查看: 1075|回复: 7
━━━问━━题━━━
发表于 2006-9-24 20:33:00 | 显示全部楼层 |阅读模式
<>为什么我下的CS  Demo  不能播放啊   </P>
<>不能播放的提示是下面的</P>
<>] playdemo 1.dem<BR>Playing demo from 1.dem.<BR>ERROR: couldn't open.</P>
<P>速回  </P>
发表于 2006-9-24 20:39:00 | 显示全部楼层
<>速回~</P>[em02]
 楼主| 发表于 2006-9-24 20:46:00 | 显示全部楼层
刚才 我看KZ视屏  又不观看 显示下面的 谁懂的回话哦 要快 <BR>BUILD 3382 SERVER (0 CRC)<BR>Server # 25<BR>Couldn't find map maps/kzfr_longjump.bsp, server will download the map<BR>Warning! File maps/kzfr_longjump.txt missing during demo playback.<BR>Warning! File maps/kzfr_longjump.bsp missing during demo playback.<BR>Error: could not load file maps/kzfr_longjump.bsp<BR>Model maps/kzfr_longjump.bsp not found and not available from server<BR>Cannot continue without model maps/kzfr_longjump.bsp, disconn
 楼主| 发表于 2006-9-24 20:47:00 | 显示全部楼层
] playdemo 254_NiconeN.dem<BR>laying demo from 254_NiconeN.dem.<BR><BR>BUILD 3382 SERVER (0 CRC)<BR>Server # 25<BR>Couldn't find map maps/kzfr_longjump.bsp, server will download the map<BR>Warning! File maps/kzfr_longjump.txt missing during demo playback.<BR>Warning! File maps/kzfr_longjump.bsp missing during demo playback.<BR>Error: could not load file maps/kzfr_longjump.bsp<BR>Model maps/kzfr_longjump.bsp not found and not available from server<BR>Cannot continue without model maps/kzfr_longjump.bsp, disc
 楼主| 发表于 2006-9-24 20:49:00 | 显示全部楼层
<>还有下面的提示</P>
<>Cannot continue without model maps/kzfr_longjump.bsp, disconnecting.</P>
发表于 2006-9-24 21:03:00 | 显示全部楼层
<>你把DEMO名字改错了.记得要改成1.dem,仔细看看自己demo的名字</P>
<>看demo还需要其中demo 所需要的地图</P>
发表于 2006-9-24 21:41:00 | 显示全部楼层
去下个地图包吧。DEMO的名字随便改的。扩展名不要动就行了。
 楼主| 发表于 2006-9-25 20:06:00 | 显示全部楼层
xiexie  lo   wo  hui lo
