查看: 1295|回复: 11
[又是愚人节玩笑] XJ新闻
发表于 2010-4-2 16:11:48 | 显示全部楼层 |阅读模式
http://xtreme-jumps.eu/news.php?extend.1213
新闻发表于:
Posted by faker on 04/01/10 - 18:47:09
Furthermore there were other sad developments in the last few days, we're going to inform you about details and the full story within the next days. This is also involving two well known (and well respected) people of this community and will be the day when they will have to say good bye from this community for ever. For now, all I can reveal is the new set of rules which will make sure that something like this will never ever happen again:
New set of rules:
You are NOT allowed to use metamod or AMXX plugins in your record demos in any way!
这篇xj新闻主要说了2个demo录制规则:
1. demo的时间快慢只取决于前2个小数点 (第3个小数位0.00x 无视, 如同时有2个时间一样的demo上传则上传较早的优胜)
2. 也就是上面那句英文粗体: demo的录制不能使用任何metamod/amxx 的插件
跟一段附带的讯息, 也就是我上面引用的那一段:
意思是说过去几日发生令人伤感的事件, 而xj 将会几日内把这件事详细公开。  这件事件涉及2位xj受尊敬的人物, 而这2位将要永远对整个xj社群说再见。也因为这件事, xj将设立以上2个规则避免同类事情再次发生!
-最后还是另一个愚人节玩笑!!-
参与人数 2金币 +9 +9 收起 理由
fantasist + 8 + 8 鼓励分享
larNe + 1 + 1 规则太多
    发表于 2010-4-2 16:14:14 | 显示全部楼层
    已经看过了
    amxx文件删光..
    但愿希望这是愚人节玩笑
    发表于 2010-4-2 16:16:04 | 显示全部楼层
    针对谁的?
    发表于 2010-4-2 16:17:07 | 显示全部楼层
    amxx2.1都不能用了?
    发表于 2010-4-2 16:20:00 | 显示全部楼层
    发表于 2010-4-2 16:20:04 | 显示全部楼层
    出来跳 腿总是要断的
     楼主| 发表于 2010-4-2 16:40:22 | 显示全部楼层
    回复 4# SiMen.26
    应该是的..
    开游戏的时候可能要在控制台打上amx_off了
    再多等几天吧
    发表于 2010-4-2 17:08:51 | 显示全部楼层
    暂时不明白
    发表于 2010-4-2 17:13:49 | 显示全部楼层
    在过些时看看情况
    发表于 2010-4-2 19:25:11 | 显示全部楼层
    LZhen hao,很强大。
