查看: 757|回复: 4
【以解决】 求视角转换插件
发表于 2010-8-30 06:05:20 | 显示全部楼层 |阅读模式
就求一个第三人称视觉插件。
不要其他功能就这个
发表于 2010-8-30 06:33:44 | 显示全部楼层
这个  估计有点难度 。。。KZ 1.0版上面就有 F6
发表于 2010-8-30 06:47:08 | 显示全部楼层
光要一个呀.
别人都是要很多的.
你就要一个.
能说说要这个干嘛么?
发表于 2010-8-30 07:13:17 | 显示全部楼层
你去下个不就行了吗。。反正都一样用
发表于 2010-8-30 07:47:34 | 显示全部楼层
  1. /*
  2. Change View Type created by OneEyed.
  3. */
  4. #include <amxmodx>
  5. #include <amxmisc>
  6. #include <engine>
  7. /*--------------------------------------------------------//
  8.    Change this to different if you want only admins to use.
  9.    e.g. #define ACCESS_TYPE ADMIN_KICK
  10.         or
  11.         #define ACCESS_TYPE ADMIN_RCON
  12. //--------------------------------------------------------*/
  13. #define ACCESS_TYPE 0
  14. //--------------------------------------------------------//
  15. new view[32]
  16. //Precache of rpgrocket.mdl is NEEDED, for some odd reason.
  17. public plugin_precache()
  18. precache_model("models/rpgrocket.mdl")
  19. public plugin_init() {
  20. register_plugin("Change View","v1.0","OneEyed")
  21. register_concmd("amx_view","changeView",ACCESS_TYPE,"Cycles through 4 different view types.")
  22. }
  23. public client_disconnect(id)
  24. view[id] = 1
  25. public client_connect(id)
  26. view[id] = 1
  27. public changeView(id,level,cid) {
  28. if ( !cmd_access(id,level,cid,0) )
  29.      return PLUGIN_HANDLED
  30. new viewtype[32]
  31. if(view[id] > 3)
  32.   view[id] = 0
  33. switch(view[id])
  34. {
  35.   case 0: format(viewtype,31,"Normal")
  36.   case 1: format(viewtype,31,"3rd Person")
  37.   case 2: format(viewtype,31,"3rd Person (Up Left)")
  38.   case 3: format(viewtype,31,"3rd Person (Top Down)")
  39. }
  40. client_print(id,print_chat,"Changing View to %s",viewtype)
  41. set_view(id, view[id])
  42. view[id]++
  43. return PLUGIN_HANDLED
  44. }
复制代码
