查看: 775|回复: 16
5张新图 转自XJ
    发表于 2009-8-3 09:18:48 | 显示全部楼层 |阅读模式
    谁帮忙翻译一下
    Hey guys,
    We have 5 new Maps for you.
    kzsca_bunratty by Draw:
    Draw is back with a map that reminds us a little of his popular KZ_kzse_towerblock map. But this time its not a block map, this time you basically jump around and inside of a old Irish caslte called bunratty.
    The castle is square so the map is built the same way with most of the jumping inside the four towers. The map has a cool atmosphere and has a little bit of that oldschool feeling.
    kz_cg_treeoflife by DaMp:
    If you are familiar with maps made by mappers from the climbers-germany community you will recognize these jumps. The map has a oldschool feeling to it and that was probably the intention
    of the mapper. If you like straight forward jumping with oldschool textures and ambience you will like this.
    kz_forgotten by radon:
    A new map by radon, and like always the map looks beautiful and has very cool ambience. The map starts of as a block map. But slowly you get to a big
    and even more beautiful dark big cave with even better atmosphere. The architecture in the cave is different from the rest of the map and it goes from being a block
    map to a fast paced map.
    kz_kzdk_timber by radon & puppetz:
    This is a colaboration map between radon and puppetz. The map starts of in a cave that you have to get through to get to the huge tree outside. This is where the tricky part starts.
    You have to be careful to not fall of the top of the tree. There is a great variation in the jumps. You probably wont see two of the same jumps anywhere in the map.
    The creativity is flowing in this map .
    trC_climbgarden by tranCyfast:
    trC_climbgarden is a colorful speedmap by tranCyfast. This map looks "happy" and is a perfect map for people who like speed maps. There is not much more else to say about this map.
    Just that if you like fast maps, you need to try this.
    Note: Due to a misunderstanding between mapadmins and demoadmins the both prochallenge maps prochallenge_longjump and prochallenge_precision were missing and got added to the record section as well.
    - Also the mapsubmission rules have been adjusted. Check the extended newspost to read the details.
    发表于 2009-8-3 09:26:19 | 显示全部楼层
    S F。  坐下来看各位对此新图有什么评价
    发表于 2009-8-3 09:28:10 | 显示全部楼层
    kz_forgotten 这图看起来好神秘 有感觉
     楼主| 发表于 2009-8-3 09:36:05 | 显示全部楼层
    radon新图终于发布了
    发表于 2009-8-3 10:21:50 | 显示全部楼层
    强势插入。。。。
    发表于 2009-8-3 10:55:47 | 显示全部楼层
    kz_forgotten 好象鬼屋....
    发表于 2009-8-3 10:59:41 | 显示全部楼层
    我想kz_synergy能快点被xj认定....
    据消息说这图是kz史上 最难的一张图...
    发表于 2009-8-3 11:07:42 | 显示全部楼层
    BB快来翻译
    发表于 2009-8-3 11:15:17 | 显示全部楼层
    感觉最后一个好玩!
     楼主| 发表于 2009-8-3 11:28:39 | 显示全部楼层
    pepedog 发表于 2009-8-3 10:59
    这是什么东西?
