查看: 1933|回复: 17
XJ 新闻。。。
发表于 2010-1-2 05:06:40 | 显示全部楼层 |阅读模式
Hey guys,
I'm sure a lot of people were already waiting for this newspost ever since the LJ section was put down for maintenance, so here we go... finally
Okay, first of all you should have known that non-steam demos are not allowed on XJ. A lot of them were submitted and accepted (because we didn't check that yet), but now (after the LJ section got checked again completely) such demos were removed, of course.
Removed non-steam demos:
EvoLuT1on 255 LJ
Exception 255 LJ
C-WaLKeR` 256 LJ
Neo[a] 256 LJ
Shady 256 LJ
xex` 266 CJ
-=ZiK_Bl0oDR@veN=- 267 CJ
C-Walker` 246 BHOP LJ
Dmitrich! 246 BHOP LJ
EvoLuT1on 246 BHOP LJ
There will be no warnings for this time, since a lot of old demos got accepted due to the fact that LJ records weren't updated for a long long time before and therfore the demos might have been submitted before the non-steam rule got added.
Other than that, there were a few cheatdemos, too.
sn_beachcliff_bisqo_0502 submitted by bisqo: slowmo
256_lj_avatar submitted by А√atar: knifespeed
268_cj_NFS submitted by NFS: knifespeed
256_lj_S3eKeR submitted by S3eKeR: knifespeed
256_lj_arrrrrr submitted by odealo: cl_sidespeed
255_lj_ArN submitted by ArN: mousespeedlimit
-> Note: knifespeed is a new sort of cheat(plugin) that allows the player to move forward with 251 units/s instead of 250 when using a knife, therefore it was called "knifespeed". Even though this sounds like a small advantage it's actually a pretty big one.
 楼主| 发表于 2010-1-2 05:12:19 | 显示全部楼层
几个 No steam dem   几个LJ作弊.. 基本都是 knifespeed   地速有所提高 251/s
还有slowmo
发表于 2010-1-2 05:14:00 | 显示全部楼层
大家好:
自从LJ的部分维护以来,相信很多人都已经等着这次新闻发布,那我们就开始吧...
首先大家都应该知道,XJ是不允许non-steam的demo的。但是很多都被提交接受了,因为我们没有检测,但是现在,在LJ的部分完全恢复以后,这些demo自然会被删除。
non-steam的demo:
EvoLuT1on 255 LJ
Exception 255 LJ
C-WaLKeR` 256 LJ
Neo[a] 256 LJ
Shady 256 LJ
xex` 266 CJ
这次不会  警告,因为LJ记录太久没有更新,很多demo是在这之前很久上传的,然而那时候还没有加上关于non-steam的规则。
除此之外,还有一些作弊的demo。
->knifespeed是一种新的作弊方法(插件),它允许玩家使用刀在向前的时候达到251 units/s的速度,因此被称为“knifespeed”。它听上去像是一个很小的优势,而事实上是非常大的!
发表于 2010-1-2 06:50:38 | 显示全部楼层
楼主复制辛苦了,不过连扩展新闻都不复制过来也太那个啥了吧
 楼主| 发表于 2010-1-2 06:54:51 | 显示全部楼层
那个啥。。对话太长了。。就没复制。
既然你诚信。诚意的问了。。。那我就大发慈悲的告诉你:  xxxxxx
Statement by S3eKeR:
S3eKeR: okay hello
[XJ] ndR`: hello back
S3eKeR: i left on irc , so , i have quitted kz already and i feel like bad for doing this
S3eKeR: me , avatar , nfs cheated our demos.
[XJ] ndR`: ok
S3eKeR: we used an illegal plugin that changes the speed of the knife/usp for better prestrafe/distance
[XJ] ndR`: first of all, that's better that you come and confess
S3eKeR: i did this because avatar and nfs said if i ever get caught now to say about them
S3eKeR: and i felt so dissapointed and removed them and went to confess.
S3eKeR: not*
S3eKeR: the plugin was made by NFS and proton
[XJ] ndR`: who's this proton?
S3eKeR: i had the idea of making this after i was was so suspicious on kelta for this.
