楼主: Pepent
哈哈, 西游记噢``看下
发表于 2010-5-5 11:02:53 | 显示全部楼层
楼主,又看见你在上网了。你怎麼总在网上呀,你的学习任务完成了吗?你父母不为你著急吗?
如果你是中学生,你应该为你父母想一想,父母养育你不容易,你不完成学习任务就上网,你父母和老师会为你担心的.你万万不能被计算机和网络给害了!你应当快快走出来!投入到学习中去!
如果你是大学生,你就该多多为自已著想啊,现在社会竞争压力这麼大,你要是不努力提高自已的知识文化素养,不努力增强自已的专业技能,以后你在社会上要怎麼立足啊,你切记一定不要沉迷於网络啊,赶快从虚拟世界中走出来,面向太阳,拥抱未来啊!
如果你已经大学毕业了,那你就更加不能天天在网络的虚拟世界里麻痹自已啊,你要努力工作,加紧*,买房买车,养老婆父母孩子啊...你千万不要自暴自弃啊,要学会在现实生活中独立自主,自信坚定地生活下去.不要再在网络里面欺骗自已了,大胆地抛弃电脑,向社会说我来了!
你如果有什麼想不通的问题可以告诉我。我帮你解决.
LZ, do you see in the Internet. The total on-line you how you, your mission to learn it? Your parents do not worry you?
If you are a middle school, you should think about your parents, yourparents bring up is not easy, you do not complete the task of learningon the Internet, you will be for parents and teachers worried aboutyou. You must not be harmful to computers and the Internet! You shouldcome out as soon as possible! Into the study to!
If you are a university student, on your own for the sake of more, ah,now so much pressure on the playing field, if you have done little toimprove the knowledge of their own culture, in the absence of effortsto enhance their professional skills in the future you want in thecommunity based on how ah, Remember that you must not indulge in thenetwork ah, as soon as possible from the virtual world to come out andface the sun, embrace the future ah!
If you have a university graduate, you can not even every day in thevirtual world of their own paralysis ah, you have to step up efforts tomake money, buy a car, wife and parents raising children ... ah ah youshould never give up on themselves , They should learn in real life ofindependence, self-confidence to live the firm. Not to deceivethemselves inside the network, boldly discard computers, to thecommunity that If you fail to figure out what problems I can tell. I help you solve.
LZ 、オンラインで见ることができます。上の合计どのようにして、お客様のミッションにご覧いただくために行?ご両亲は心配しないのですか?
中学校の场合は、ご両亲の详细については、ご両亲を持ち出す场合は、インターネット上での学习のタスクを完了しないと容易ではない场合、亲と教师のためになることを心配する必要があります。あなたのコンピュータに、インターネットの有害されてはならない!できるだけ早く出てくる必要があります!の研究に!
场合は、大学の学生は、自分でのためには、ああ、运动场にするほどの圧力、もしあなたの努力は、将来どのようにああ、コミュニティに基づいて欲しいでプロのスキルを强化するための不在で独自の文化の知识を改善するため、小さな続けてきた、その场合は、ネットワークのアーでは、可能な限り早急には、仮想世界から出てくるし、太阳が颜を、将来はああふける受け入れる必要があります
 楼主| 发表于 2010-5-5 15:40:57 | 显示全部楼层
回复 11# dsm635625
楼上,又看见你在上网了。你怎麼总在网上呀,你的学习任务完成了吗?你父母不为你著急吗?
Поднявшись наверх, они видят вас в сети. Как всегда он-лайн Да, вы узнаете, задача сделать? Разве не ваши родители беспокоятся о вас?
Если вы студенты, вы должны думать о родителях, воспитания детей не так легко, вы не должны заполнять задача обучения по Интернету, ваших родителей и учителей для вас беспокоиться. Ты не должен быть компьютер и Интернет для навреди! Вы должны вытащить его! На ваших исследований!
Если вы студент, вам следует больше за свои собственные ах ради, в настоящее время такой конкурентной общества, если вы не работаете над улучшением своих собственных знаний и воспитания, а не работать для повышения своих профессиональных навыков, так как вы находитесь в обществе, каким, ах, Помните, что вы не должны предаваться сети ах, скорей выйти из виртуального мира, лицом к солнцу, охватывать в будущем, ах!
Если вы уже закончил колледж, то вам лучше не каждый день виртуальном мире сети паралич собственной ах, вы должны упорно работать, наращивать *, автомобиль или дом, жена, родители, дети ... вы не сдавайтесь на себя ай, ай, В реальной жизни, научиться самостоятельности, уверенности в себе, чтобы жить сильным. Не обманывайте себя в сети, который смело отказался от компьютера, к сообществу, что я приду!
Если у вас есть какие-либо вопросы, не может меня понять. Я могу помочь вам решить.
瑞典
Övervåningen, de ser dig online. Hur du alltid on-line Ja, lär du dig uppgiften gjort? Är inte dina föräldrar oroliga för dig?
Om du är studerande, bör du tänka på dina föräldrar, är föräldraskap inte lätt för dig, du behöver inte fylla i lärandet uppgift på Internet, dina föräldrar och lärare för dig att oroa sig för. Du får inte dator och Internet till skada! Du bör dra sig ur det! I dina studier!
Om du är en college student bör du fundera mer för sin egen skull ah, nu finns ett konkurrenskraftigt samhälle, om du inte arbetar hårt för att förbättra sin egen kunskap och utbildning, inte arbeta hårt för att förbättra sin professionella kompetens, eftersom ni är baserade i samhället om hur, ah, ihåg att du måste inte hänge oss åt i nätverket ah, bråttom att komma ut från den virtuella världen, mot solen, omfamna framtiden, ah!
