查看: 3552|回复: 46
KZ危在旦夕,命运尽在恶心的valve手中
发表于 2009-4-25 22:31:19 | 显示全部楼层 |阅读模式
XJ今天发布了一则消息:
Stand up to save CS 1.6 climbmaps.
请大家奋起拯救KZ吧。
Hey Guys,
筒子们
as you might know valve, the developers behind Counter-Strike 1.6,are running a series of updates at the moment, to "finally" fix the"russian duck" exploit (known as doubleduck in the Kreedz community).The first updates just added some extra sounds to achieve that, but thenext update, which is about to come very soon (you can already play itin steam by going to "settings -> account -> change ->Counter-Strike 1.6 Beta) will remove some of the sounds again (sincethe whole community hated them) BUT it will also added a massive slowdown after ducking.
你们也许听说过CS1.6的开发公司valve正在进行一系列升级行动,为了彻底地修复“russian walk”漏洞(也就是KZ中的狗跳技巧)。一开始的更新只是增加了一些额外的声音,但即将到来的进一步更新(你已经能在steam里玩到这个测试版了),会把某些声音重新去掉(所有人都觉得它们太恶心了),但还会极大地降低蹲下后的速度
Nosurprise that this will change the CS movement completely, which iskinda annoying for normal Counter-Strike players, but HORRIBLE for us,since it will kill (or at least make them way less effective) somebasic techniques in Kreedz:
毫无疑问这将会完全改变CS的进程,对普通CS玩家而言可能仅仅是有点烦,但对我们则是噩梦,因为这将破坏(至少是使变得无效)一些基本KZ技巧:
- Doubleducks
- Countjumps
- Duckstandup Bhops
Therforewe'd like to ask you to stand up to save the CS 1.6 Kreedz Climbmapsyou used to love as they are at the moment, and to take part in thediscussion going on in the official valve/steam forum thread.
所以希望你们起来拯救现在的KZ,请加入官方论坛里的讨论吧。
Let'shope we add some voices to make a chance, or at least to convince themto add a cvar or maybe even an own mod for our lovely community, toremove the new physics which are about to come and destroy CS 1.6climbmaps.
希望我们发出声音争取一个机会,或者至少说服valve添加一个控制变量甚至为我们热爱的社区提供专门的mod,而取消即将到来毁灭KZ的新机制。
Related links: http://forums.steampowered.com/forums/showthread.php?t=848369
Best regards,
参与人数 1金币 +5 +5 收起 理由
119366686 + 5 + 5 登不上!!!!!!!
发表于 2009-4-25 22:34:03 | 显示全部楼层
拯救地球 从我做起
哦~错了 是KZ...
发表于 2009-4-25 22:38:27 | 显示全部楼层
注册了 但是激活不成
发表于 2009-4-25 22:39:54 | 显示全部楼层
too bad
发表于 2009-4-25 22:40:25 | 显示全部楼层
其实我一直觉得CJ是个不应该存在的bug!!
发表于 2009-4-25 22:47:52 | 显示全部楼层
没CJ了 SC~~~~
发表于 2009-4-25 22:50:43 | 显示全部楼层
Hey Guys,
筒子们
这翻译的……
发表于 2009-4-25 22:52:06 | 显示全部楼层
没CJ用bhop和LJ走很多SC都要瘸腿了……
发表于 2009-4-25 22:54:40 | 显示全部楼层
这些东西都没了,那现时的WR又重新刷??
发表于 2009-4-25 23:24:22 | 显示全部楼层
其实我一直觉得我的存在是个错误...
