查看: 1331|回复: 9
编辑器问题。高手帮忙啊。。!~
发表于 2010-1-2 16:15:30 | 显示全部楼层 |阅读模式
编译没错误,编译结束进游戏就出现could not  load library XXXXX(X是乱码)的错误  高手帮忙解决下啊 。。。
发表于 2010-1-2 16:31:19 | 显示全部楼层
什么类库无法载入?
路径问题?
发表于 2010-1-2 16:32:06 | 显示全部楼层
看不懂哦
我没出现这情况
发表于 2010-1-2 16:47:23 | 显示全部楼层
请把编译信息粘贴上来   我看能不能帮你
发表于 2010-1-2 18:14:10 | 显示全部楼层
啥都看不懂
 楼主| 发表于 2010-1-3 08:53:35 | 显示全部楼层
** Executing...
** Command: Change Directory
** Parameters: E:\单机游戏\CS1.6中文版\cstrike
** Executing...
** Command: Copy File
** Parameters: "E:\单机游戏\CS1.6中文版\Worldcraft\cs_jiandan.map" "E:\单机游戏\CS1.6中文版\Worldcraft\cs_jiandan.map"
** Executing...
** Command: E:\单机游戏\CS1.6中文版\Worldcraft\hlcsg.exe
** Parameters: "E:\单机游戏\CS1.6中文版\Worldcraft\cs_jiandan"
hlcsg v2.4.2 rel (Nov  9 2000)
Based on Valve's version, modified with permission.
Submit detailed bug reports to (zoner@gearboxsoftware.com)
-----  BEGIN  hlcsg -----
Command line: E:\单机游戏\CS1.6中文版\Worldcraft\hlcsg.exe E:\单机游戏\CS1.6中文版\Worldcraft\cs_jiandan
-= Current hlcsg Settings =-
Name                 |  Setting  |  Default
threads               [       2 ] [  Varies ]
verbose               [     off ] [     off ]
log                   [      on ] [      on ]
developer             [       0 ] [       0 ]
chart                 [     off ] [     off ]
estimate              [     off ] [     off ]
max texture memory    [ 4194304 ] [ 4194304 ]
priority              [  Normal ] [  Normal ]
noclip                [     off ] [     off ]
onlyents              [     off ] [     off ]
wadtextures           [      on ] [      on ]
skyclip               [      on ] [      on ]
hullfile              [    None ] [    None ]
min surface area      [   0.500 ] [   0.500 ]
brush union threshold [   0.000 ] [   0.000 ]
Wadinclude list :
[zhlt.wad]
Error: Error opening E:\单机游戏\CS1.6中文版\Worldcraft\cs_jiandan.map: No such file or directory
-----   END   hlcsg -----
** Executing...
** Command: E:\单机游戏\CS1.6中文版\Worldcraft\hlbsp.exe
hlbsp v2.4.2 rel (Nov  9 2000)
-----  BEGIN  hlbsp -----
Command line: E:\单机游戏\CS1.6中文版\Worldcraft\hlbsp.exe E:\单机游戏\CS1.6中文版\Worldcraft\cs_jiandan
>> ERRORLOG E:\单机游戏\CS1.err detected, hlbsp processing halted
>> If you have fixed the problem, you can delete the file and rerun hlbsp
-----   END   hlbsp -----
** Executing...
** Command: E:\单机游戏\CS1.6中文版\hl.exe
** Parameters:  +map "cs_jiandan"
 楼主| 发表于 2010-1-3 08:54:45 | 显示全部楼层
就是这个样子  之后 就显示这些英文了 ,我在网上找的  说是某类库加载失败。帮帮忙。。
发表于 2010-1-7 10:26:37 | 显示全部楼层
上面说的是路径错误,你检查下该路径是否有该地图。
还有,尽量不要用中文。因为老外有些软件是无法检测出中文路径的
 楼主| 发表于 2010-1-18 21:24:33 | 显示全部楼层
闷。。我CS1.6的路径就是中文的。。我咋知道!? 老外可恶。。!~
发表于 2010-9-22 09:31:56 | 显示全部楼层
中文路径是没关系的,错在map文件不在这个路径上