S3eKeR: i dont know
S3eKeR: i dont know
S3eKeR: he said so
S3eKeR: then we got it to work and even get stats on it
S3eKeR: we didnt use to high values , 251 or even 252 knifespeed was enough to gain kinda big advantage.
S3eKeR: then i sent the plugin to avatar
S3eKeR: he did couple of 256 and finally decided to upload xj like we did
S3eKeR: so what more to add ndr , i told the story
S3eKeR: what else to say , what's neccesary
[XJ] ndR`: right
S3eKeR: just say me what information u need
[XJ] ndR`: You got nothing else to add?
S3eKeR: hmm
S3eKeR: i think kelta is using this
[XJ] ndR`: did one of you give the plugin to anybody else?
S3eKeR: no
[XJ] ndR`: why do you think that?
S3eKeR: hey can share it after they get banned tho
S3eKeR: i can help making anticheat of it
[XJ] ndR`: could you give me this plugin?
S3eKeR: im not good in coding anyways , i can just give the plugin , and tell it hows it works
S3eKeR: okay let me see if i still have it
S3eKeR: just the plugin
S3eKeR: or whole addons?
S3eKeR: by the way we got it to work with different values
S3eKeR: even on 260 speed of knife we would get stats
S3eKeR: i dont havae the latest version of it cuz i quitted kz
S3eKeR: but i have the first one
[XJ] ndR`: I'd like it please
S3eKeR: hold up
S3eKeR: but just a little question ndr
S3eKeR: do u think anybody had any chance detecting this?
[XJ] ndR`: tell me
[XJ] ndR`: The thing I was going to tell you at the end of our conversation is that
[XJ] ndR`: we had already busted you all
S3eKeR: lol is it
S3eKeR: no bullshit right?
[XJ] ndR`: I'm not lying
S3eKeR: so i guess u dont need the plugin anymore?
[XJ] ndR`: I'm still going to take it
S3eKeR: well my last thing at the end of our conversation would be merry christmas and happy holidays.
[XJ] ndR`: yup of course for me too, but I want to keep contact with you, in order to explain you what's gonna happen
S3eKeR: i found the addons
S3eKeR: how did u busted us btw
S3eKeR: edark still cant detect sidespeed man
S3eKeR: and he can detect plugins
S3eKeR: that's amazing
[XJ] ndR`: last question
[XJ] ndR`: why did you say that about keltA?
S3eKeR: i started thinking of this
S3eKeR: when i saw his clintmo_longjump(er)
S3eKeR: i think wr
S3eKeR: he was going to fast and what was in my mind was the speed of the knife.
S3eKeR: then i asked nfs if theres a way of creating this
S3eKeR: and somehow , he did it in 20 mins.
[XJ] ndR`: so you think he cheats with the same kind of cheat?
S3eKeR: yes
S3eKeR: kelta is not using it on ljs
S3eKeR: tell this to edark
S3eKeR: try to check kelta demos and check of bj prestrafe
[XJ] ndR`: but with your words and the plugin you're going to give me, we can check his demos.
S3eKeR: if the speed of knife is higher
S3eKeR: also prestrafe can pass 299
S3eKeR: i'll try
S3eKeR: i can also help at sidespeed
S3eKeR: -link-
S3eKeR: heres the addons i still have
S3eKeR: which has the plugin on it
S3eKeR: amx_knifespeed.amxx
S3eKeR: this is the plugin
[XJ] ndR`: thank you
S3eKeR: no problem man
S3eKeR: i realised i did wrong for a game
S3eKeR: i took it to serious and i only realised after i quitted
[XJ] ndR`: I understand
S3eKeR: but i want to tell u something
S3eKeR: i want any of us get the same punishment
S3eKeR: even if i confessed it
Statement by Avatar:
Avatar: ok
Avatar: at first
Avatar: u know nfs or?
: nope
Avatar: k
Avatar: hes a jumper and coder
Avatar: let me tell teh whole story be4 us ay anything k?
Avatar: say*
: ok
Avatar: good!
Avatar: it should not end like this!
Avatar: it was not planed!
