查看: 1123|回复: 9
插件求助。 关于fantasist整合插件
发表于 2010-1-25 04:47:56 | 显示全部楼层 |阅读模式
我下了fantasist的整合插件后 装在指定文件夹内。跟装了以前一样。没有weapon转换。没有各种功能。请问是怎么搞的呢? 困惑
发表于 2010-1-25 04:52:47 | 显示全部楼层
我的帖子里写了可能出现的问题及解决方案,试过没有?
 楼主| 发表于 2010-1-25 05:06:30 | 显示全部楼层
都试过了。 没有。还有就是不明白amx平台版本是什么意思。我都不知道自己的版本
发表于 2010-1-25 05:22:39 | 显示全部楼层
如果直接解压整合插件到相应文件夹,应该不用管amxx平台版本
你新建一个游戏,把控制台里的信息全部复制过来看看
 楼主| 发表于 2010-1-25 05:55:17 | 显示全部楼层
NET Ports:  server 27015, client 27005
Server IP address 169.254.110.250:27015
   Metamod version 1.19p31 Copyright (c) 2001-2006 Will Day
     Patch: Metamod-P (mm-p) v31 Copyright (c) 2004-2007 Jussi Kivilinna
   Metamod comes with ABSOLUTELY NO WARRANTY; for details type `meta gpl'.
   This is free software, and you are welcome to redistribute it
   under certain conditions; type `meta gpl' for details.
   AMX Mod X version 1.76d Copyright (c) 2004-2006 AMX Mod X Development Team
   AMX Mod X comes with ABSOLUTELY NO WARRANTY; for details type `amxx gpl'.
   This is free software and you are welcome to redistribute it under
   certain conditions; type 'amxx gpl' for details.
L 01/25/2010 - 06:07:34: -------- Mapchange to kz_kzdk_kosovo --------
L 01/25/2010 - 06:07:34: [AMXX] Plugin file open error (plugin "weapons.amxx")
[AMXX] Loaded 1 admin from file
Executing AMX Mod X Configuration File
Scrolling message displaying frequency: 10:00 minutes
L 01/25/2010 - 06:07:36: [AMXX] Language key "UNKNOWN_CVAR" not found for language "cn", check "admincmd.amxx"
L 01/25/2010 - 06:07:36: [admin.amxx] Login: "miki .Mm <str><1><VALVE_ID_LOOPBACK><>" became an admin (account "loopback") (access "abcdefghijklmnopqrstu") (address "loopback")
L 01/25/2010 - 06:07:36: [AMXX] Language key "PRIV_SET" not found for language "cn", check "admin.amxx"
This server is running Hook Mod v5 by:
Drunken F00l (drunkenf00l@hotmail.com) - http://www.adminop.net
* Privileges set
BUILD 3647 SERVER (0 CRC)
Server # 1
L 01/25/2010 - 06:07:38: [admin.amxx] Login: "miki .Mm <str><1><VALVE_ID_LOOPBACK><>" became an admin (account "loopback") (access "abcdefghijklmnopqrstu") (address "loopback")
L 01/25/2010 - 06:07:38: [AMXX] Language key "PRIV_SET" not found for language "cn", check "admin.amxx"
miki .Mm <str> 进入游戏连接中...
Couldn't open file overviews/kz_kzdk_kosovo.txt. Using default values for overiew mode.
 楼主| 发表于 2010-1-25 05:58:40 | 显示全部楼层
有什么问题吗。要不我加你Q 你帮我看下吧。
 楼主| 发表于 2010-1-25 06:11:12 | 显示全部楼层
Currently loaded plugins:
name               version  author            file             status
Admin Base         1.76d    AMXX Dev Team     admin.amxx       running
Admin Commands     1.76d    AMXX Dev Team     admincmd.amxx    running
Admin Help         1.76d    AMXX Dev Team     adminhelp.amxx   running
Multi-Lingual Sys  1.76d    AMXX Dev Team     multilingual.am  running
Menus Front-End    1.76d    AMXX Dev Team     menufront.amxx   running
Commands Menu      1.76d    AMXX Dev Team     cmdmenu.amxx     running
Players Menu       1.76d    AMXX Dev Team     plmenu.amxx      running
Teleport Menu      1.76d    AMXX Dev Team     telemenu.amxx    running
Maps Menu          1.76d    AMXX Dev Team     mapsmenu.amxx    running
Admin Chat         1.76d    AMXX Dev Team     adminchat.amxx   running
Scrolling Message  1.76d    AMXX Dev Team     scrollmsg.amxx   running
Info. Messages     1.76d    AMXX Dev Team     imessage.amxx    running
Admin Votes        1.76d    AMXX Dev Team     adminvote.amxx   running
Pause Plugins      1.76d    AMXX Dev Team     pausecfg.amxx    running
LjS - eXtreme Mod  2.2b7 L  Fatalis & Numb &  kz_ljs_xm.amxx   running
Xtreme-Jumps       1.0      Fatalis           xtreme-jumps.am  running
unknown            unknown  unknown           weapons.amxx     bad load
17
发表于 2010-1-25 07:55:14 | 显示全部楼层
说明你的amxx平台是1.76d版本,估计你解压错地方了吧,否则肯定是1.8.1
发表于 2010-1-25 09:58:52 | 显示全部楼层
插件。。真高深。。
发表于 2010-1-25 10:54:12 | 显示全部楼层
一看就是压错地方
