查看: 1792|回复: 20
Hard and extreme maps league
发表于 2010-5-6 00:15:03 | 显示全部楼层 |阅读模式
In our forum the first league was already created and now it is time that a second one follows. The speciality about this league is, that it is all about hard and extreme maps.
You can look at the mappool in our additional news. The matches will be played in a 1on1 system with a best of 5 modus. The league has 8 open slots and it is meant that only world record holders (or former record holders with more than one world record) can sign up. We want to create a league now where the best KZ players can play against each other on very difficult maps.
That is why I want to ask all the good players out there to participate. Do not hesitate to sign up because you are afraid of losing in cup matches. This is the beginning of live matches and finally the attention will not only lie on world records. Make it happen.
Joining the league requires responsibility. You have to take care of all your issues and affairs and the admins will not spend more time than they have to do. Please try to cooperate as good as you can to let this happen.
If you want to know the requirements for joining and the rules, read the extended newspost. Also you can have a look at this forum thread where we already started to play 1on1 matches. If you have any questions regarding the system I suggest to take a look at the forum first.
Our beloved admin m0ver currently codes something useful for our league. He will create tables and match overviews with a lot of statistics and useful information.
Since a league with rankings is hopefully more exciting than the world record business, we will maybe accompany the matchdays with some written articles, interviews and good information.
Eight slots are available now. You can sign up in comments or via a private message to me.
If not enough players sign up for this league we can switch to another mappool of course.
Players
w1zz
zhady
rEs0LuTe
akkord
M@UGLI
MepH
How to participate in that league?
Finally we managed to create a league, but it is still based on manual admin work.
Not like on other professional sites everything works automatically...
To participate you need to be able to organize and talk English. Admins will not take care of everything, you will be the one who has to handle your own matches. Participation needs responsibility.
Sign up
For signing up you need to give us your steamID. At the moment you sign up you have assured us you are able to handle everything on your own. If the admins have to do extra work, because you are not able to take care of your own affairs, you can be excluded any time. All matches you play will be logged and released on XJ, as well as the demos of these matches. With signing up you agree that you will release all demos to the public.
Requirements to participate
1. You need to be mature enough to talk to every opponent out there. You need to be able to upload files (demos) and you are willed to spend some time in organizational activities.
2. You need to have a lan or internet server you have full access to. The server needs to be accessible through the internet.
3. If you can not forward ports etc., you will install the “Hamachi Client” to play against other opponents.
4. You need to be able to set up your lan or internet server properly. Two certain plugins are needed to participate: mpbhops and a cup plugin.
5. You are aware of the fact that cheating in a ladder has a permanent ban as a consequence.
6. You can manage to find some time for one match (BO5 -> ~35 minutes ingame) each week. You have to be around and you need to be motivated to find a certain time with your opponent where both of you can play the match.
Rules for 1on1 matches in the first league
A match takes place on 5 different maps (Best Of 5)
For every won map you earn a point.
Matches are played with a cup plugin. The time of a cup is always 5 minutes (standard).
Both players need to record demos on every single map. If you don't record a demo on one map you lose (your opponent can accept the real result though, but at least one demo has to exist, otherwise the match is invalid).
A hltv demo can replace all in-eye demos.
Mappool for the league
bn_tombbhop
cg_brick
j2s_4tunnels
kzarg_infinitefall
kzno_xtremeblock
kzsca_broken
kzsca_burrow
kzsca_burrow[grass_rocks]
kzsca_burrow[red_bricks]
kz_1man_understock
kz_a2_bhop_corruo_h
kz_cg_extreme
kz_cruiser
kz_cxg_jekyll
kz_dimblock
kz_exodus_hard
kz_j2s_sunblock
kz_kzdk_templebhop_h
kz_kzfr_haunted
kz_kzfr_rabbithighway[+1337]
kz_kzfr_rabbithighway[-1337]
kz_kzj_tech
kz_kzhu_jail
kz_kzlv_wanderer
kz_kzlt_dementia[-tranquillity]
kz_kzlt_dementia[+tranquillity]
kz_kzsca_mineblock
kz_kzsca_research
kz_kzse_dustbhop_h
kz_kzse_natureblock[hard]
kz_kzse_towerblock_h
kz_sandblock
kz_sandblock 2
kz_xj_3ways[extreme]
kz_xj_mounthard
mto_desolate_h
mto_greencave
prochallenge_bhop
risk_compound (real way, without ANY scs)
risk_xtrm_weaponsfactory
(not)kz_synergy_x
imao_darkcavern
kzcn_mahjong
kzru_pharaonrun
kzsca_dawn
kzsca_crazyblock
kz_xj_caseblock_h
kz_tomb
kz_kzsca_oasis
kz_ea_beneath_h
kz_cg_xtremedesert
cg_oldtexas
1v1 比赛?
求翻译
参与人数 1金币 +7 +7 收起 理由
SiMen.Net``` + 7 + 7 辛苦辛苦
发表于 2010-5-6 00:15:36 | 显示全部楼层
楼主复制辛苦了,鼓掌
发表于 2010-5-6 00:18:43 | 显示全部楼层
这种新闻不发也罢
发表于 2010-5-6 00:19:28 | 显示全部楼层
还以为是广告。。 看到BB回复  赶紧跟上瞧瞧
发表于 2010-5-6 00:22:16 | 显示全部楼层
给哥翻译下
    昨天 08:37
  • 签到天数: 541 天
    [LV.9]以坛为家II
    发表于 2010-5-6 01:08:48 | 显示全部楼层
    没翻译悲剧鸟
    发表于 2010-5-6 01:54:11 | 显示全部楼层
    复制的东西也发上来
      又不翻译
         SB 和威望不是那么好拿的
    发表于 2010-5-6 02:20:38 | 显示全部楼层
    楼主是来求翻译的
    发表于 2010-5-6 08:51:52 | 显示全部楼层
    求中文版,有的给分
    发表于 2010-5-6 09:34:28 | 显示全部楼层
    哇。。全是 英个类序
