查看: 1115|回复: 23
我刚来到SIMEN就被封禁啦.
发表于 2009-5-29 16:44:54 | 显示全部楼层 |阅读模式
刚进服务器,按了1下跳就出现这样的:
Kicked:Script(special)(被封禁30分钟)
是不是我的脚本有问题?我设置了鼠标滚轮是连跳.
发表于 2009-5-29 16:47:29 | 显示全部楼层
脚本。。。。。咋是纯爷们。
发表于 2009-5-29 16:49:26 | 显示全部楼层
config,脚本不干净,回答完毕。
发表于 2009-5-29 16:49:41 | 显示全部楼层
不知道呀`!!
发表于 2009-5-29 16:53:53 | 显示全部楼层
不清楚呀!
 楼主| 发表于 2009-5-29 16:54:20 | 显示全部楼层
能不能把你们的config发给我看看?
 楼主| 发表于 2009-5-29 16:57:12 | 显示全部楼层
提示: 该帖被管理员或版主屏蔽
发表于 2009-5-29 16:57:35 | 显示全部楼层
// This file is overwritten whenever you change your user settings in the game.
// Add custom configurations to the file "userconfig.cfg".
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "," "buyammo1"
bind "-" "+rope"
bind "." "buyammo2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "+hook"
bind "\" "timeleft"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "l" "+power3"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "buyequip"
bind "q" "lastinv"
bind "r" "+reload"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "v" "buyequip"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "say menu;cl_minmodels 0"
bind "F2" "stop;record jump;say RECORD"
bind "F3" "mp5;primammo;vesthelm;vest;hegren;flash;flash;defuser;secammo;"
bind "F4" "say /checkpoint"
bind "F5" "say /gocheck"
bind "F6" "amx_view"
bind "F7" "awp;vesthelm;vest;usp;secammo;hegren;flash;flash;defuser;"
bind "F8" "say /stuck"
bind "F9" "vestheml;vest;hegren;flash;flash;sgren;defuser;"
bind "F12" "snapshot"
bind "INS" "bot_quota 31"
bind "DEL" "bot_kick"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "centerview"
bind "KP_HOME" "deagle;"
bind "KP_UPARROW" "m249;"
bind "KP_PGUP" "shield;"
bind "KP_LEFTARROW" "famas;galil;"
bind "KP_5" "aug;sg552;"
bind "KP_RIGHTARROW" "awp;"
bind "KP_END" "flash;"
bind "KP_DOWNARROW" "hegren;"
bind "KP_PGDN" "sgren;"
bind "KP_ENTER" "vesthelm;"
bind "KP_DEL" "defuser;"
bind "CAPSLOCK" "+voicerecord"
bind "MWHEELDOWN" "+jump"
bind "MWHEELUP" "+duck"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "MOUSE3" "+voicerecord"
bind "MOUSE5" "invprev"
bind "PAUSE" "pause"
_cl_autowepswitch "0"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "1"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "101"
cl_corpsestay "600.000000"
cl_crosshair_color "50 250 50"
cl_crosshair_size "small"
cl_crosshair_translucent "0"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "0"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Blue"
cl_logofile "andre"
cl_lw "1"
cl_minmodels "0"
cl_radartype "1"
cl_righthand "0"
cl_shadows "1"
cl_timeout "35"
cl_updaterate "101\"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "1"
crosshair "1"
fastsprites "0"
fps_max "101"
fps_modem "0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "0"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "1"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0"
mp_decals "300.000000"
name "vesslan"
net_graph "0"
net_graphpos "3"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "0"
s_a3d "0"
s_automax_distance "30"
s_automin_distance "2"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "5"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "9"
skin ""
spec_autodirector_internal "0"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "1.390000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "2"
volume "0.3"
setinfo "_vgui_menus" "0"
setinfo "_ah" "1"
+mlook
exec userconfig.cfg
发表于 2009-5-29 17:00:59 | 显示全部楼层
LZ,你还不错,脚本都发上来~
发表于 2009-5-29 17:02:29 | 显示全部楼层
LZ强大,直接发脚本上来
