查看: 654|回复: 8
cc上傳demo問題!
发表于 2010-6-23 16:43:59 | 显示全部楼层 |阅读模式
我上傳一個demo後他說
Error: Wrong file name. (h)
Error: Wrong file name. (n)
demo名字是:bhop_minimountain_snow
錯了什麼??
发表于 2010-6-23 16:47:22 | 显示全部楼层
http://www.cosy-climbing.net/rules.php
Demo Rules:
Cosy-Climbing uses fps-Death's record time. It means you'll have to check your demo with fps-Death and name it correctly with the "record time" demo read out. Get fps-Death here.
  • You have to start recording before you press the start timer and stop recording, after you've stopped the end timer.
  • The only weapons allowed for recording are USP & knife.
  • The demo should be compressed with WinRAR like this: "mapname_author_time.miliseconds.rar" (for example "rs_grassblock_Nikola_1337.10.rar") and the .dem file inside should be in the same format (mapname_author_time.miliseconds.dem) (Only the first 2 digits of the miliseconds) (The miliseconds can be seen on fpsDeath)
  • The average fps must be at least 80 fps. Before submitting your demo, please check the demo using fps-Death.
  • Using Godmode is forbidden. If there's any HP booster, use it.
  • Your demo must be recorded on your LAN server.
  • Cheats/hacks/scripts are strictly forbidden! Any cheating will give you a permanent ban from the whole community.
  • You cannot use any plugins/metamod plugins which will give you advantage.
  • Custom model are not allowed! If your demo contains a custom model it will be denied.
  • Your demo must be recorded with these settings (originally from Xtreme-Jumps):
    Server:
    edgefriction "2"
    mp_footsteps "1"
    sv_cheats "0"
    sv_gravity "800"
    sv_airaccelerate "10"
    sv_maxspeed "320"
    sv_stepsize "18"
    sv_maxvelocity "2000"
    Player:
    developer "0"
    fps_max "101"
    You are not allowed to use any cvar or setting (like changing the default value on cl_sidespeed) that might give you an advantage against other players using the default CS settings. Keep it default!
发表于 2010-6-23 16:47:31 | 显示全部楼层
坐下来,和咖啡 慢慢琢磨
发表于 2010-6-23 16:55:40 | 显示全部楼层
参考别人是怎么填写的,笨蛋
 楼主| 发表于 2010-6-23 16:56:10 | 显示全部楼层
我用不到fps_death- -
按load demo沒反應...
发表于 2010-6-23 17:09:50 | 显示全部楼层
先选中demo再load
 楼主| 发表于 2010-6-23 17:13:57 | 显示全部楼层
給個圖教教- -
我笨
发表于 2010-6-23 19:29:06 | 显示全部楼层
....你们说的什么?
发表于 2010-6-23 22:16:29 | 显示全部楼层
没有时间
地图名_跳跃者id_跳图用时
