查看: 1088|回复: 11
simen版本很严重的问题!
发表于 2010-5-13 11:02:09 | 显示全部楼层 |阅读模式
KZie_bunnyheaver 时候
请告诉我该如何解决
发表于 2010-5-13 11:03:41 | 显示全部楼层
少文件!train.sc
发表于 2010-5-13 11:05:21 | 显示全部楼层
我也是这样
 楼主| 发表于 2010-5-13 11:07:09 | 显示全部楼层
我下载了 train.sc 放进去还是不行  很多图都进不去
发表于 2010-5-13 11:09:33 | 显示全部楼层
复制到记事本保存为train.sc
放到\cstrike\events 下
如果还不行把控制台的错误信息发来
  1. // System-wide global variables
  2. $server = false;
  3. $localplayer = true;
  4. $origin = [ 0, 0, 0 ];
  5. $view_ofs = [ 0, 0, 0 ];
  6. $angles = [ 0, 0, 0 ];
  7. $gun_position [ 0, 0, 0 ];
  8. $gun_angles[ 0, 0, 0 ];
  9. $usehull = 0;
  10. $client_time = 0;
  11. //
  12. $snd = "";
  13. $model = "";
  14. $shell_origin = [ 0, 0, 0 ];
  15. $shell_velocity = [ 0, 0, 0 ];
  16. $forward = [ 0, 0, 0 ];
  17. $right   = [ 0, 0, 0 ];
  18. $up                 = [ 0, 0, 0 ];
  19. public Fire_Glock()
  20. {
  21.         // Play a sound
  22.         $snd = weapons/pl_gun3.wav;
  23.         $model = models/shell.mdl;
  24.         Native_PlayPlayerSound( $player = $localplayer, $sound = $snd, $channel = CHAN_STATIC, $pitch = $def_pitch, $attenuation = $def_attn, $pitch = $def_pitch );
  25.         // Eject shells
  26.         //
  27.         for ( $i = 0; $i < 2; $i++ )
  28.         {
  29.                 $shell_origin   = $origin + $view_ofs;
  30.                 $shell_velocity = $forward * 24 + right * 6 + $up * 20;
  31.                 $shell_angles = $angles;
  32.                 $angles[0] = 0;
  33.                 $angles[2] = 0;
  34.                 Native_CreateTempEntity
  35.                 (
  36.                         $te_origin = $shell_origin,
  37.                         $te_angles = $angles,
  38.                         $te_framemax = Native_FrameCountForModel( $model = $model ),
  39.                         $te_flags = FTENT_COLLIDEWORLD | FTENT_GRAVITY | FTENT_ROTATE,
  40.                         $te_hitSound = BOUNCE_SHELL;
  41.                         $te_baselineangles = Native_RandomAngles(),
  42.                         $te_basedirection  = $shell_velocity,
  43.                         $te_die = $client_time + 3.5,
  44.                         $te_body = Native_Random( 0, $te_framemax )
  45.                 )
  46.                 // Now fire bullets
  47.                 $start = $origin;
  48.                 $end = $origin + 8192 * $gun_angles;
  49.                 Native_PerformTrace( $start = $start, $end = $end, $flags = PM_STUDIO_BOX );
  50.                 if ( $trace_fraction != 1.0 )
  51.                 {
  52.                         Native_PlaySoundAtPosition( $origin = $trace_endpos, $sound = weapons/bullet_hit1.wav );
  53.                         Native_ImpactParticles( $origin = $trace_endpos );
  54.                         Native_PlaceDecal( $origin = $trace_endpos, $decal = "{shot2", $trace_entity );
  55.                 }
  56.         }
  57. }
复制代码
参与人数 1金币 +5 +5 收起 理由
K!tteN + 5 + 5 谢谢
发表于 2010-5-13 11:12:27 | 显示全部楼层
是1.1 版本的问题吗?
我在帖子里说的已经很详细了
那里的问题就到相关的帖子里说明原因
以后另开的帖子一律删除
发表于 2010-5-13 11:46:33 | 显示全部楼层
小K不要冲动~冲动是魔鬼啊
发表于 2010-5-13 12:24:13 | 显示全部楼层
K已经不小了,比K大的也就A、2和大小王了
发表于 2010-5-13 12:31:07 | 显示全部楼层
putao  陕西的挖坑3最大 没King
发表于 2010-5-13 13:47:21 | 显示全部楼层
有些地图就这样
