查看: 1275|回复: 10
哈哈,26被举例了.
发表于 2010-4-17 04:59:02 | 显示全部楼层 |阅读模式
http://www.cosy-climbing.net/comment.php?comment.news.237
CC两项新规定,一些数据插件被禁用. 26 的KZcn_simen_bunnyhop_v3记录好像被暂时取消了.
Hello guys.
From today we have decided to add two new demo rules.
1.You are NOT allowed to use this plugin that shows the yellow line in fpsDeath. If you are using this plugin please remove it. We are adding this new rule because no one knows what advantages is giving. -link- Also you can read about it here -link-
2.You are NOT allowed to use the plugin which shows the prestrafe everytime you jump.With this plugin you know if you have to strafe or not to get a bhop pre .If you are using this plugin please remove it.You can see 26 using this plugin in his demo on kzcn_simen_bunnyhop_v3
The name of the bhop plugin(s) is(are):
jump_framework.amxx
jump_prestrafe.amxx
jump_distance.amxx
Thanks to: Nikola, SLAYER.kkz and WeMeRA
不说,看看kzcn_simen_bunnyhop_v3先,,,,26还没跳到25秒.
发表于 2010-4-17 07:03:43 | 显示全部楼层
          - - . 太...
发表于 2010-4-17 07:48:08 | 显示全部楼层
shnz也用過啦....我*
发表于 2010-4-17 07:58:02 | 显示全部楼层
唉。。。不懂 英葛类序 555555
发表于 2010-4-17 08:23:25 | 显示全部楼层
典型人物,小2b
发表于 2010-4-17 08:52:35 | 显示全部楼层
有新规则了~
发表于 2010-4-17 10:08:01 | 显示全部楼层
怎么没中文版啊
发表于 2010-4-17 10:20:52 | 显示全部楼层
从今天起,我们决定增加两个新的demo规则。
不再允许使用显示fpsDeath黄线的插件。如果你还在使用这个插件,请删除它。我们正在增加这一新的规则,是因为没有人知道使用这些插件跳图中会会出现什么优势。
不再允许使用的插件,显示了你每次跳跃的横向速度这个插件,With this plugin you know if you have to strafe or not to get a bhop pre(啥意思求解??有了这个插件,你知道什么时候你要扫射或什么时bhop??) 。如果你正在使用这个插件,请删除.
大家可以看看26使用这个插件t跳的 kzcn_simen_bunnyhop_v3
插件名称:
jump_framework.amxx
jump_prestrafe.amxx
jump_distance.amxx
发表于 2010-4-17 11:26:37 | 显示全部楼层
横扫BHOP?
    发表于 2010-4-17 12:24:29 | 显示全部楼层
    显示bhop pre?
    就是下面那个298.***?
