查看: 461|回复: 8
The New Cosy
发表于 2009-8-3 07:13:32 | 显示全部楼层 |阅读模式
Hello
There are some changes in the Cosy-Climbing's page, team and in the cup system.
Lets start with the team.
SilverNinja joined our crew! Lets give him a warm welcome *hug*. Also, you must have read the XJ's news about kayne, who was also a jumper here and of course, got kicked from the team and banned from the page & the mirc channel.
Moving to the website changes...
Cosy-Climbing will host nonKZ maps. The reason? Cypress-Climbing is way away from a serious community - their head admin s1z3 was cought for cheating again. Also, he was involved in the fps Death leaking, the same leaking which caused thopa leave the XJ Staff. Of course, there are going to be people who wont like this idea - Cosy-Climbing to host nonkz maps, because "cypress" was the official. Indeed, "cypress" is not and will never be the official. The new about naming the demos is also changed. Instead of notkz_map_Nikola_1337.rar, you have to name your demo notkz_map_Nikola_1337.10.rar. The miliseconds can be seen by Demolyser/fpsDeath.
New feature: KZ Points. Everytime you beat a demo, you'll get amount of points. This amount depends from the last demo beat to your demo beat. Here's an example: on 10.08.2009 I beat bk_bhop; on 19.08.2009 player "layer" beats my demo and gets 9 points. Those KZ Points will get you some features, which we'll alone a bit later
Lets take a look at the cup changes..
I (Nikola) has been recoding the whole mirc cup system. So far, it got just as I wanted. To play cups, you gotta register to the bot. How do you do that?
/msg Cosy-Climbing register password steamid
here's a real example:
/msg Cosy-Climbing register ccr0x STEAM_ID:0:0:1337
After you register, you have to login. Your login name, will be the nick with which you've registered. Lets say my nick was "Nikola" and if we take the example with the registering, my password is "ccr0x" - then just message the bot like:
/msg Cosy-Climbing login nickname password
or like with the real example:
/msg Cosy-Climbing login Nikola ccr0x
Then you are ready to play the cups ^^
A little change in the cup system on the server also. When the admin set the start position, all the current jumpers need is to say !ready and the match starts.
Well, I hope you actually understood anything.
Have fun recording
 楼主| 发表于 2009-8-3 07:18:12 | 显示全部楼层
请懂英语di速翻译,貌似COSY成了nonkz maps主场了。我查了一下,所有nonkz maps都没有记录,这真是CC刷图党的福音啊,以后可以转战这里了,cypress要倒闭咯。只是不知道有什么规则,WR选手能不能参与刷图?如果有2个wr以上的选手不能刷图的话,那以后我们就可以爽啦,哈哈哈。上传demo的时间要精确到小数点后两位,不能四舍五入。Remember to name your demo like notkz_map_Nikola_1333.37.rar, where 1333 is your timer time and 37 are the first 2 digits of the miliseconds (which can be viewed by Demolyser/fpsDeath)
    发表于 2009-8-3 08:30:46 | 显示全部楼层
    那么 如果WR级选手用马甲?  会被封IP吧..
    发表于 2009-8-3 08:44:06 | 显示全部楼层
    silverninja还是那种作风啊
    就是不知道为什么离开了cypress
    看现在的cosy管理团队,没有一个人满权限,也不知谁是终极BOSS
    发表于 2009-8-3 08:52:12 | 显示全部楼层
    请懂英语di速翻译,貌似COSY成了nonkz maps主场了。我查了一下,所有nonkz maps都没有记录,这真是CC刷图党的福音啊,以后可以转战这里了,cypress要倒闭咯。只是不知道有什么规则,WR选手能不能参与刷图?如果有2个w ...
    puma 发表于 2009-8-3 07:18
    看了一下,wr选手的限制没有了……
    而且没看到non-steam相关问题
    发表于 2009-8-3 08:58:19 | 显示全部楼层
    占个位置坐下等着看翻译。
    发表于 2009-8-3 09:09:11 | 显示全部楼层
    不是吧 那么WR级选手还可以刷?
    发表于 2009-8-3 09:48:19 | 显示全部楼层
    不是吧 那么WR级选手还可以刷?
    fanzhen0019 发表于 2009-8-3 09:09
    http://www.cosy-climbing.net/comment.php?comment.news.103
    看nikola给omilo的回复
    发表于 2009-8-3 10:59:16 | 显示全部楼层
    cypress要倒闭了,默哀一个
