查看: 6562|回复: 3
【以解决】 WIN7关机蓝屏重启
发表于 2010-8-21 22:19:23 | 显示全部楼层 |阅读模式
电脑一关机就蓝屏 屏幕上显示一个百分比 到100% 就重启了  除非按关机键才可以关掉
问题签名:
  问题事件名称: BlueScreen
  OS 版本: 6.1.7600.2.0.0.256.1
  区域设置 ID: 2052
有关该问题的其他信息:
  BCCode: 18
  BCP1: 00000000
  BCP2: 987F5280
  BCP3: 00000002
  BCP4: FFFFFFFF
  OS Version: 6_1_7600
  Service Pack: 0_0
  Product: 256_1
有助于描述该问题的文件:
  C:\Windows\Minidump\082110-26878-01.dmp
  C:\Windows\Temp\WER-30232-0.sysdata.xml
联机阅读隐私声明:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0804
如果无法获取联机隐私声明,请脱机阅读我们的隐私声明:
  C:\windows\system32\zh-CN\erofflps.txt
这是 C:\Windows\Minidump\082110-26878-01.dmp里的信息
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\082110-26878-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (3 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x8443c000 PsLoadedModuleList = 0x8457b570
Debug session time: Sat Aug 21 21:49:42.072 2010 (GMT+8)
System Uptime: 0 days 3:57:45.664
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
______________________________________________________
兼容性问题
建议返回还原
发表于 2010-8-21 22:43:14 | 显示全部楼层
0X000?似乎是软件问题
发表于 2010-8-21 22:52:27 | 显示全部楼层
重装please.
这种都是系统文件错误导致的问题.去修复这种问题还不如重装
发表于 2010-8-21 22:58:46 | 显示全部楼层
我貌似冒有
