查看: 1877|回复: 18
Second matchday ended kelta离开比赛
发表于 2010-5-23 03:59:07 | 显示全部楼层 |阅读模式
This newspost had a delay as you already know. The reason for that is that one match has not been played and we were waiting some more days, but unfortunately without luck.
The match Cypek vs. KeltA has not been played. Furthermore, we have to announce that KeltA leaves the league. We are searching someone who can replace him in order to fulfill his spot. Before you apply in comments make sure you have the time to play, because it is always work for us admins when someone leaves.
Kelta退出了比赛.
In addition to that news we also have to explain some results. ShoCk did not record all demos and because of that w1zz decided that these results are invalid. It is the second time people tend to forget recording...
Shock没有录完全部的demo,因为w1zz当时认为结果无效.
Cypek vs KeltA... will be played when KeltA is replaced...
Adantoud vs rEs0LuTe 1:4, --------------demos: Adantoud rEs0LuTe   啊蛋疼萎了
zhady vs niki 5:0--------------------------demos: zhady niki                不出意料
akkord vs Skizo_ 4:1, ---------------------demos: akkord Skizo_    akkord在某图走SC摔死.
chrizZo vs Memories 4:1, -------------------demos: chrizZo Memories
w1zz vs ShoCk 3:2, --------------------------demos: w1zz ShoCk
MepH vs Z0ck3rOO7 2:3, -----------------------demos: MepH Z0ck3rOO7      宝刀未老
Matchday 3  第三回合
Cypek vs M@UGLI
KeltA vs rEs0LuTe
Adantoud vs Skizo_
zhady vs Memories
akkord vs ShoCk
chrizZo vs Z0ck3rOO7
w1zz vs MepH
niki rests this match day  niki休息
Mappool: KZ_kzfr_haunted; kzno_xtremeblock; kz_kzj_tech; j2s_4tunnels; kz_j2s_sunblock
KeltA will be replaced in the next days. The player who signs up for KeltA needs to play the match against Cypek (matchday 2) and the match against rEs0LuTe (matchday 3) in one week!
Deadline is 30.5.2010, please try to play your matches till that date this time, else the league will slow down...
发表于 2010-5-23 04:08:52 | 显示全部楼层
MepH vs Zock3rOO7 超级精彩
 楼主| 发表于 2010-5-23 05:33:32 | 显示全部楼层
发表于 2010-5-23 06:14:03 | 显示全部楼层
还是想看zhady的表现
  Zock3rOO7的弹跳
发表于 2010-5-23 06:27:35 | 显示全部楼层
小K 为何退出
难道状态不佳
发表于 2010-5-23 10:26:03 | 显示全部楼层
围观..您的帖子长度不符合要求。 当前长度: 6 字节系统限制: 8 到 100000 字节
发表于 2010-5-23 10:52:32 | 显示全部楼层
求HLTV
发表于 2010-5-23 11:19:49 | 显示全部楼层
看好 zhady  shock  resolute
因为这几个名字熟点
发表于 2010-5-23 11:24:35 | 显示全部楼层
早说了  KeltA 肯定最后一名  不如早点退出 加速虽好  但是技巧 和 节奏都不到位
发表于 2010-5-23 11:46:31 | 显示全部楼层
K!tteN 发表于 2010-5-23 11:24
    他状态不好么?
再怎么样,niki肯定不是他对手啊
