查看: 1135|回复: 23
communityblock工程遥遥无期……
发表于 2009-10-8 05:01:37 | 显示全部楼层 |阅读模式
ChrizZo发布的新闻:
It's a long time since our communityblock project came up here at XJ. Alot of people within the community, especially the mappers, werewaiting for the release of the final version. I met radon to ask himabout the status of the project and I've summed up what he was saying.
自从XJ开始communityblock项目已经过去很长时间了。社区里很多人,特别是地图制作者,一直期待着最终版本。我问radon进度怎样了,并把他的回答汇总在下面。
radon:"It feels like the whole project is still at 0%, even tho I've spentcountless hours in fixing bugs and designing each block. Because of thehuge size and the mass of blocks, it's the most boring work in theworld. You can't be creative at all and it's always the same.
Itwasn't only me, who was trying to finish it. Raver and Puppetz weretrying to work on it as well, but both run out of patience. The same istrue for me at the moment. To be honest, in my eyes it's unbelievablethat people still think that someone will ever finish it. If atrustable person would like to continue and if he seriously thinks hehas enough patience, I wouldn't mind handing it over."
radon:我觉得整个工程还停留在0%,尽管我已经花费无数个小时去修复bug和设计每个跳点。因为地图巨大、跳点太多,这是世界上最无聊的工作。你不能创造什么,一直在做同样的事。除了我之外还有别人想完成它。Raver和Puppetz尝试过,但都失去了耐心。我现在的情况也是这样。说实话,我觉得没有任何人能完成它。如果哪个可靠的人愿意继续这项工程,并且对自己的耐心有足够的自信,我会很乐意把这个包袱托付给他。
PS:顺便提一句,cosy-climbing发布demo的速度非常慢,想必经常上去刷图的人都很痛苦。目前这个网站开始招人了,如果谁愿意花大量时间去检测demo,赶紧去申请做demo admin(基本的英语交流能力显然是必须的)。另外还可申请mapper、jumper等职位(自从Kureno在服务器里用连跳脚本作弊后被踢出cosy,那边没什么活跃的mapper了吧;从来就不知道这个网站的jumper是做什么的,难道挂cC队标去XJ等服务器晃么-_-|||)。
发表于 2009-10-8 05:06:08 | 显示全部楼层
radon偷懒了。
 楼主| 发表于 2009-10-8 05:06:51 | 显示全部楼层
当前的communityblock可玩性不高,所以XJ搞了一次投票,是仍将其作为一个整体进行处理,还是拆分成两张小一些的地图,甚至干脆不管它了。最后的投票结果里第一项以微弱优势胜出。
所以估计最后可能会变成一张漂亮的、FPS狂低的、跟现在版本一样大的强图。现在这个版本还有很多空间没利用上,可以加不少跳点,那样就更变态了,哇哈哈哈哈。
发表于 2009-10-8 08:36:40 | 显示全部楼层
那图所需要时间长了点.
40分钟上次没跳完就换图了
发表于 2009-10-8 08:40:39 | 显示全部楼层
比kz_world还world
比crazyblock还crazy
发表于 2009-10-8 08:52:26 | 显示全部楼层
LS说的经典
发表于 2009-10-8 08:53:40 | 显示全部楼层
又大又简单的图实在是没兴趣跳啊
发表于 2009-10-8 10:01:39 | 显示全部楼层
啊,最后成悲剧了
发表于 2009-10-8 10:08:07 | 显示全部楼层
没玩过这图 进来围观
发表于 2009-10-8 10:47:10 | 显示全部楼层
几个mapper缺乏毅力就放弃了这个集60多个mapper心血的图了。。。。。。
天长地久  有时尽,
此恨绵绵  无绝期!
把kreez找回来,建立个地图攻关小组,干掉它
参与人数 1金币 +4 +4 收起 理由
hkxxswz8 + 4 + 4 言之有理
