查看: 2251|回复: 9
【软件】Vegas Pro10.0要问世了
发表于 2010-10-7 10:54:07 | 显示全部楼层 |阅读模式
旁门左道消息。Vegas10.0要在10月11日发布了。加了新的功能
When speed, precision, flexibility and dimensionality matter most, Vegas Pro™ 10 delivers. This collection offers an efficient and intuitive environment for professional audio and video editing, DVD/Blu-ray Disc™ authoring, and new stereoscopic 3D production. With broad format support, superior video effects processing, and the most powerful audio tools available in a NLE, Vegas Pro 10 provides everything needed to produce outstanding results whether in the field or the editing suite.
Vegas Pro 10 will be available October 11, 2010 and offers an impressive list of new features and workflow enhancements. Listed below are a few core components that make this one of the most significant upgrades ever to our award-winning editing and production platform.
1.3D特效编辑
Vegas Pro 10 让你导入,编辑,预览和生成真正的3D立体电影
2.支持AVC格式的GPU渲染
如果你是用N卡,并且你的显卡支持CUDA技术,你就可以运他来加速你的AVC格式的渲染速度
3.图像稳定技术
Vegas终于整合了PRODAD里面的图像稳定插件了
4.音频特效
改进的音频特效处理
5.轨道管理
Vegas Pro 10提供轨道组合功能.轨道组合功能可以节省你的空间.并且管理和梳理复杂的轨道关系
6.更新的播放控制按钮
更新了裁剪器和预览窗口的控制方式.让你在编辑中更简单
7.增强的视频特效底层
新的视频特效SDK.降低第三方制作插件的难度.让更多人可以开发更好的插件
8.DVD Architect Pro 5.2*
DVD Architect Pro 5.2更新支持Microsoft's Image Mastering API (IMAPI).提供更广泛的刻录支持.以及36套高清模板
Stereoscopic 3D Editing
Video editors can now create stereoscopic 3D projects utilizing the same workflow we’ve provided for 2D media! Vegas Pro 10 provides the ability to import, adjust, edit, preview, and output stereoscopic 3D media — all using industry standard professional delivery formats including single or dual files including side-by-side, top/bottom, or line-alternate encoding. Anaglyphic monitoring and output are also supported.
Comprehensive Closed Captioning
In addition to Vegas Pro’s industry-leading closed captioning workflow, Vegas Pro 10 supports import and export of Line 21 closed captioning, capture and print to tape of HD-SDI from AJA and Blackmagic Design cards, as well as support for standard closed captioning file types. Before delivering the final project, you can preview closed captioning data during the editing process to ensure correct placement and viewing experience.
GPU-Accelerated AVC Encoding
Editors using a CUDA-enabled NVIDIA® video card are able to encode to the Sony AVC format using GPU-accelerated rendering — providing improved AVC rendering performance and speed, ensuring final projects are published faster than ever before
Image Stabilization
Enhance video by removing camera shake and rolling shutter. Developed in partnership with proDAD, image stabilization provides a smooth playback experience by reducing jittery or shaky video that sometimes occurs when shooting without a tripod or by using inexpensive portable pocket devices.
Audio Event FX
Vegas Pro 10 allows editors to assign audio effects at the master output, bus level, track level, and now the event level for greater flexibility when working with multitrack projects. Audio event effects provide more options and precise control over the placement of audio effects throughout the project.
Input Busses
Record, monitor, and mix audio from external devices with Vegas Pro 10 projects. Input busses provide the ability to record external hardware effects, mix external audio sources and effects processors, utilize complex internal audio effect chains, and monitor audio input with ease and precision.
Track Management
Vegas Pro 10 provides the ability to group tracks. Grouping tracks saves space on the timeline by providing collapsed tracks under a single header track. This is a quick and easy way to organize and manage complex projects by grouping specific sections of video/audio.
Updated Transport Controls
Updated Trimmer and Video Preview windows now provide transport controls. This allows you the freedom to edit with a more tactile approach, providing more intuitive and immediate command over your editing and improving the overall workflow.
Enhanced Video Plug-in Architecture
The new Video Effects Plug-in SDK (Software Developer’s Kit), based on the Open Effects Association platform, provides updated and enhanced technology that enables third-party plug-in developers to develop advanced video effect plug-ins more easily and rapidly. These additional plug-ins offer Vegas Pro 10 editors a wider variety of effects and special techniques for creating professional-level projects.
In addition to industry-leading DVD and Blu-ray Disc authoring tools, DVD Architect Pro now offers support for Microsoft's Image Mastering API (IMAPI), providing increased drive support and stability while burning to DVD and Blu-ray Disc. Use over 36 new high-definition themes to quickly bring your project to life.
发表于 2010-10-7 11:02:44 | 显示全部楼层
好诶!~~~~~SF
发表于 2010-10-7 11:04:00 | 显示全部楼层
好诶!~~~~~SF网不好 多按了  各位大大别扣分啊!!!!!
发表于 2010-10-7 11:04:04 | 显示全部楼层
哇~好厉害啊
发表于 2010-10-7 11:19:58 | 显示全部楼层
。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。顶!
发表于 2010-10-7 11:24:29 | 显示全部楼层
bucuo
发表于 2010-10-7 11:39:10 | 显示全部楼层
是个啥?
看来我要好好学习了
发表于 2010-10-7 13:28:28 | 显示全部楼层
以后做KZ视频的时候就做成3D的看了。
发表于 2010-10-7 16:25:33 | 显示全部楼层
我就等着下载咯~
 楼主| 发表于 2010-10-8 10:34:38 | 显示全部楼层
期待啊。就等发布了。
参与人数 1金币 +7 +7 收起 理由
SiMen.xInsHou + 7 + 7 我来加分的~
