查看: 1912|回复: 15
懂英文的 对CS熟悉的 进
发表于 2006-9-24 20:58:00 | 显示全部楼层 |阅读模式
<>刚才 我下了几部KZ视屏想来看看 但是 又不能观看 下面是控制台显示的</P>
<>] playdemo 254_NiconeN.dem<BR>laying demo from 254_NiconeN.dem.<BR><BR>BUILD 3382 SERVER (0 CRC)<BR>Server # 25<BR>Couldn't find map maps/kzfr_longjump.bsp, server will download the map<BR>Warning! File maps/kzfr_longjump.txt missing during demo playback.<BR>Warning! File maps/kzfr_longjump.bsp missing during demo playback.<BR>Error: could not load file maps/kzfr_longjump.bsp<BR>Model maps/kzfr_longjump.bsp not found and not available from server<BR>Cannot continue without model maps/kzfr_longjump.bsp, disconnecting.</P>
<P>还有提示</P>
<P>Cannot continue without model maps/kzfr_longjump.bsp, disconnecting.</P>
<P>懂的速回  QQ51261247</P>
发表于 2006-9-24 21:02:00 | 显示全部楼层
<> playdemo 254_NiconeN.dem<BR>laying demo from 254_NiconeN.dem.<BR><BR>BUILD 3382 SERVER (0 CRC)<BR>Server # 25<BR>Couldn't find map maps/kzfr_longjump.bsp, server will download the map<BR>Warning! File maps/kzfr_longjump.txt missing during demo playback.<BR>Warning! File maps/kzfr_longjump.bsp missing during demo playback.<BR>Error: could not load file maps/kzfr_longjump.bsp<BR>Model maps/kzfr_longjump.bsp not found and not available from server<BR>Cannot continue without model maps/kzfr_longjump.bsp, disconnecting.</P>
<>你播放DEMO的 CS版本是 3382</P>
<P>提示找不到地图 kzfr_longjump</P>
<P>一句话你得先下载一个 kzfr_longjump</P>
发表于 2006-9-24 21:37:00 | 显示全部楼层
没地图
发表于 2006-9-24 21:41:00 | 显示全部楼层
<>地图呢??</P>
<>下载后保存位置对吗??</P>
发表于 2006-9-24 21:42:00 | 显示全部楼层
DEMO是DEMO,视频是视频。。。。
发表于 2006-9-24 21:52:00 | 显示全部楼层
<>DEMO是CS录象,视频是不用CS,只用播放器就能看的影片</P>
<>随便说下LZ没有地图,所以看不了DEMO</P>
<>鉴定完毕</P>[em01][em01][em01]
 楼主| 发表于 2006-9-25 20:05:00 | 显示全部楼层
谢谢哦    恩啊[em01]
发表于 2006-10-13 21:48:00 | 显示全部楼层
<>播放 254_NiconeN.dem<BR>开始播放 254_NiconeN.dem.<BR><BR>BUILD 3382 版本服务器 (0 CRC)<BR>服务器 # 25号<BR>无法找到地图 maps/kzfr_longjump.bsp, 服务器将下载此地图<BR>警告! 文件 maps/kzfr_longjump.txt 在demo播放过程中未发现.<BR>警告! 地图 maps/kzfr_longjump.bsp 在demo播放过程中未发现.<BR>错误: 无法读取地图 maps/kzfr_longjump.bsp<BR>模型 maps/kzfr_longjump.bsp 在此服务器中不存在<BR>没有模型 maps/kzfr_longjump.bsp 将无法继续, 断开连接.</P>
<>还有提示</P>
<>没有模型 maps/kzfr_longjump.bsp 将无法继续, 断开连接.</P>
<P>中文的兄弟你该明白了吧,地图没装对</P>[em02]
发表于 2007-3-10 21:24:00 | 显示全部楼层
<DIV class=quote><B>以下是引用<I>yuanjin77520</I>在2006-10-13 21:48:00的发言:</B><BR>
<>播放 254_NiconeN.dem<BR>开始播放 254_NiconeN.dem.<BR></P></DIV><BR>BUILD 3382 版本服务器 (0 CRC)<BR>服务器 # 25号<BR>无法找到地图 maps/kzfr_longjump.bsp, 服务器将下载此地图<BR>警告! 文件 maps/kzfr_longjump.txt 在demo播放过程中未发现.<BR>警告! 地图 maps/kzfr_longjump.bsp 在demo播放过程中未发现.<BR>错误: 无法读取地图 maps/kzfr_longjump.bsp<BR>模型 maps/kzfr_longjump.bsp 在此服务器中不存在<BR>没有模型 maps/kzfr_longjump.bsp 将无法继续, 断开连接.
<p>
<>还有提示</P>
<DIV></DIV>
<P>懂了。 ..大家一定也懂了吧//?</P>
发表于 2007-3-10 21:26:00 | 显示全部楼层
老帖![em09]