Om du redan har examen från college, då du bättre inte varje dag nätverkets virtuella världen pares egen ah, måste du jobba hårt, öka *, en bil eller hus, hustru, föräldrar, barn ... du inte ger upp sig själva ah, ah, I verkliga livet, att lära sig självständighet, självförtroende att leva stark. Lura inte sig i nätverk som djärvt övergavs datorn, för samhället att jag kommer!
Om du har några frågor kan inte förstå mig. Jag kan hjälpa dig med.
棒子
위층에, 그들은 당신이 온라인으로를 참조하십시오. 어떻게 당신은 항상 온라인 그래요, 당신은 작업이 다 배웠지? 부모님이 당신을 걱정 아닌가요?
당신은 학생들이있다면, 당신은 부모님 생각한다, 양육 당신에게 쉽게, 당신은 인터넷에, 당신은 걱정을위한 부모와 교사를 학습 작업을 완료하지 않습니다. 당신은 컴퓨터와 인터넷 피해해서는 안됩니다! 당신은 그것을 당겨 야지! 로 공부!
당신이 대학생있다면 당신은 지역 사회에 기반부터 열심히 열심히 자신의 전문 능력을 향상시키기 위해 작동하지 않을 자신의 지식과 교육, 개선을 위해 작동하지 않는 경우, 당신은 자신의 술 아에, 지금과 같은 경쟁 사회를 더 고려해야하는 방법, 아, 당신은 네트워크 아에, 서둘러 가상 세계에서 나오기 탐닉해서는 안됩니다, 태양을 마주보고 기억,, 아 미래를 포옹!
당신은 이미 대학, 그럼 매일은 네트워크의 가상 세계가 마비 아를 소유하고 더 좋지 않다 졸업있다면, 당신은 열심히, *, 차 또는 집을 나서고, 아내, 부모, 아이 ... 당신은 자신에, 어 어 포기하지 마,이 실제, 자신감을 강하게 살 독립을 참조하십시오. 담대하게 컴퓨터를 버려진 네트워크에 자신을 속이지, 내가 간다 지역 사회를 위해하지 마!
당신은 질문이 이해 못하실 수 있습니다. 난 당신이 해결할 수 있습니다.
Im Obergeschoss finden Sie sie online. How do you immer on-line Yeah, lernen Sie die Aufgabe erledigt? Sind deine Eltern Sorgen um dich?
Wenn Sie Schüler sind, sollten Sie über Ihre Eltern denken, ist nicht leicht, Kindererziehung, du nicht vollständig die Lernaufgabe über das Internet, Ihre Eltern und Lehrer für Sie zu kümmern. Sie müssen keine Computer und Internet zu schaden! Sie sollten aus ihm ziehen! In Ihrem Studium!
Wenn Sie ein Student sind, sollten Sie mehr um ihrer selbst willen ah betrachten, jetzt so eine wettbewerbsfähige Gesellschaft, wenn du nicht hart arbeiten, um ihr Wissen und ihre Bildungs-, verbessern nicht hart arbeiten, um ihre beruflichen Fähigkeiten zu verbessern, da Sie in der Gemeinschaft beruhen, wie, äh, Denken Sie daran, Sie müssen nicht in das Netzwerk ah frönen, eilig zu kommen aus der virtuellen Welt, vor der Sonne, die Zukunft zu umarmen, ah!
Wenn Sie bereits das College abgeschlossen haben, dann besser nicht jeden Tag das Netzwerk der virtuellen Welt Lähmung eigenen Ah, Sie haben hart daran arbeiten, step up *, ein Auto oder ein Haus, Frau, Eltern, Kinder ... Sie geben nicht auf sich selbst ah, ah, Im wirklichen Leben zu lernen, Unabhängigkeit, Selbstvertrauen zu leben stark. täuschen sich nicht in das Netzwerk, das kühn den Computer verlassen wurde, an die Gemeinde, dass ich komme!
Wenn Sie Fragen haben, können mich nicht verstehen. Ich kann Ihnen helfen zu lösen.
法A l'étage, ils vous voient en ligne. Comment pouvez-vous toujours en ligne Ouais, vous découvrez la tâche est accomplie? Ne sont pas vos parents s'inquiètent pour toi?
Si vous êtes étudiants, vous devriez penser à vos parents, la parentalité n'est pas facile pour vous, vous ne remplissez pas la tâche d'apprentissage sur Internet, vos parents et les enseignants pour vous inquiétez pas. Vous ne devez pas être un ordinateur et Internet de nuire! Vous devez sortir de celui-ci! Dans vos études!
Si vous êtes un étudiant, vous devriez envisager de plus pour leur Ah-même, maintenant une société compétitive, si vous ne travaillez pas dur pour améliorer leurs propres connaissances et d'éducation, pas d'efforts pour améliorer leurs propres compétences professionnelles, puisque vous êtes basé dans la communauté à la façon dont, ah, N'oubliez pas que vous ne doit pas se livrer à l'ah réseau, pressé de sortir du monde virtuel, face au soleil, embrasser l'avenir, ah!
Si vous avez déjà obtenu un diplôme collégial, alors il vaut mieux pas tous les jours le monde virtuel du réseau paralysie propres ah, vous avez à travailler dur, d'intensifier *, une voiture ou une maison, femme, parents, enfants ... vous ne donnez pas sur eux-mêmes ah, ah, Dans la vie réelle, à savoir l'indépendance, la confiance en soi pour vivre fort. Ne pas se tromper dans le réseau qui a été abandonnée hardiment l'ordinateur, à la communauté que je viens!
Si vous avez des questions ne peuvent pas me comprendre. Je peux vous aider à résoudre.
 楼主| 发表于 2010-5-5 15:45:50 | 显示全部楼层
靠,............
