查看: 699|回复: 7
Gangien's KZ Updater 自动更新KZ地图,看了半天没见人发过
发表于 2009-5-24 07:00:50 | 显示全部楼层 |阅读模式
这是老美做的自动更新KZ地图的小软件,配合正版steam用没问题,non-steam没试过,不太确定。
地图来源可以选xj或者kzna的服务器,下载地址如下(21MB):
http://kz-na.com/e107_plugins/kreedz/install.rar
安装说明
Gangien's KZ Updater is a program, that will idle in your System tasktray and periodically check for new maps. And depending on yoursettings, download those maps and install them for you.
To install (安装步骤)
1.) Download and extract the file (下载并解压文件)
2.) move it to wherever you want to install it to.  So, if you want to put it in Program Files, copy it there. (将解压开的文件夹拷贝到你指定的地方)
3.)Run the KZUpdaterInstall.exe in the directory you just copied. So ifyou put it in Program Files, it would be in ProgramFiles\kzupdater \KZUpdaterInstall.exe  (运行KZUpdaterInstall.exe)
* Install for, will install shortcuts for you, everyone, or no one. (选择安装给当前用户或者所有人)
* Run at startup will make the program automatically start up when you log in. (选择Run at startup则会在每次电脑启动时自动启动此程序)
4.) Configure your settings. (设置)
* Select your CStrike directory (选定Cstrike目录)
* Probably best to leave it at verify maps to Download.  If you choose the other one, it will download maps without asking you. (最好设定成verify maps to download,这样每次有新地图下载前会提示你)
* also probably best to use the system tray, otherwise when it runs,the only way to kill it is with the task manager or something similiar. (最好设定成use the system tray,这样在任务栏有一个图标,不然的话只能通过资源管理器来关闭程序了)
Click oK (设置好之后点OK)
5.) now you should be able to run the program. (现在就可以运行KZUpdater程序了)
Ifyou installed shortcuts, you'll notice that you can check for updates.This means the program will run once, check for updates, and if thereare some, download them or prompt you, then quit. (如果选择了创建快捷方式,那么运行此快捷方式会自动检查地图更新,下载安装地图并退出)
Also theprogram will automatically download new versions of the software, andit takes a restart of the program to get these updates. (另外此程序支持自动更新,不过我怀疑作者会继续更新此软件)
这个软件也不复杂,不知道国内有没有人能做一个类似的,用上国内的地图更新服务器,应该会快很多。
本人只负责转帖,软件版权归原作者所有。
发表于 2009-5-24 07:57:52 | 显示全部楼层
到底是不支持自动更新 ..怀疑作者会继续更新此软件
还是  支持自动更新 ... 怀疑作者不会继续更新此软件
 楼主| 发表于 2009-5-24 08:31:04 | 显示全部楼层
s3veN 发表于 2009-5-24 07:57
后者。。。
好久不打中文,按英语习惯来了。。。
发表于 2009-5-24 12:22:51 | 显示全部楼层
什么东西啊?
发表于 2009-5-24 13:29:23 | 显示全部楼层
:P
发表于 2009-5-24 14:28:12 | 显示全部楼层
东西呢??
 楼主| 发表于 2009-5-25 01:08:58 | 显示全部楼层
。。。回帖不看帖的还真多
    发表于 2009-5-25 01:11:50 | 显示全部楼层
    不懂``````
