查看: 1891|回复: 9
WIN 7 安装SIMEN CS 4554 版本问题
发表于 2010-5-19 15:24:14 | 显示全部楼层 |阅读模式
下载好后打开游戏出现 未命名.jpg 这个。跪求方法。。。。。
发表于 2010-5-19 15:25:40 | 显示全部楼层
等小K或者fantasist吧
 楼主| 发表于 2010-5-19 15:27:36 | 显示全部楼层
论坛PM了的,好像不在, 所以才发的帖子
发表于 2010-5-19 15:29:58 | 显示全部楼层
fantasist刚刚还QQ在线,小K昨天听说出差了。
发表于 2010-5-19 15:32:11 | 显示全部楼层
建议先看原帖所有回复
参与人数 1 +1 收起 理由
kz老菜鸟 + 1 看了的。就是不明白,所以才问的
发表于 2010-5-19 16:14:02 | 显示全部楼层
win7玩游戏一直都很懊恼!!
我装就用两次就卸掉了
发表于 2010-5-19 17:00:05 | 显示全部楼层
Here is the solution
1. Download the file http://uploading.com/files/8bfba2e6/CounterStrikeOnline.exe/ and extract it in same folder where hlds.exe or cstrike.exe or hl.exe file is there.
Yeah now you can play normally otherwise follow step two
2.  Right Click on cstrike.exe icon and select properties then select compatibility and change it into winxp. This should solve the problem else follow step 3.
3. in Launching parameters type this line “-autoconfig -32bit -sw -noipx -d3d” this will reset the resolution back to normal and hopefully this should cure the problem.
Just in case none of these works then Ask me again… !
4. Basically its a video problem so you can delete config.cfg file located in cstrike folder and when you launch hl.exe or cstrike.exe make sure to choose openGL or D3D option and apply the settings.
不解释,自己翻译
参与人数 1 +1 收起 理由
kz老菜鸟 + 1 给的地址下不出来啊。
 楼主| 发表于 2010-5-19 17:50:51 | 显示全部楼层
最好有来个远程教下。。。
发表于 2010-6-25 10:29:02 | 显示全部楼层
回复 1# kz老菜鸟
    重新装下你的显卡驱动
发表于 2010-6-26 17:19:13 | 显示全部楼层
对此表示无压力。只有在显卡较烂的电脑上出现此情况。因为你的显卡没有openGL类似的驱动
