查看: 905|回复: 7
各位KZ达人 请进 谁有优化好的config那个文件啊
发表于 2010-7-13 09:40:22 | 显示全部楼层 |阅读模式
显卡比较次   求一个 那个config 那个文件 谢谢
一定要优化好的啊 fps啊 纠结。。。。
 楼主| 发表于 2010-7-13 09:42:19 | 显示全部楼层
// This file is overwritten whenever you change your user settings in the game.
// Add custom configurations to the file "userconfig.cfg".
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "*" "radio2"
bind "+" "sizeup"
bind "," "buyammo1"
bind "-" "+rope"
bind "." "buyammo2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "+hook"
bind "[" "invprev"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100;wait;wait;wait;impulse 100;wait;wait;wait;impulse 100;wait;wait;wait;"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" ".menu"
bind "j" "cheer"
bind "k" "+voicerecord"
bind "l" "showbriefing"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "say menu"
bind "p" "stop;sv_restartround 1;record 1"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "v" "+Paint"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "say menu"
bind "F2" "stop;record jump;say RECORD"
bind "F3" "say /top15"
bind "F4" "say /checkpoint"
bind "F5" "say /gocheck"
bind "F6" "amx_view"
bind "F7" "say /bm15"
bind "F8" "say /stuck"
bind "F9" "say /ungocheck"
bind "F10" "say /ljsmenu"
bind "F11" "amx_view"
bind "F12" "exec csmate.cfg"
bind "INS" "+klook"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "centerview"
bind "KP_LEFTARROW" "tg_famgal"
bind "KP_5" "awp"
bind "KP_RIGHTARROW" "tg_augsg"
bind "KP_END" "deagle"
bind "KP_DOWNARROW" "mp5"
bind "KP_PGDN" "tg_m4ak"
bind "KP_ENTER" "rze_helm"
bind "KP_INS" "hegren"
bind "KP_DEL" "flash"
bind "KP_SLASH" "+attack2"
bind "KP_MINUS" "defuser"
bind "KP_PLUS" "vest"
bind "CAPSLOCK" "+speed"
bind "MWHEELDOWN" "+jump"
bind "MWHEELUP" "+duck"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "MOUSE3" "+jd"
bind "MOUSE4" "+jd"
bind "PAUSE" "pause"
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "0"
ati_subdiv "0"
bgmvolume "1.000000"
bottomcolor "0"
brightness "30"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "30"
cl_cmdrate "80"
cl_corpsestay "180.000000"
cl_crosshair_color "50 250 50"
cl_crosshair_size "small"
cl_crosshair_translucent "1"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "0"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Yellow"
cl_logofile "lambda"
cl_lw "1"
cl_minmodels "0"
cl_radartype "1"
cl_righthand "1"
cl_shadows "1"
cl_timeout "35"
cl_updaterate "80"
cl_vsmoothing "0.05"
cl_weather "0"
con_color "255 180 30"
console "0.000000"
crosshair "1.000000"
fastsprites "2"
fps_max "101"
fps_modem "0.0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "1"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "arctic"
MP3FadeTime "2.0"
MP3Volume "0.8"
mp_decals "0.000000"
name "buhuiwan,*"
net_graph "3"
net_graphpos "3"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "0"
s_a3d "0"
s_automax_distance "30"
s_automin_distance "2"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "5"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "1.6"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.25"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "0"
viewsize "120"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "1"
volume "2"
setinfo "_connect_sound" "0"
setinfo "sredir" "-1"
setinfo "kzp" "kztw"
setinfo "_redirect" "1"
setinfo "lang" "cn"
setinfo "_vgui_menus" "1"
setinfo "_ah" "0"
+mlook
+jlook
exec userconfig.cfg
这个是我的 帮我改改也行啊
发表于 2010-7-13 12:00:29 | 显示全部楼层
LSV5!!!
发表于 2010-7-13 14:31:53 | 显示全部楼层
发表于 2010-7-13 16:09:25 | 显示全部楼层
有人推荐给我的config,但是我觉得不如原版好..
发表于 2010-7-13 17:32:11 | 显示全部楼层
你要优化什么方面的?
 楼主| 发表于 2010-7-16 10:09:32 | 显示全部楼层
回复 6# yanjunan
    fps a
发表于 2010-7-16 10:26:36 | 显示全部楼层
如果有水的地图卡,可以用invis插件屏蔽掉,如果像kz_kzfr_escape这样结构复杂而卡的地图,只好放弃咯。config基本没用,升级硬件才是王道。
另外小手冰冷咋被禁止访问了
