查看: 426|回复: 3
自定义管理员的皮肤
发表于 2009-5-3 12:04:26 | 显示全部楼层 |阅读模式
源代码 要弄到那个位置?
#include <amxmodx>
#include <amxmisc>
#include <cstrike>
public plugin_init() {
        register_plugin("admin", "1.0", "admin")
        register_event("ResetHUD", "resetModel", "b")
        return PLUGIN_CONTINUE
public plugin_precache() {
        precache_model("models/player/OP/OP.mdl")
        precache_model("models/player/MM/MM.mdl")
        precache_model("models/player/pifu1/pifu1.mdl")
        precache_model("models/player/pifu2/pifu2.mdl")
        precache_model("models/player/pifu3/pifu3.mdl")
        precache_model("models/player/CT/CT.mdl")
        precache_model("models/player/T/T.mdl")
public resetModel(id, level, cid) {
        if (get_user_flags(id) & ADMIN_LEVEL_A) {
                new CsTeams:userTeam = cs_get_user_team(id)
                if (userTeam == CS_TEAM_T) {
                        cs_set_user_model(id, "OP")
                else if(userTeam == CS_TEAM_CT) {
                else {
                        cs_reset_user_model(id)
        if (get_user_flags(id) & ADMIN_LEVEL_B) {
                        cs_set_user_model(id, "MM")
                else {
        if (get_user_flags(id) & ADMIN_LEVEL_C) {
                        cs_set_user_model(id, "pifu1")
                else {
        if (get_user_flags(id) & ADMIN_LEVEL_D) {
                        cs_set_user_model(id, "pifu2")
                else {
        if (get_user_flags(id) & ADMIN_LEVEL_E) {
                        cs_set_user_model(id, "pifu3")
                else {
        if (get_user_flags(id) & ADMIN_USER) {
                        cs_set_user_model(id, "T")
                        cs_set_user_model(id, "CT")
                else {
我不知道弄那去  谁知道的说下
 楼主| 发表于 2009-5-3 12:05:44 | 显示全部楼层
还有怎么弄,谁懂的帮帮忙,我加加++++++
发表于 2009-5-3 12:12:05 | 显示全部楼层
牛鳖 快来帮他
发表于 2009-5-3 13:32:54 | 显示全部楼层
牛鳖 快来帮他
