查看: 896|回复: 6
E文帝,请进,求翻译。
发表于 2010-9-11 16:57:36 | 显示全部楼层 |阅读模式
  1. hns_enable 1/0
  2. - Enables or disables the plugin (default: 1)
  3. hns_votegametype 1/0
  4. - If set, there will be a vote for game type on the start of each map (deathmatch or normal mode). Disable to have only normal mode or deathmatch mode. (default: 1)
  5. hns_halfwayvote 1/0
  6. - If set and deathmatch mode is on, a vote for gametype will re-appear halfway through the game. (default: 1)
  7. hns_deathmatch 1/0
  8. - Enables or disables deathmatch mode (default: 0). After enabling, map should be changed.
  9. hns_gamename gamename
  10. - Sets the game description
  11. hns_timer 0-∞
  12. - How long the hiding time is (default: 10)
  13. hns_fadecolor red green blue alpha
  14. - Sets the color of fadecolor, alpha is transparency (default: 0 0 0 255)
  15. hns_switch 0-∞
  16. - Number of rounds CTs have to lose in a row before the teams automatically switch, (default: 5, to disable: 0)
  17. hns_slash 0-∞
  18. - Number of rounds CTs have to lose in a row before they can use slash, default: 3 (default: 3, to disable: 0)
  19. hns_flashbangs 0-3
  20. - Number of flashbangs Terrorists receive
  21. hns_hegrenade 0-3
  22. - 0: Disable, 1: Hiders get a HE-Grenade, 2: Seekers, 3: Both (default: 0)
  23. hns_smokegrenade 0-3
  24. - 0: Disable, 1: Hiders get a smoke grenade, 2: Seekers, 3: Both (default: 1)
  25. hns_nadesbeginning 1/0
  26. - Should terrorists receive grenades at spawn or after timer (default: 0)
  27. hns_sound 1/0
  28. - Enables or disables countdown sound in hide time, (default: 1)
  29. hns_semiclip 1/0
  30. - Enables or disables team semiclip (default: 1)
  31. hns_pickup 1/0
  32. - Enables or disables blocking of weapon pickup (default: 1)
  33. hns_fakeknife 0/1/2
  34. - Enables or disables a fake knife for Terrorists to avoid speed bug. 0: disable, 1: invisible knife, 2: visible knife (default: 1)
  35. hns_chooseteam 1/0
  36. - Enables or disables players ability to choose a team (default: 0)
  37. hns_blockkill 1/0
  38. - Enables/disables blocking of kill command in console
  39. hns_footsteps 0/1/2
  40. - 1 = Terrorists have no footsteps, 2 = CT, 0 = disable (default: 1)
  41. hns_noflash 1/0
  42. - If enabled, terrorists will not be affected by flashbangs (default: 1)
  43. hns_removedoors 1/0
  44. - Enables or disables removal of doors (default: 1)
  45. hns_removebreakables 1/0
  46. - Enables or disables removal of breakables, not removed on: any map containing "dust", de_piranesi, de_train (e.g vents, default: 1)
  47. hns_newnades 1/0
  48. - Should the last terrorist get new nades (default: 1)
复制代码
发表于 2010-9-11 17:33:16 | 显示全部楼层
发表于 2010-9-11 18:20:06 | 显示全部楼层
hns_enable 1 / 0
- 启用或禁用插件(默认是:1)
hns_votegametype 1 / 0
- 如果设置,将会有一个游戏每个地图(死斗或正常模式启动类型)进行表决。禁用有只正常模式或死斗模式。 (默认是:1)
hns_halfwayvote 1 / 0
- 如果设置和死斗模式是,一个游戏模式投票将重新出现在游戏的中间。 (默认是:1)
hns_deathmatch 1 / 0
- 启用或禁用死斗模式(默认值:0)。启用后,地图应该有所改变。
- 设置游戏介绍
hns_timer 0 - ∞
- 隐藏多久时间(默认:10)
hns_fadecolor红色绿色蓝色阿尔法
- 设置fadecolor颜色,阿尔法是透明度(默认值:0 0 0 255)
hns_switch 0 - ∞
- 电流互感器的轮数都在失去前行的车队自动开关,(默认:5,禁用:0)
hns_slash 0 - ∞
- 电流互感器的轮数要连续输,才可以使用斜线,默认是:3(默认是:3,禁用:0)
hns_flashbangs 0-3
- 恐怖分子获得的flashbangs数
hns_hegrenade 0-3
- 0:禁止,1:Hiders得到何手榴弹,2:求职者,3:两者(默认值:0)
- 0:禁止,1:Hiders得到一个烟雾弹,2:求职者,3:两者(默认是:1)
hns_nadesbeginning 1 / 0
- 应在收到恐怖分子产卵或手榴弹后计时器(默认值:0)
hns_sound 1 / 0
- 启用或禁用倒计时声中隐藏的时间,(默认:1)
hns_semiclip 1 / 0
- 启用或禁用队semiclip(默认是:1)
hns_pickup 1 / 0
- 启用或禁用武器皮卡(默认是:阻塞1)
hns_fakeknife 0/1/2
- 启用或禁用一个恐怖分子,以避免假刀速度的一个错误。 0:关闭,1:无形的刀,2:可见刀(默认是:1)
hns_chooseteam 1 / 0
- 启用或禁用玩家能够选择一组(默认值:0)
hns_blockkill 1 / 0
- 允许/禁止阻断杀死控制台命令
hns_footsteps 0/1/2
- 1 =恐怖分子没有脚步声,2 =电脑断层,0 =禁用(默认是:1)
hns_noflash 1 / 0
- 如果启用,恐怖分子不会受到影响flashbangs(默认是:1)
hns_removedoors 1 / 0
- 启用或禁用去除门(默认是:1)
hns_removebreakables 1 / 0
- 启用或禁用去除易碎品,而不是取消了:任何地图,其中“尘”,de_piranesi,de_train也(如泉,默认是:1)
hns_newnades 1 / 0
- 如果最后恐怖分子获得新纳代什(默认是:1)
发表于 2010-9-11 18:39:44 | 显示全部楼层
鼓励加分。
发表于 2010-9-12 01:27:46 | 显示全部楼层
hns_enable 1 / 0
- 启用或禁用插件(默认是:1)
- 设置游戏介绍
hns_timer 0 - ∞
- 隐藏多久时间(默认:10)
hns_switch 0 - ∞
hns_slash 0 - ∞
hns_flashbangs 0-3
hns_hegrenade 0-3
hns_sound 1 / 0
hns_semiclip 1 / 0
hns_pickup 1 / 0
hns_fakeknife 0/1/2
hns_blockkill 1 / 0
- 允许/禁止阻断杀死控制台命令
hns_footsteps 0/1/2
hns_noflash 1 / 0
- 启用或禁用去除门(默认是:1)
hns_newnades 1 / 0
发表于 2010-9-12 10:26:30 | 显示全部楼层
好多淫才
 楼主| 发表于 2010-9-12 16:36:31 | 显示全部楼层
木有人工翻译吗?
