查看: 3353|回复: 44
extreme/hard比赛开始了!
 火.. [复制链接]
发表于 2010-5-9 09:00:21 | 显示全部楼层 |阅读模式
Fourteen people signed up to our ladder and now it is full and ready to start.
1st matchday:
Adantoud vs. KeltA
zhady vs. M@UGLI
akkord vs. rEs0LuTe
chrizZo vs. niki
w1zz vs. Skizo_
MepH vs. Memories
Z0ck3rOO7 vs. ShoCk
Mappool:
imao_darkcavern ; KZ_kzdk_templebhop_h ; kz_sandblock ; mto_desolate_h ; kz_cg_extreme
The results of the first matchday will be released on 15.5.2010. All demos will hopefully be available and during the week the matches will be played on various server. Maybe you are lucky and some matches are played on our cup server and you can enjoy them live on the hltv! Also, m0ver will code a little site for the league, where the whole matchplan, the matches from each matchday and the rankings are written down.
顺便翻译了一下,请英语达人指教
共有14个人报名参加,比赛可以开始了
第一比赛日:
Adantoud vs. KeltA
zhady vs. M@UGLI
akkord vs. rEs0LuTe
chrizZo vs. niki
w1zz vs. Skizo_
MepH vs. Memories
Z0ck3rOO7 vs. ShoCk
地图:
imao_darkcavern ; kz_kzdk_templebhop_h ; kz_sandblock ; mto_desolate_h ; kz_cg_extreme
比赛结果会在2010.5.15发布。这周内比赛将会在各个服务器进行,有些是在我们的cup服务器进行的,幸运的话你可以用hltv现场观看他们的表演。mOver也会为此次比赛开设一个小板块,有关比赛策划,每个比赛日的情况以及排名都会写在里面。
还有一部分是参赛者必读的,我就不转了
发表于 2010-5-9 09:11:02 | 显示全部楼层
zhady 必赢!!!  。。。。。。。。。
发表于 2010-5-9 09:40:41 | 显示全部楼层
我们 能亲临现场?
发表于 2010-5-9 09:42:56 | 显示全部楼层
KeltA  zhady  rEs0LuTe  chrizZo   Skizo_  MepH  Z0ck3rOO7
比赛结果就是以上这几位赢了,
发表于 2010-5-9 10:05:34 | 显示全部楼层
Z0ck3rOO7
神龙那
发表于 2010-5-9 10:06:28 | 显示全部楼层
支持咯,
随便问下 能在赛盟里看到吗?
发表于 2010-5-9 10:20:36 | 显示全部楼层
ZOck3r007
我希望他赢
发表于 2010-5-9 10:32:37 | 显示全部楼层
zhady.....
  • 签到天数: 2 天
    发表于 2010-5-9 10:40:47 | 显示全部楼层
    kz_cg_xtreme直接给zhady准备的吧
    发表于 2010-5-9 10:44:34 | 显示全部楼层
    我看好memories
