楼主: lzj5911
这个参数是干什么用的。。
发表于 2010-8-28 22:37:16 | 显示全部楼层
强烈鄙视那个叫你改的人
  最好是把config删了 然后进游戏设置键位
  什么参数都是合法的
发表于 2010-8-28 22:49:49 | 显示全部楼层
回复 9# GOoo
    左手拿刀,右手拿叉。
发表于 2010-8-29 02:04:04 | 显示全部楼层
回复 6# lzj5911
    XJ上的规则:
    * Demos must be done with these settings:
      Server settings:
      edgefriction "2"
      mp_footsteps "1"
      sv_cheats "0"
      sv_gravity "800"
      sv_airaccelerate "10"
      sv_maxspeed "320"
      sv_stepsize "18"
      sv_maxvelocity "2000"
      Client settings:
      developer "0"
      cl_lw "1"
      cl_sidespeed "400"
      cl_backspeed "400"
      cl_forwardspeed "400"
      fps_max "101"
      You are not allowed to use any cvar or setting that might give you an unfair advantage compared to the default counter-strike settings (just as cl_sidespeed and so on), even if it's not stated in the list above. Keep your config default!
发表于 2010-8-29 08:45:54 | 显示全部楼层
不知道这参数有啥用
