查看: 756|回复: 7
求top15插件
发表于 2009-8-13 20:38:38 | 显示全部楼层 |阅读模式
要求单独就top15这个插件 不要其他的 更不要给我什么插件包 什么KZ整合插件
只要能记录保存所有玩家跳跃每张张地图跳跃的时间的排名就好
万分感谢
发表于 2009-8-13 21:29:42 | 显示全部楼层
KZ Stats by Chris
To be used with Kz Jump Plugin v0.08 by teame06
Functions offered:
- Top15
More to come...
这个可以吗?
我没测试过哈!
Credits / Thanks / Notes:
teame06 for the Kz Jump Plugin and help
AssKicR for KZ Multiplugin
I took the top15 from Multiplugin
#include <amxmodx>
#include <amxmisc>
#include <nvault>
#include <kz>
#define VERSION "0.3"
#define MP_COMPATIBLE 1  //Enable/Disable reading&converting Top15 from KZ Multiplugin
//TaskIds
//UpdateScoreboard TaskId = 0
//Pointers
new kz_enabled;
new kz_top15;
//Vault File
new Vault;
new const TOP15_FILE[] = "kz_Top15";
new const EMPTY[] = "X";         //Assigned to SteamId to know if a top15 slot is empty or not
#if MP_COMPATIBLE
new const TOP15_FOLDER[] = "kz_top15";//Folder name where old Top15 from KZ Multiplugin will be read
#endif
//Top15 Vars
new Top15_SteamId[15][33];
new Top15_Name[15][33];
new Top15_Time[15];
new Top15_CP[15]; //Checkpoints
new Top15_GC[15]; //GoChecks
new deleteNum = -1;
//Other vars
new CurrentMap[32]; //Current map name
plugin_init
Called on plugin load
public plugin_init()
        register_plugin("KZ Stats", VERSION, "Chris");
        //Setting Cvars
        kz_top15 = register_cvar("kz_top15", "1");
        //Getting Other Cvar Pointers
        kz_enabled = get_cvar_pointer("kz_enabled");
        //Setting mapname
        get_mapname(CurrentMap, 31);
kz_Init
Called by main plugin when it loads
public kz_Init(_state)
        if(!_state)
                pause("a");
                return PLUGIN_HANDLED;
        if(!get_pcvar_num(kz_enabled))
        //Register say command
        register_saycmd("top15", "Top15_Show", -1, "");
        register_concmd("amx_removetop15","Top15_Remove",ADMIN_RCON,"Shows the edit menu");
        register_concmd("amx_cleartop15", "Top15_Clear",ADMIN_RCON,"Deletes the Top15 of the current map");
        register_concmd("amx_printtop15","Top15_Print",ADMIN_RCON,"Shows the top15 in console");
        //Top15_Read(); //commentend because using below block
        #if MP_COMPATIBLE
        new Top15_TxtFilePath[128];
        new BaseDir[32];
        get_basedir(BaseDir,31);
        format(Top15_TxtFilePath,sizeof(Top15_TxtFilePath),"%s/%s/%s.txt", BaseDir, TOP15_FOLDER, CurrentMap);
        if(file_exists(Top15_TxtFilePath))
                //Reads the Top15
                Top15_MP_Read(Top15_TxtFilePath);
                //Deletes the file since it's not needed anymore (Top 15 is saved with nvault)
                delete_file(Top15_TxtFilePath);
        else
                Top15_Read();
        #else
                Top15_Read();
        #endif
kz_FinishClimb
Called by main plugin when the player pushes the end button
public kz_FinishClimb(player, time, cp_count, gc_count)
        if(!get_pcvar_num(kz_top15))
        new Name[33];
        get_user_name(player,Name,32);
        // will be eventualy a variable with the minimum time per map
        // preventing to fast times with exploits or boosting
        if(time > 20)
                Top15_Check(player,time,cp_count,gc_count);
        else
                if(time > 1)
                        kz_ColorChat(player,green,"[KZ Top15] Your time is too fast...cheater !!");
                        log_to_file("KZ_Cheats.txt","[KZ Top15] %s was beaten in %s by %s", CurrentMap, GetStrTime(time), Name);
                else
                        kz_ColorChat(player,green,"[KZ Top15] To bad you didn't have a timer...");
public Top15_Clear(id,level,cid)
        if ( !cmd_access(id,level,cid,1) )
                return PLUGIN_HANDLED ;
        new VerificationNumber[5];
        read_argv(1,VerificationNumber,4);
        if(str_to_num(VerificationNumber) != deleteNum)
                deleteNum = random_num(1,999);
