查看: 1526|回复: 11
求混战最好用的CONFIG,正规参数.比赛禁止的参数不要
发表于 2009-6-23 16:30:13 | 显示全部楼层 |阅读模式
有的.发来,谢谢,,我做个参考
比赛禁止的参数我不需要,要没有禁止的, 我也知道比赛的时候不能用自己的CONFIG,  但我只想把CONFIG拿来混战用..谢谢..有的公布一下..好用的.推荐一下
发表于 2009-6-23 16:33:50 | 显示全部楼层
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "," "buyammo1"
bind "-" "+rope"
bind "." "buyammo2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "+hook"
bind "\" "timeleft"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "l" "+power3"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "buyequip"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "v" "buyequip"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "say menu;cl_minmodels 0"
bind "F2" "stop;record jump;say RECORD"
bind "F3" "mp5;primammo;vesthelm;vest;hegren;flash;flash;defuser;secammo;"
bind "F4" "say /checkpoint"
bind "F5" "say /gocheck"
bind "F6" "amx_view"
bind "F7" "awp;vesthelm;vest;usp;secammo;hegren;flash;flash;defuser;"
bind "F8" "say /stuck"
bind "F9" "say /keyhelp"
bind "F12" "snapshot"
bind "INS" "bot_quota 31"
bind "DEL" "bot_kick"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "centerview"
bind "KP_HOME" "deagle;"
bind "KP_UPARROW" "m249;"
bind "KP_PGUP" "shield;"
bind "KP_LEFTARROW" "famas;galil;"
bind "KP_5" "aug;sg552;"
bind "KP_RIGHTARROW" "awp;"
bind "KP_END" "flash;"
bind "KP_DOWNARROW" "hegren;"
bind "KP_PGDN" "sgren;"
bind "KP_ENTER" "vesthelm;"
bind "KP_DEL" "defuser;"
bind "CAPSLOCK" "+voicerecord"
bind "MWHEELDOWN" "+jump"
bind "MWHEELUP" "+duck"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "MOUSE3" "+voicerecord"
bind "MOUSE5" "invprev"
bind "PAUSE" "pause"
_cl_autowepswitch "0"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "1"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "101"
cl_corpsestay "600.000000"
cl_crosshair_color "50 250 50"
cl_crosshair_size "small"
cl_crosshair_translucent "0"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "0"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Blue"
cl_logofile "andre"
cl_lw "1"
cl_minmodels "0"
cl_radartype "1"
cl_righthand "0"
cl_shadows "1"
cl_timeout "35"
cl_updaterate "101\"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "1"
crosshair "1"
DF_hook_color "1"
DF_hook_deployspeed "1500"
DF_hook_forcespeed "0"
DF_hook_gravity "0.5"
DF_hook_ground "0"
DF_hook_hold "9999"
DF_hook_instant "1"
DF_hook_noise "1"
DF_hook_on "1"
DF_hook_onlywalls "0"
DF_hook_password "0"
DF_hook_players "1"
DF_hook_showspy "0"
DF_hook_sky "1"
DF_hook_sound "1"
DF_hook_speed "2"
DF_hook_swing "0"
DF_hook_swing_acceleration "150"
DF_hook_swing_minlength "100"
DF_hook_swing_reelspeed "200"
DF_hook_usekey "0"
DF_hook_wait "0.05"
DF_hook_weapon "0"
DF_hook_width "20"
fastsprites "0"
fps_max "101"
fps_modem "0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "0"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "1"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0"
mp_decals "300.000000"
name "vesslan"
net_graph "0"
net_graphpos "3"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "0"
s_a3d "0"
s_automax_distance "30"
s_automin_distance "2"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "5"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "8"
skin ""
spec_autodirector_internal "0"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "4"
spec_pip "0"
suitvolume "1.390000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "2"
volume "0.05"
setinfo "_vgui_menus" "0"
setinfo "_ah" "1"
+mlook
exec userconfig.cfg
发表于 2009-6-23 16:34:48 | 显示全部楼层
注意:其中bind "MWHEELUP" "+duck"是禁止的!
 楼主| 发表于 2009-6-23 16:34:58 | 显示全部楼层
这个是谁的????
发表于 2009-6-23 16:35:17 | 显示全部楼层
2L的太强了。那么多,眼睛都看花了。
 楼主| 发表于 2009-6-23 16:38:45 | 显示全部楼层
楼上的是水王,每次看你回贴,你都不讲内容,只讲废话
发表于 2009-6-23 16:42:49 | 显示全部楼层
这个是谁的????
SiMen.仔仔 发表于 2009-6-23 16:34
我的。
 楼主| 发表于 2009-6-23 16:47:37 | 显示全部楼层
bind "MWHEELUP" "+duck"     这个参数是哪个键梆定在蹲?
发表于 2009-6-23 16:48:01 | 显示全部楼层
求KZ最NB的CONFIG,正规KZ参数.XJ禁止的参数不要
发表于 2009-6-23 16:57:18 | 显示全部楼层
这玩意怎么看都象刷屏工具....
