "vegas pro 9.0 (32 and 64bit) series
7: select "program files\sony\Vegas Pro 10.0" folder and   "program files\sony\Shared Plug-Ins"  press to patch again
8: after patch open sony vegas
9: Generate a serial number like this "1HF-xxxx-xxxx-xxxx" and register program with the same serial number
    but change the first three characters in "1R8" (like this: 1R8-xxxx-xxxx-xxxx)
10: select another pc registration or register later.
11: In registration window, fill anything and write authentication number from keygen.
12 Enjoy ;)
发表于 2010-10-12 23:54:26 | 显示全部楼层
可以汉化么。。。。。。。。?
发表于 2010-10-13 08:19:44 | 显示全部楼层
前天我安装了看了。没啥意思。
