查看: 652|回复: 7
谁能给下录制WR的基本设置
发表于 2010-1-15 19:59:42 | 显示全部楼层 |阅读模式
RT谢谢 1231312312
发表于 2010-1-15 20:02:22 | 显示全部楼层
// Settings
    * Demos must be done with these settings:
      Serversettings:
      edgefriction "2"
      mp_footsteps "1"
      sv_cheats "0"
      sv_gravity "800"
      sv_airaccelerate "10"
      sv_maxspeed "320"
      sv_stepsize "18"
      sv_maxvelocity "2000"
      Clientsettings:
      developer "0"
      cl_lw "1"
      fps_max "101"
      You are not allowed to use any cvar or setting that might give you an unfair advantage compared to the default counter-strike settings (just as cl_sidespeed and so on), even if it's not stated in the list above. Keep your config default!
 楼主| 发表于 2010-1-15 20:05:39 | 显示全部楼层
- - 悲剧  无法理解
发表于 2010-1-15 20:06:51 | 显示全部楼层
LZ要刷WR了吗…
发表于 2010-1-15 22:53:18 | 显示全部楼层
不知道我的合不合格呢,
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "0"
ati_subdiv "0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "1"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "40"
cl_cmdrate "101"
cl_corpsestay "600"
cl_crosshair_color "50 250 50"
cl_crosshair_size "auto"
cl_crosshair_translucent "1"
cl_dlmax "768"
cl_download_ingame "1"
cl_dynamiccrosshair "1"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Orange"
cl_logofile "lambda"
cl_lw "1"
cl_minmodels "0"
cl_radartype "1"
cl_righthand "1"
cl_shadows "1"
cl_timeout "35"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "1"
crosshair "1"
fastsprites "0"
fps_max "100"
fps_modem "0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "vip"
MP3FadeTime "2.0"
MP3Volume "0.40"
mp_decals "300"
name "7176153"
net_graph "0"
net_graphpos "0"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "1"
s_a3d "0"
s_automax_distance "30"
s_automin_distance "2"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "8"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "3.000000"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.250000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "0.750000"
volume "2"
setinfo "_dco" "5A9C39CF2AEC7832114E47AE594EB2A0"
setinfo "_uid" "7176153"
+mlook
exec userconfig.cfg
发表于 2010-1-15 22:54:38 | 显示全部楼层
人家要录DEMO的设置,你把自己CFG发出来干啥
发表于 2010-1-15 23:50:22 | 显示全部楼层
bind "F1" "stop;sv_restartround 1;record x"
他要的是这个
发表于 2010-1-16 11:34:35 | 显示全部楼层
又一个WR选手即将诞生
