查看: 1311|回复: 8
【已解决】 急啊!!!!!!求助,域名纠错系统
发表于 2010-3-17 12:00:47 | 显示全部楼层 |阅读模式
http://bhlmcs16.s1.fyzzz.com/bbs/index.php   这个网站我原来还可以进 但是最近一打开就无法显示网页
我刚才又把cookies和其他的什么全部清理了一遍
我家是铁通的
发表于 2010-3-17 12:03:52 | 显示全部楼层
可以打开...
把index.php去掉看看
发表于 2010-3-17 13:21:54 | 显示全部楼层
填写当地DNS服务协议,调整网址,或设置问题,修复IE.
或直接command:键入ipconfig/flushdns
例如:
Microsoft Windows XP [版本 5.1.2600]
(C) 版权所有 1985-2001 Microsoft Corp.
C:\Documents and Settings\承诺爱>ipconfig
Windows IP Configuration
Ethernet adapter 本地连接:
        Connection-specific DNS Suffix  . :
        IP Address. . . . . . . . . . . . : 192.168.1.254
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        Default Gateway . . . . . . . . . : 192.168.1.1
PPP adapter 宽带连接:
        IP Address. . . . . . . . . . . . : 110.*.*.249
        Subnet Mask . . . . . . . . . . . : 255.255.255.255
        Default Gateway . . . . . . . . . : 110.*.*.249
C:\Documents and Settings\承诺爱>ipconfig /?
USAGE:
    ipconfig [/? | /all | /renew [adapter] | /release [adapter] |
              /flushdns | /displaydns | /registerdns |
              /showclassid adapter |
              /setclassid adapter [classid] ]
where
    adapter         Connection name
                   (wildcard characters * and ? allowed, see examples)
    Options:
       /?           Display this help message
       /all         Display full configuration information.
       /release     Release the IP address for the specified adapter.
       /renew       Renew the IP address for the specified adapter.
       /flushdns    Purges the DNS Resolver cache.
       /registerdns Refreshes all DHCP leases and re-registers DNS names
       /displaydns  Display the contents of the DNS Resolver Cache.
       /showclassid Displays all the dhcp class IDs allowed for adapter.
       /setclassid  Modifies the dhcp class id.
The default is to display only the IP address, subnet mask and
default gateway for each adapter bound to TCP/IP.
For Release and Renew, if no adapter name is specified, then the IP address
leases for all adapters bound to TCP/IP will be released or renewed.
For Setclassid, if no ClassId is specified, then the ClassId is removed.
Examples:
    > ipconfig                   ... Show information.
    > ipconfig /all              ... Show detailed information
    > ipconfig /renew            ... renew all adapters
    > ipconfig /renew EL*        ... renew any connection that has its
                                     name starting with EL
    > ipconfig /release *Con*    ... release all matching connections,
                                     eg. "Local Area Connection 1" or
                                         "Local Area Connection 2"
C:\Documents and Settings\承诺爱>ipconfig/flushdns
发表于 2010-3-17 14:34:20 | 显示全部楼层
排除病毒、流氓软件
有可能跟你电脑无关
我这里能正常浏览
PS:LS疯了
发表于 2010-3-17 14:42:44 | 显示全部楼层
1-3 L
皆高人
    发表于 2010-3-17 15:30:19 | 显示全部楼层
    3L......疯了- -
    发表于 2010-3-17 17:06:20 | 显示全部楼层
    无法定位远程服务器
    您试图访问的地址 http://bhlmcs16.s1.fyzzz.com/bbs/index.php 目前不可用。请确保网址(URL)拼写和标点符号使用都正确,然后试着重新载入页面。
     楼主| 发表于 2010-3-17 20:21:58 | 显示全部楼层
    回复 3# Pledges
        怎么弄啊?
    我没看懂 - -  能加我QQ帮我弄下吗 谢谢了
    332646283
    发表于 2010-3-25 10:12:46 | 显示全部楼层
    问题已经解决,接下来的图片等无法正常浏览请下载更新 FLASH player  ActiveX