                client_print(id, print_console, "Type amx_top15clear %i   to delete the top 15", deleteNum);
        else
                deleteNum = -1;
        Vault = nvault_open(TOP15_FILE);
        if(Vault == INVALID_HANDLE)
                log_amx("Error opening nVault file: %s", TOP15_FILE);
        new Key[40];
        for( new i = 0; i < 15; i++ )
                GetKey(i+1,Key);
                Top15_SteamId = EMPTY;
                Top15_Time = 99999;
                Top15_CP = 99999;
                nvault_remove(Vault, Key);
        nvault_close(Vault);
        client_print(id, print_console, "Top15 of %s has been deleted", CurrentMap);
public Top15_Remove(id,level,cid)
public Top15_Print(id,level,cid)
        client_print(id, print_console, "-------------------------------------------------------------------");
                client_print(id, print_console, " %d. %s %s %s %i %i",(i+1),Top15_SteamId, Top15_Name,GetStrTime(Top15_Time),Top15_CP,Top15_GC);
        new Key[40], Data[100];
        new TimeStamp;
        new tSteamId[32],tName[32],tTime[5],tCP[5],tGC[5];
                GetKey(i+1,Key);
                if(nvault_lookup(Vault, Key, Data, 99, TimeStamp))
                        parse(Data,tSteamId,31,tName,31,tTime,4,tCP,4,tGC,4);
                        client_print(id, print_console, " %d.%s %s %s %i %i",(i+1),tSteamId,tName,GetStrTime(str_to_num(tTime)),str_to_num(tCP),str_to_num(tGC));
Top15_Read
Reads the Top15 file if there is already one
public Top15_Read()
        new TimeStamp;
                GetKey(i+1,Key);
                        Top15_SteamId = tSteamId;
                        Top15_Name = tName;
                        Top15_Time = str_to_num(tTime);
                        Top15_CP = str_to_num(tCP);
                        Top15_GC = str_to_num(tGC);
                else
                        Top15_Time = 99999;
                        Top15_CP = 99999;
Top15_MP_Read
Reads the Top15 from a KZ Multiplugin File
public Top15_MP_Read(Top15_File[])
        if(file_exists(Top15_File))
                new line, stxtsize ;
                new data[192] ;
                new tAuth[32],tName[32],tMins[10],tSecs[10],tHuns[10],tChecks[10];
                new Mins,Secs,Huns;
                for(line = 0; line < 15; ++line)
                        read_file(Top15_File,line,data,191,stxtsize);
                        parse(data,tAuth,31,tName,31,tMins,9,tSecs,9,tHuns,9,tChecks,9);
                        Top15_SteamId[line] = tAuth;
                        Top15_Name[line] = tName;
                        Mins = str_to_num(tMins);
                        Secs = str_to_num(tSecs);
                        Huns = str_to_num(tHuns);
                        Top15_Time[line] = MinSecHunToSecs(Mins,Secs,Huns);
                        Top15_CP[line] = str_to_num(tChecks);
                        Top15_GC[line] = -1;
                //Save to nVault file;
                Top15_Save();
MinSecHunToSecs(&Mins,&Secs,&Huns)
        new Result = (Mins * 60) + Secs;
        if(Huns >= 5)
                ++Result;
        return Result;
Top15_Save
Saves the Top15 to file
Top15_Save()
        static Key[40], Data[100];
                if(equali(Top15_SteamId,EMPTY))
                format(Data, 99, "^"%s^" ^"%s^" %i %i %i", Top15_SteamId,Top15_Name,Top15_Time,Top15_CP,Top15_GC);
                GetKey(i+1,Key);
                nvault_set(Vault, Key, Data);
Top15_Check
Checks if the player's time is good enough to go in the top15
Top15_Check(id, PlayerTime, cp_count, gc_count)
        if(PlayerTime <= Top15_Time[14]) //if the player has a better or the same time than the last person in the Top 15
                if(PlayerTime == Top15_Time[14] && cp_count > Top15_CP[14]) //if they have the same time and the player has more checkpoints
                        kz_ColorChat(id, green, "[KZ Top15] Too bad, you have the same time as the 15th but you used to much checkpoints");