Avatar: everybody is flaming about cheaters and guys who apper with uberskills from nowhere!
Avatar: so he coded a plugin
Avatar: knifespeed!
Avatar: u know it now
Avatar: ok
Avatar: and he asked me, if i could use it for xj
Avatar: becouse all ppl say that edark is not as good in detecting things as all think
Avatar: so i agreed
Avatar: becouse many ppl know taht 256 would be easy 4 me
Avatar: or poss 4 me
Avatar: we anted to see if edark is able to detect plugins.
Avatar: becosue he think that many ppl on xj use things liek this
Avatar: that changing runspeed!
Avatar: i told u be4 that i know from nothing becouse we dont wanted to close this so earyl
Avatar: so i did 256 in like 2 minutes!
Avatar: and posted it
Avatar: to see if edark detects this
Avatar: the problem was that i sent my addins to s3eker without thinking
Avatar: that i have this plugin in it
Avatar: for it too than
Avatar: so we took him in
Avatar: so we posted our demos to xj
Avatar: wen wanted to see how far we can go with this until edark notices this
Avatar: thats why s3eker sued 253 knifespeed and i 251
Avatar: used*
Avatar: but we didnt even thought that eark would detect this so fast, so it was too l8
Avatar: to say that its was a test to faker or somebody becosue he del8ed me from list be4 i could explain
Avatar: we w8ted until the right moment
Avatar: and after u posted ur massage to me, we knew it was
Avatar: it was a "bad idea" to do this and we know this, we will give u the plugin (including the .sma code and the ljstats) to show that we never wanted to so something bad and that we naver wanted to damage somebody or something!
Avatar: i hope u can understand the situation, in that we are involved now, and we really never wabted to do soemthign abd to anybody!
Avatar: but now we have to tell this to someone or we wont be able to do!
Avatar: l8ter
Avatar: so we choosed u
Avatar: becouse we know that u maybe could understand this!
Avatar: ok!
Avatar: ill send u the plugin link now
Avatar: im ready now
Avatar: -link-
Avatar: here is the knifespeed plugin!
Avatar: :/
: ok
Avatar: we never wanted to do anything bad! seriously!
Avatar: thats why i denied that i was using it be4!
Avatar: i ahd to talk to the other guys!
Avatar:
Avatar: i hops u can understand this
Avatar: and we know that this was wrong!
Avatar: and we apologize for the problems that we made
Avatar: !
Avatar: if u need to know something about this plugin, just ask me or nfs!
Avatar: better nfs
Avatar: becouse i cant code
:'(: ok
Avatar: :/
:'(: ima post this in admin forums now, k?
Avatar: ye
Avatar: thx dude
Avatar: !
:'(: np
Statement by NFS:
NFS | Merry xmas: Okay, how do you want me to ezplain our "project"?
:'(: I don't know.
:'(: Just give us a statement
NFS | Merry xmas: Ye, I know, Avatar told me
NFS | Merry xmas: well, everything avatar said is true, i read the logs between you guys
NFS | Merry xmas: Our project was to test XJ's anti-cheat, too see if it was as good as my checker that i have today. but it turned out that he learned to read the speed just a couple of days after we submitted our demos.
NFS | Merry xmas: I don't wanna bring up the whole story from the beginning, but everything avatar told u. It's the truth, ok?
:'(: ye ok
NFS | Merry xmas: i know we gonna get permbanned
NFS | Merry xmas: im fine with that, but the reputation :/
:'(: mm :/
发表于 2010-1-2 06:58:14 | 显示全部楼层
仔细看了看扩展新闻,keltA危险了。。。。让我们拭目以待
2010刚开始就来个作弊新闻
255_lj_ArN 这个demo过了1年半以后终于真相大白
发表于 2010-1-2 07:31:16 | 显示全部楼层
e   作弊的真多。
发表于 2010-1-2 08:24:22 | 显示全部楼层
观望中~~~
发表于 2010-1-2 09:01:12 | 显示全部楼层
255_lj_ArN  这个可是很老了。没LJ2的时候就有了。
发表于 2010-1-2 09:08:00 | 显示全部楼层
我还膜拜了avatar的CJ那么久....
