查看: 931|回复: 11
config
发表于 2009-7-1 23:49:56 | 显示全部楼层 |阅读模式
// This file is overwritten whenever you change your user settings in the game.
// Add custom configurations to the file "userconfig.cfg".
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "+" "sizeup"
bind "," "buyammo1"
bind "-" "bot_kill"
bind "." "buyammo2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "bot_add"
bind "[" "invprev"
bind "\" "bot_kick"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "j" "cheer"
bind "k" "+voicerecord"
bind "l" "showbriefing"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "buyequip"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "v" "+moveup"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "autobuy"
bind "F2" "rebuy"
bind "F5" "snapshot"
bind "F6" "save quick"
bind "F7" "load quick"
bind "F10" "quit prompt"
bind "INS" "+klook"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "centerview"
bind "KP_HOME" "m4a1;ak47;primammo;"
bind "KP_UPARROW" "aug;sg552;primammo;"
bind "KP_PGUP" "awp;buyammo1;"
bind "KP_LEFTARROW" "famas;galil;primammo;"
bind "KP_5" "mp5;primammo;"
bind "KP_RIGHTARROW" "scout;buyammo1"
bind "KP_END" "usp;buyammo2;buyammo2;buyammo2;buyammo2;"
bind "KP_DOWNARROW" "deagle;secammo;"
bind "KP_PGDN" "g3sg1;sg550;buyammo1;"
bind "KP_ENTER" "hegren;"
bind "KP_INS" "vesthelm;vest;"
bind "KP_DEL" "defuser;"
bind "KP_MINUS" "sgren;"
bind "KP_PLUS" "flash;flash;"
bind "MWHEELDOWN" "invnext"
bind "MWHEELUP" "invprev"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "MOUSE4" "+jump"
bind "PAUSE" "pause"
_cl_autowepswitch "0"
_snd_mixahead "0.1"
ati_npatch "0"
ati_subdiv "0"
bgmvolume "1.000000"
bottomcolor "0"
brightness "1.380000"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "101"
cl_corpsestay "180"
cl_crosshair_color "50 250 50"
cl_crosshair_size "small"
cl_crosshair_translucent "0"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "1"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Red"
cl_logofile "skull"
cl_lw "1"
cl_minmodels "1"
cl_radartype "0"
cl_righthand "1"
cl_shadows "1"
cl_timeout "60"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "0.000000"
crosshair "1.000000"
fastsprites "0"
fps_max "101"
fps_modem "0.0"
gamma "2.660000"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "arctic"
MP3FadeTime "2.0"
MP3Volume "0.700000"
mp_decals "300"
net_graph "0"
net_graphpos "1"
net_scale "5"
r_bmodelhighfrac "5.0"
s_a3d "0"
s_automax_distance "30.0"
s_automin_distance "2.0"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000.0"
s_min_distance "8.0"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "2.220000"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.25"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "0"
viewsize "110"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "1"
volume "1.260000"
+mlook
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
+jlook
exec userconfig.cfg
有无非法脚本?
发表于 2009-7-1 23:50:38 | 显示全部楼层
呼叫牛憋
发表于 2009-7-1 23:58:09 | 显示全部楼层
后面那一串
exec userconfig.cfg
+jlook
保留一组就行
userconfig.cfg发上来
 楼主| 发表于 2009-7-2 00:04:20 | 显示全部楼层
// CPL GUI
// http://www.thecpl.com/
// powered by RzE's CS Helper
// http://www.csnation.net/rze/
echo "CS1.6 Okgogogo Ehanced Popularized Edition"
echo "Powered by XiaoReal"
echo "On the web at: Http://Www.Okgogogo.Com"
echo "*==-=-==E-Sports Life Games==-=-==*"
echo "On the web at: Http://Xiaoreal.Bokee.Com"
echo "E-Sports Life Games, Challenge Top Gun!"
alias go_slot1 "weapon_mp5navy; weapon_m4a1; weapon_m249; weapon_p90; go_slot1b"
alias go_slot1b "weapon_scout; weapon_awp; weapon_g3sg1; weapon_sg550; go_slot1c"
alias go_slot1c "weapon_sg552; weapon_aug; weapon_tmp; weapon_mac10; weapon_ak47; go_slot1d"
alias go_slot1d "weapon_ump45; weapon_xm1014; weapon_m3; weapon_famas; weapon_galil"
alias go_slot2 "weapon_usp; weapon_glock18; weapon_deagle; weapon_p228; weapon_elite; weapon_fiveseven"
alias rze_helm "vesthelm; vest"
alias rze_nvgs "nvgs; nightvision"
alias tg_fn57dual "fn57; elites"
alias tg_tmpmac10 "tmp; mac10"
alias tg_famgal "famas; galil"
alias tg_m4ak "m4a1; ak47"
alias tg_augsg "aug; sg552"
alias tg_sg550g3 "sg550; g3sg1"
ati_subdiv 0
ati_npatch 0
s_eax 0
s_a3d 0
rate 25000
cl_updaterate "101"
cl_cmdrate "101"
ex_interp "0.01"
bind "F12" "exec csmate.cfg"
exec saycn_bind.cfg
 楼主| 发表于 2009-7-2 00:04:54 | 显示全部楼层
 楼主| 发表于 2009-7-2 00:11:30 | 显示全部楼层
呼叫牛鳖#46 说一下有没有- - 这个版本是前年我玩豆客在它官网下载的。没改过里面的东西。有的话就2个中文聊天插件。和赛盟的KZ插件。
发表于 2009-7-2 00:20:48 | 显示全部楼层
很安全
没有special之类的基本上没问题
 楼主| 发表于 2009-7-2 00:22:53 | 显示全部楼层
刚在#7被玉兰油说我在牛鳖的压枪脚本名单上,,,我郁闷卅。人打僵尸,都是凑很近的。。有次被kick也是复仇站着不动让刷僵尸币的。。
 楼主| 发表于 2009-7-2 00:33:56 | 显示全部楼层
睡觉。明天看牛鳖回复。。。。
发表于 2009-7-2 00:36:10 | 显示全部楼层
好哦
那个插件有时会有误报
但是如果多次被记录那就