                        return PLUGIN_HANDLED; //too bad he didn't make it in the top15
                //Get the SteamId and player name
                static Name[33],SteamId[33];
                get_user_name(id, Name, 32 );
                get_user_authid(id, SteamId ,32 );
                        if( PlayerTime < Top15_Time) //if the player's time is less
                                new pos = i;
                                while( !equal( Top15_SteamId[pos], SteamId ) && pos < 14 )
                                        pos++;
                                for( new j = pos; j > i; j-- )
                                        format( Top15_SteamId[j], 32, Top15_SteamId[j-1] );
                                        format( Top15_Name[j], 32, Top15_Name[j-1] );
                                        Top15_Time[j] = Top15_Time[j-1];
                                        Top15_CP[j] = Top15_CP[j-1];
                                        Top15_GC[j] = Top15_GC[j-1];
                                format( Top15_SteamId, 32, SteamId );
                                format( Top15_Name, 32, Name );
                                Top15_Time = PlayerTime;
                                Top15_CP = cp_count;
                                Top15_GC = gc_count;
                                kz_ColorChat(id,green,"[KZ Top15] Congratulations you made it in the Top15");
                                Top15_Save();
                        if( equal( Top15_SteamId, SteamId ) ) //if the player already has a better time
                                kz_ColorChat(id,green,"[KZ Top15] Too bad, you didn't beat your time in the Top15");
        else
                kz_ColorChat(id,green,"[KZ Top15] Too bad, you didn't make it in the Top15");
Top15_Show
Shows the Top15 on /top15 command
public Top15_Show(id)
        else if(!get_pcvar_num(kz_top15))
                kz_ColorChat(id, green, "[KZ Top15] Server has disabled that option");
        new buffer[2100];
        new line[250];
        new strGC[5];
        new len = format( buffer, sizeof(buffer), "<table cellspacing=0 rules=all border=2>" );
        len += format( buffer[len], sizeof(buffer)-len, "<tr><th> # <th> Nick <th> Climb time <th> Checkpoints <th> Go Checks" );
        for(new i = 0; i < 15; ++i)
                if(equali(Top15_SteamId,EMPTY)) //if the slot is free
                        format(line, sizeof(line), "<tr><td> %d. <td> %s <td> %s <td> %s <td> %s", (i+1), "<--------------------------->", "---- min. -- sec.", "---", "---");
                else
                        num_to_str(Top15_GC,strGC,4);
                        format(line, sizeof(line), "<tr><td> %d. <td> %s <td> %s <td> %i <td> %s", (i+1),Top15_Name,GetStrTime(Top15_Time),Top15_CP,Top15_GC==-1?"---":strGC);
                len += format( buffer[len], sizeof(buffer)-len, line );
        format(line, sizeof(line), "</table>" );
        show_motd(id, buffer, "Top 15 Climbers" );
Sets the correct Key for top15
GetKey(Rank, Key[])
        format(Key, 39,"%s %i",CurrentMap, Rank);
GetStrTime
Recives time in secs and returns a string: X min. X sec.
GetStrTime(Seconds)
        new sTime[18];
        new Minutes;
        Minutes=Seconds/60;
        Seconds=Seconds%60;
        format(sTime,17, "%i min. %i sec.", Minutes,Seconds);
        return sTime;
 楼主| 发表于 2009-8-13 21:45:04 | 显示全部楼层
KZ Stats by Chris
Functions offered:
- Top15
More to come...
这个可以吗?
我没测试过哈!
Pledges 发表于 2009-8-13 21:29
你给我源码啊!!!
我晕!
我是要单机练习用的!!
好牛啊!
你太有心了!
我表达能力有限!
发表于 2009-8-13 22:21:02 | 显示全部楼层
top15功能要么是集成在某个插件里面,要么像2#发的那样需要配合其他kz插件使用
 楼主| 发表于 2009-8-14 18:53:38 | 显示全部楼层
我知道它集成在某个插件里 我就是想要单独一个,某位高人能做出来给我吗????
 楼主| 发表于 2009-8-15 13:37:11 | 显示全部楼层
求top15插件
要求单独就top15这个插件 不要其他的 更不要给我什么插件包 什么kz整合插件
万分感谢
 楼主| 发表于 2009-8-16 15:25:50 | 显示全部楼层
万分感谢
 楼主| 发表于 2009-8-24 19:24:40 | 显示全部楼层
高手做个出来啊!!!!
