查看: 1132|回复: 13
insilio快讯
发表于 2009-10-3 16:36:03 | 显示全部楼层 |阅读模式
KZhack is maybe gonna be VAC detectable soon
chrizZo, Tuesday 29 September 2009 - 18:27:15 // comment: 14
Our old friend Kureno sent the well known kreedz hack called "kzh" to valve in order to do something against it. He asked the admins to add this hack to their valve anti-cheat module that is basically installed on nearly every serious counter-strike server out there.
It was a surprise that he got a quick answer relating to his suggestion, but it is the truth. At the moment valve is adding this hack to their anti-cheat system and soon you'll probably get a VAC ban, if you use this certain hack.
Thanks.
kz hack也许不久后就能通过VAC检测出来
Kureno,此人大家记得不,就是那个日德籍做地图的人。
他最近把一个很出名臭名昭彰的软件,名字叫做kzh, 传给了valve公司。
希望valve公司能分析后把这种软件加入到反作弊的模块中。
这样各大CS服务器就都能装上这个反作弊的软件了。
令人惊讶的是,valve公司很快就给他回信了。
此时valve公司正在把这个软件加入反作弊模块中。
如果你以后再用这个软件作弊,也许就会被VAC ban掉了。
KZ在反作弊的道路上又迈进了一步。
发表于 2009-10-3 16:39:53 | 显示全部楼层
喔噢噢。。。。。
发表于 2009-10-3 16:41:18 | 显示全部楼层
作弊的无处躲!
象犯罪一样
人见人恨
发表于 2009-10-3 16:43:36 | 显示全部楼层
嘿嘿,有好戏看了!
发表于 2009-10-3 16:50:08 | 显示全部楼层
有能力的人在不同的立场
发挥的作用就是不一样啊~
发表于 2009-10-3 16:52:23 | 显示全部楼层
强悍~~~~~~
发表于 2009-10-3 17:01:29 | 显示全部楼层
Kureno
這人在cosy climbing的服內用bhop hack
給cosy ban了
想不到會弄反作弊
 楼主| 发表于 2009-10-3 17:02:21 | 显示全部楼层
.....楼上知道不少
发表于 2009-10-3 17:05:49 | 显示全部楼层
26...哈哈哈
发表于 2009-10-3 17:13:46 | 显示全部楼层
正版才能享受吧
